Question about The Computers & Internet
WHat is the tourney password - The Computers & Internet
Can I replace a Shimano RD-TY15 with Shimano Tourney TX?
Main thing with gears is that they have the same number of gears, and that the cage is the same length. Also the RD TY15 has a built in hanger.
The Tourney pictured has a built in hanger (below link) just make sure the replacement does.
SHIMANO TOURNEY TX 55 Rear Derailleur with Hanger Virtue Bike
Apr 24, 2015 | Shimano Cycling
Exploded view of parts diagram for shimano tourney st-ef40 shifters for re-assembly?
If you can't find with a search for st-ef40 diagram or on the Shimano site then it does not exist. Although not identical carefully disassembling the other shifter may give you enough insight.
Apr 08, 2015 | Shimano Tourney ST-EF40 3x7 Speed Brake...
Gears slipping whilst pedaling
you need to adjust the tension on the derallieur, you can log onto and follow instructions, it is simple enough the way they show it, if not then search derallieur adjustment
Feb 07, 2010 | Mountain Shimano Tourney 6/7 Rear...
Shimano Tourney rear derailleur is stuck on smallest gear and will not shift. How do I adjust the tension correctly?
There are several things that could be wrong. You could have thrown your chain (you couldn't ride at all if so). The bike could have been crashed and the derailleur bent. The cable might have slipped where it bolts to the derailleur. Or the cable or shifter could need maintenance, too. It is most likely one of the above. If it is only the adjustment, there are two stop screws on the derailleur that can be adjusted.
My best advice for you is to either find a bicycle repair manual at a local bookstore or your library that can show you some of the detail. Or just let your local bike shop do the repair.
Aug 30, 2009 | Mountain Shimano Tourney 6/7 Rear...
How to fit cable to shimano tourney FD-C050
Go to and download instructions.
Jul 03, 2009 | Shimano Cycling
Texas Holdem Tourney Blank Screen
Are you using AOL? It is a common error among AOL9 users.
You can view the problematic website in Firefox. I recommend you to download and install Firefox on your computer, and view the site with it.
Feb 25, 2009 | Microsoft Windows XP Professional With...
Computers & Internet Logo
20 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
