Question about Tablets & eReaders
My mini iPad has gone into a reboot loop and I've tried the two button fix but it doesn't. I'd settle for a complete reset but don't know how to do it.
3 Suggested Answers
SOURCE: Son switched on guided access on iPad and doesn't know what pass code he used. Now stuck on safari and can't get to settings to switch guided access off
To disable guided access try the following:
Triple-click the Home button and enter the passcode chosen during setup of Guided Access to unlock the device
You'll now be back to the usual behavior of iOS.
If you'd like to turn off Guided Access completely, just go back to Settings > Accessibility > Guided Access > and flip the setting to OFF. You'll need to enter the passcode again to do so.
Posted on Oct 31, 2012
  • 6702 Answers
SOURCE: Hi I have just replaced a home button and screen on my mini iPad gone to charge it and am getting a dull chime about every 4 seconds and no power on.
If you have opened the iPad, to change the buttons, you must have made an error while reassembling it. I hope you did not glue it together, before you tested it, because it will be difficult (if not impossible) to open it again, without damaging the screen.
That is why (I'm a technician myself) I goto a repair store with Apple stuff. At least I get it back working, even if that tech makes an error.
Posted on Jan 02, 2015
My iPad is disabled and i don't know what to do i've gone on iTunes but nothing seemed to work,what should i do please help you think that you can help me
disabled how if icloud locked we or itunes cant help you --if battery or screen problem bring to a repair shop or sony store
Aug 30, 2016 | Apple iPad Mini
Setting up gave wrong email will not let me fix it
Barry, You may have to do a factory reset and start over, or contact manufacturer for suggestion.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Apple iPad mini Retina How to master reset
Perform factory reset Apple iPad mini 2 128 GB
How to Easily Master Format APPLE IPAD MINI 2 RETINA DISPLAY with Safety...
Feb 29, 2016 | Apple iPad Mini with Retina Display
Music sound is gone when I play my iPad mini
This can only be one of 3 things:
1) iPad needs a reset - Press and hold the Sleep/Wake button until the red slider appears. Drag the slider to turn your device completely off. After the device turns off, press and hold the Sleep/Wake button again until you see the Apple logo.
2) Toggle the 'Silence' switch on the side of the iPad and turn up the volume
3) If the above two doesn't work, then it is most likely that your speaker isn't working.
Sep 27, 2015 | Apple iPad Mini
My ipad is locked up and will not reboot, keeps saying go to itunes
Try a Hard Reset. Hold the On button and the Home button until you see the Apple Logo.
If that doesn't work , you need to connect it to a computer and use iTunes program to do a Factory reset. You will lose all the data on the iPad unless it is backed up, but it will give you a freshly installed machine.
Sep 21, 2015 | Apple iPad Mini
The touch screen in my Ipad stopped working. It works to unlock or to shut a screen but that's all.
Try restarting it: hold power button down until "slide to power off", power off for 10 seconds, press power to restart.
if that doesn't fix it, reset your iPad: hold BOTH power button and Home button until device resets and apple logo appears.
Feb 14, 2015 | Apple iPad Mini
How do I unfreeze my Apple ipad air ?
It's actually very easy, once you know how to do it. Click and hold down the Sleep/Wake button (located on the upper-right corner of your iPad). While you're holding down the Sleep/Wake button, hold down the Home button as well (located on the front of your iPad at the bottom).
Hold down both buttons until your iPad powers off. It will reboot and start again with a small silver Apple image on the screen. It takes about 30 seconds for the iPad completely start up.
May 12, 2014 | Apple iPad (16 GB) WiFi Tablet PC
App updates do not complete
1. Try one at a time 2. You will come to know which app is stalling the other two 3. Then take back up for the one that is not getting installed or updated. 4. Try updating if does not happen delete and re install
Dec 26, 2013 | Apple iPad Mini
Ipad screen not rotating
Hit home button 2 times then slide ur finger copper and click the cerved arrows
May 18, 2013 | Apple iPad (16 GB) WiFi Tablet PC
My Ipad Mini keeps shutting off automatically, then turns back on. When the home screen is shown it just keeps glitching and shutting off. Whats wrong with it?
I would first try doing a hard reset. Hold the home and power button down simultaneously until the iPad completely turns off and the Apple logo appears. You can ignore the slide to turn off button when it appears.
If that doesn't solve the issue I would make an appointment with your local Apple Store and have the device checked out by an Apple Genius.
Hope that helps!
Mar 22, 2013 | Apple iPad Mini
How do I unlock a locked up ipad?
If you've got a locked up iPad app or otherwise misbehaving iPad, and want to reboot / reset your iPad, simply hold the sleep and home buttons together until the iPad restarts.
You'll see the shutoff slider come up first, but just keep holding. The screen will go blank and the Apple logo will reappear as the iPad reboots.
Note: this does not reset any data on your iPad. This is just a restart, equivalent to rebooting your computer.
Aug 18, 2012 | Apple iPad 64 GB 3G Tablet PC
Tablets & eReaders Logo
35 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
