Question about Garden
Waterpump belt replace for Toro 217D ... Mitsubishi KE-75
Very limited adjustment...
2 Suggested Answers
USMC ETECH
  • 60 Answers
SOURCE: have a toro 217d 1986 model with a 30562 62inch
THIS IS THE WEBSITE FOR THE MANUAL. SO FAR THIS IS THE ONLY SITE I HAVE FOUND WITH THE INFORMATION.
https://homeownersolutions.toro.com/portal/server.pt?space=CommunityPage&cached=true&parentname=CommunityPage&parentid=1&in_hi_userid=19462&control=SetCommunity&CommunityID=214&PageID=238#manualsResultPage
I HOPE THIS HELPS IF NOT PLEASE LET ME KNOW AND I WILL FIND SOMETHING BETTER.
Posted on Feb 23, 2010
What do I need done to my 2010 mitsubishi endeavor it is at 109,000 miles.
replace the timing belt , crank and cam shaft seal , hydraulic belt adjuster and idler pulleys ( 100,000 km limit)
rest of the service as per the service manual
if automatic . change the auto oil and if CV Transmission check with the dealer as the transmission oil to use as it is different to automatic oil
Nov 12, 2017 | Mitsubishi Cars & Trucks
Mitsubishi Pajero2.5 ltr engine model 4D56, year build 1992. Engine runs like hum noise, after replacing the timinh belts.
Missmatched belt teeth or grooves. Wrong belt for the car installed. Worn waterpump, or bearings for cam.
Dec 13, 2013 | Cars & Trucks
Mower blades speed slows down in thick grass, the engine speed remains constant 217D
Hi, check that the belt is not worn and bottoming out in any of the pulleys and also check that none of the deck spindles are stiff to turn with the belt removed. Regards Phil.
Jul 03, 2012 | Toro Garden
I have an 89 cady with a 307. I replaced.the alternator, waterpump, waterpump pulley and .all of the belts but it is still screaming loudly. What else could it be caused from?
It probably is your P/S Belt. The P/S belt is adjusted different than the other belts. There is a slot in the pully that has to be lined up with the adjusting bolt on the pump. I think the adjusting bolt is more towsrd the bottom part of the pump. Tighten this up and that should repair the screaming.
Oct 19, 2011 | 1989 Cadillac Brougham
Toro model 38182 replaced new flat idler gear belt continues to come off after short amount of time can i use v shape idler part # please all parts rotate freely
It sounds to me like your idler pulley pin is bent. The Toro part number 75-872. You can order it through a shop like www.arcolawn.com and have it shipped to you in a day or two.
Please vote my fix up if it helps.
Joe
Feb 07, 2011 | Toro Lawn Mower With Toro Power Tools
Drive belt slipping, not propelling mower
Adjust belt tension or replace belt with new or slightly shorter one
Phillip
Sep 12, 2009 | Toro Lawn Mower With Toro Power Tools
Te magna waterpump changeover
MAGNA 1996 TE you have to pull down all covers of front of motor remove rh wheel and inner plastic protecters to access crank wheel remove crank wheel. rh engine mount and two outer belts lower/lift engine to remove timing belt pulleys ect.remove timing belt to access waterpump lots of labour can email photos if any one needs an idea .of whats involved when replacing water pump. best get a timing belt kit and replace belt ,pulleys as well. then good for 100.0000 kms and plugs as well platium ones by doing on your own can save 800 to 1000 dollars just be carful not to move pulleys on timing belt . good luck i posted this after i had no response .a desiel mechanic guided me though the ordeal a lot of labour for a waterpump it took me 8 hrs straight to do . hope this is useful i didnt need timing kit just belt total cost if you do job $350.00 i got quoted $1500 by mechanic
$25 COOLANT
$300 TIMING BELT KIT OR $100 FOR BELT ALONE
$95( WATER PUMP NON GEN SUPERCHEAP AUTO)( GENUINE MITS $300 TOO MUCH$$$)
$90 PLUGS PLATIUM
$30 OIL
$7 OIL FILTER
$10 GASKET GLUE
Apr 01, 2009 | Mitsubishi Diamante Cars & Trucks
Water pump chang on mitsubishi Galant 2.5 V6
Waterpump replacement requires removal and replacement of your timing belt. Because of this it is not your typical do it yourself repair. Engine timing is critical, and not having your belt set correctly can lead to catastrophic engine damage.
You can purchase a service manual at your local parts store to get an idea of what is involved, however this being an interference engine you should leave this job to a professional if you are uncertain enough about your abilities that you need to ask for help on it. The cost to replace the waterpump is far far less than the cost to repair a engine that had an incorrectly set timing belt.
Mar 13, 2009 | 2000 Mitsubishi Galant
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
