Cant read control board - Washing Machines
Goodman package unit pgb036075-1 issues. No light on control board
there is a fuse on the board which is very hard to see it is a three amp automotive style fuse most people cant find it it is purple in color look very closely using a flashlight
Aug 04, 2012 | Goodman GPC1342H21A Air Conditioner
I have a frigidaire fdb520rhs2a that will not come on I checked the circuit breaker and it's on. I ran the hot water for 10mins and still nothing.
Remove the bottom access panel in the front of the dishwasher. In a plastic envelote there is a technician diagnostic sheet. Read where it says start auto diagnostic mode. There are like 6-10 buttons you have to hit in a sequence. The sheet will also give you what is wrong and what to replace/ reset. If you cant enter diag mode than disconnect power remove the door panel and access the console. Open the control board and see if there is a 20amp fuse near the control board test this. This fuse is designed to protect the control board. If bad replace. If you have any more questions please comment me back.
Jul 30, 2011 | Frigidaire Dishwashers
GE Profile Model # JGS905SEK1SS Controll Board not lid cant operate broiler or see the time, what is wrong?
Sorry to read about your problem, I hope this helps you out.
try a reset ckt breakers for 10 sec...does oven lite come on..if yes..you have lost the control board on the unit..
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 25, 2010 | GE Microwave Ovens
2nd Hand simpson 880 dishwasher cant read numbers on dial. Can read a 6 but that is all. Have no manual, need to know which number is where on the dial.
is control board problem, also check for mains voltage, normaly is a mains cables problems.
if is +\- 10% tolerance (110V or 220V) of machine supply is ok, then is control board is defective, needs to replace\repaired.
is normal after a storm, some dishwasher (electronic) control boards be burned.
Feb 14, 2010 | Dishwashers
Ps3 will not play, read or eject game. light blinks green then blinks red
your bluray board is dead. there are two ic chips that control the board 1 controls the motor that inserts and ejects the disk is the one bad. sorry you cant buy that chip. get a new board find someone in youre area that does bga work and have your security chip removed from your board and placed on the new one. look at psxboy.com they will show which chips to remove. make sure you have the right board. they make 4 types. bmd-1,bmd-2,bmd-3,bmd-4 you will have to look to make sure of the board type. it will be on the bottom of bluray drive
Jan 22, 2010 | Sony Playstation 3 (PS3) Console
MY DOOR CONTROL PANEL WAS FLASHING AND THE ICE MAKER WAS FLAPPING,M AND IT WOULDNT STAY COLD. I WAS TOLD BY THE DEALER THAT I NEEDED TO REPLACE THE CONTROL PANEL ON THE DOOR. I HAVE DONE THAT AND IT IS...
you need to replace the high voltage board behind the unit , not he board behindthe dispnesor.. call maytag with oyur issue, tell them thatyou read about it oin the internet adn would like compenstaion for the board, form the numbe rof posts you read about!!!
Jan 26, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag Nepture MAH5500BWW burned control board
ummmm, honestly ive never replaced just the board(im an authorized maytag servicer) so our replacements have always been new, and in this case the repair kit containing both board and motor. that being said, i cant see a reason as to why you couldnt relace just the board itself, ,Ireally never found the reason why the board would burn out, but, as far as repair kit im certain that they were trying to get all circuit boards and motors back to only one model, instead of having 5 or six different boards andmotors, this will bring them all to the most recent board and motor, never was an issue with themotor, jusat that you couldnt wire in the new board without the neew wiring. As long as its the same board i cant see why that wont work. as far as the "wax motor" that was a seperate issue burning out the Top control board, total seperate then your problem,., dont really see an issue with installing your "used board"
Apr 07, 2008 | Maytag Neptune MAH5500B Front Load Washer
Electronic controls don't count down properly
Your problem is the electronic control board and unfortant that you cant repair or even get parts for it . Only if you get the whole control board will you fix your problem assy unless you find a good appliance man that repairs electronic control boards
Apr 14, 2006 | Bosch SHU5316UC Dishwasher
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
