Machine water only gets warm - Washing Machines
Cold water not going into my machine sw80usp
Make sure both water valves are on at the supply. Set the machine to warm wash/warm rinse and start it, feel the water coming in, then turn off the water valves at the take the water pressure off the hoses, then turn off the machine.Then swap the H and C water hoses at the back of the unit, then turn it on to wash again. If you now get cold but no hot, the cold water valve solenoid is bad, replace it.
Feb 16, 2015 | Washing Machines
How do I get the hot water work for my Fisher & Paykel Eco Smart washer?
How hot is the water temp in the house that you are in? If the inlet hose to the washer is not hot, then it is not the washing machine.
Jul 31, 2014 | Fisher Paykel EcoSmart GWL15
Maytag washer will not get warm
1) the temperature coming from your house determine how is the temperature. You can get hot, cold or mix of hot and cold available to your machine.If the water is too cold affect the machine,and if is too hot, the warm temperature colapse.
If you live Northern are, unless you adjust the cold and hot verywell affect the temperatur of your machine.WARM water is better in summer and Colder during the winter.
God bless you
Jun 21, 2012 | Maytag Washing Machines
My washer will not work. It will not fill unless the washer is on warm warm, hot warm anything but cold. Otherwise I get NO water. It will spin. But I can only get hot water. Not even warm water.
One of two things, easy one first, the cold water inlet screen on the back of the machine is clogged preventing cold water from entering,or more likely the mix valve has gone bad (the cold water solenoid) replacing the mix valve is not hard on these for a doit your selfer and the parts are less than $ 50.00
Sep 18, 2010 | Kenmore 24032\24036 Top Load Washer
Washer will not fill up with hot water however it will with warm
Is your water temp on your water heater set high enough? If it is sounds like you are getting water from both hot & cold water valves. If temp is set correctly on machine temp switch may be bad on warm all time.
Mar 12, 2010 | Kenmore Washing Machines
If the setting is only hot and cold, there will be no
warm water coming out. At warm setting if it is
present, it should give you warm water.
Sep 23, 2009 | Kenmore 3.5 cu. ft. King Size Capacity Top...
No warm or hot water
The easiest possibility is no hot water coming from supply,I have seen the valve turned off,input hose normaly has a filter where it attatches to the machine and they can get clogged.If neither of these solves problem just try hot valve to confirm water supply does work and if so more than likely the valve that hoses are connected to likely source of problem.
Apr 20, 2009 | Kenmore Washing Machines
lets see hear.what the water fill hoses are connected to is call the water fill valve.when you select a water temp.,electricty will then go to ither water valve coil or both for if your not getting hot it could be first that the fill screens at the hose at the water valve is blocked .but most of the time thats not true of hot because minerals drop out in the water heater before getting to the water valve,unlike the cold if screen is clean,next would be voltage to the water valve.if its getting voltage but not working then its the water valve.if its not getting voltage then use the wiring diagram to see what componet is before the water valve.may be water selector switch or timer
Jan 03, 2009 | Maytag HAV3460AWW Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
