Question about Dryers
Tv won't start by pushing power button. but it clicks likes a relay.switch.it is panssonic.
Boba
  • 64 Answers
SOURCE: No Power
The click might originate from the cd mechanism, you might be expriencing some electrical display problem.
Posted on Mar 01, 2006
SOURCE: tv no start up, fuses ok.
Telling someone to get professional help would be the obvious response from a TV repairman who wants to charge someone at least half the cost of TV replacement to fix it. People get on here so the can try and avoid the high cost of tv repair. How about giving advice on how to fix it which is why the got on here to begin with.
Posted on Dec 28, 2007
  • 105 Answers
SOURCE: my tv won"t turn on.
1. Hold [menu] and [vol-] button on the side of the TV
2. while holding these, press the [power] button on the side of TV (NOT remote)
3. blue light comes ON and stays ON
4. wait 10 seconds then let go of [menu] and [vol-]
5. wait another 30 seconds and some type of picture should appear
I think this is right. I got it from the JVC call centers guys so sorry if I missed or messed up a step.
Posted on Apr 29, 2009
fkuk
  • 311 Answers
SOURCE: 2000 FORD WINDSTAR 3.8 NO POWER TO FUEL PUMP TRIED
check fuses
Posted on Dec 31, 2009
Testimonial: "Thanx that was it. Did not think relay would work with bad fuse."
electrotech1
  • 1126 Answers
SOURCE: Samsung model HP-T5054 Plasma TV
When you remove the back of the set. You will fined a couple of caps on the power supply board that are bulged and they need to be replaced, or you can buy a new power supply at www.partstore.com. If you want to just purchase the caps, you can get them at www.mcmelectronics.com
Posted on Oct 16, 2010
Samsung dryer DV42h5000ew won't power up
Kenmore Whirlpool Dryer Won Start Easy Fix
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=MhVUEhngZMg
https://www.youtube.com/watch?v=9xD7lCXJ0ZM
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
What to Test When Whirlpool or Kenmore Dryer Won Start or Run Kenmore Whirlpool Dryer Won Start Easy Fix Troubleshooting Why Your Dryer Won Start PartSelect com
Jan 02, 2017 | Samsung Dryers
GTWN4250D1WS WON'T START. CHECKED THE POWER CORD, ALL IS WELL. WONDER IF THERE IS A FUSE OR SOMETHING ELSE TO LOOK FOR.
Troubleshooting Why Your Dryer Won Start PartSelect com Electric dryer no start does nothing
Kenmore Whirlpool Dryer Won Start Easy Fix What to Test When Whirlpool or Kenmore Dryer Won Start or Run Troubleshooting Why Your Dryer Won Start PartSelect com
Jan 01, 2017 | Dryers
Kenmore dryer model 110.74994300 push start does not stay on
Jul 01, 2014 | Kenmore 62602 Electric Dryer
Kenmore elite sensor smart electric dryer Model 110 65066500 I have power but won't start
What to Test When Whirlpool or Kenmore Dryer Won Start or Run Troubleshooting Why Your Dryer Won Start PartSelect com Kenmore Whirlpool Dryer Won Start Easy Fix
Jun 24, 2014 | Kenmore Dryers
I have a Sony NSX-40GT1 that won't power on. You can hear the relay click after plugging in, and the red power led comes on, but when you push the power button it does nothing. Any ideas?
I'm having the same problem. Can anyone help. If possible i'd like to fix it rather than go return it. It worked fine for a while and then suddenly started turning itself off. Now every time i turn it on it turns itself off.
Jun 12, 2011 | Sony Google TV NSX-40GT1 40 in. HDTV LCD...
I have a 1997 Yamaha Big Bear that won't start with the button, can hand crank it with the starter cord and it will start - very hard to pull over cause I have a bum arm. I'm thinking it could be a...
you could be right about the starter relay, start with a test light and check the power at the relay. then if so check power at the switch if good make sure that the power is getting back to the relay if so replace your relay. let me know what you find and if you need help
May 23, 2011 | Yamaha DT 360 Motorcycles
My Kenmore Dryer model # 110.65942401 will not start. The door switch seems fine. When I hold the start button in I can here the timer clicking, that's it. Any suggestions? Thanks!
Kenmore Whirlpool Dryer Won Start Easy Fix Troubleshooting Why Your Dryer Won Start PartSelect com What to Test When Whirlpool or Kenmore Dryer Won Start or Run
Apr 29, 2011 | Kenmore 659 Electric Dryer
Gentlemen, I have a 1979 580c backhoe, proud owner for 3 weeks now. But it won?t start. Here's what I've done so far. 1.checked the starting circuit, the neutral switch is good. 2.I have continuity...
It sounds like you have a bad starter. You can try bringing 12v direct to
the starter just to be sure(be sure it's in neutral) or use a volt meter at
the starter while somone turns the key. You have checked the wire's
and all appears to be ok, the only thing left that would draw the meter
into the red is the starter itself. I hope this helps.
May 23, 2010 | Garden
Asko washer w6021 doesn't work. I've checked
See whether water is flowing into the wash machine. Then the door close switch.
Mar 28, 2010 | Asko W6021 Front Load Washer
2002 Suzuki GSX 600 F runs good when starts but now it wont start
Take a test light or multimeter and check if
power is getting to the starter each
time you push your starter button.
If so, the solenoid or starter relay is okay.
If not, then find the relay, it is at
the end of the battery positive wire.
It may be under the side cover or
under the seat.
Use your test light again and
see if power is on both sides
of the relays larger terminals when
you push your button (key on of course).
You should hear the solenoid or relay
click. It connects the positive
battery terminal to the starter
to make it run.
If it doesn't click or pass the power through
then check if power gets to it's
smaller wire when you push the button.
If not, could be the button, or
possibly something like a
bad side stand switch or engine
stop switch.
Aug 21, 2009 | 1993 Suzuki GSX 600 F (Katana)
Dryers Logo
Top Dryers Experts
