Question about Garden
I have no power to right side wheels, could I have sheared a key or connecter
2 Suggested Answers
  • 1118 Answers
SOURCE: Sheared off Wheel Stud
Not realy that critical sense theres 4 others, but it should be replaced as soon as posible. They put 5 on there for a reason.
Posted on Oct 06, 2009
Engine works fine blade turns, in gear tries if I push the tyre gently it tries to creep forward. The belt is turning and also the wheel but it is asif the gear is not engaging . Any thoughts?
make sure you have not sheared the key in the axle to wheel connection. and also check the key on the Transaxle input shaft and pulley connection that the belt rides around on the rear end..
Apr 17, 2016 | Garden
Tractor will not move under it's power.
Make sure you routed the drive belt correctly there might be an idler pulley you missed, make sure the belt is firmly on the trans axle, if so, put the rear end up on blocks and see if the wheels turn then, if they do put pressure against both rear wheels and see if you can stop them. If these wheels are on keyed axles and one key shears it wont drive because the drive wheel is the one that turns the easiest. so pull the wheel and check for a missing or sheared key. Replace key for an easy fix.
Jan 07, 2016 | Husqvarna Garden
The right rear wheel is not driving. Can you help
You probably shears something. There's probably a keyway with a broken shear key in it or perhaps a spring pin or clevis/hitch pin that's been broken. Try to look in the hub where the shaft goes through it coming from the transmission, if you see holes you need some sort of pin. If you take the wheel completely off and see a keyway in the shaft, you probably sheared the key and need a new one.
Jan 08, 2015 | Cub Cadet 2011 - LTX 1050 - 22 HP Kawasaki...
Hit a stump with lawnmower, now wont start
You may have sheared the flywheel key. This throws the timing off. If the shaft isn't bent replace the key.
Jun 22, 2014 | Poulan Pro 22inch 625 Series Briggs ...
My craftsman lawn mower started fine I pushed it about 100 feet it died won't start has gas and oil got it last summer
Here is one suggestion,that may help. When mowing,did you hit something hard,like a root or maybe a small stump. There is a key to a key way under the fly wheel. The key has to line up with the key way for the motor,to run. This is a way that the motor is timed. This key is made to shear off if the mower hits something solid,this is to protect the motor crank shaft from damage. To get to the key,to check to see if has sheared,you must remove the fly wheel. If the key is sheared you will have to purchase a new key,any lawn mower parts store has them. If you don't have a part number,that okay,just give the model # of the motor and the horse power. The parts department can look up the key. If this is a problem,for you,than take the sheared key to the parts department,and they can match up the key,by actual seeing the key. Remember this,you must have some mechanical knowledge,when doing this repair work. The flywheel usually comes off with little effort,then again,on some fly wheels has to removed with a puller tool. I hope this helps. Sincerely,Brad Locke
May 06, 2014 | Craftsman Garden
30 in. craftsman snow thrower,model no. 247.883960,pulls to the right
If your blower uses the two wheels to drive which I think it does I would suggest that you have a shear pin on the right side that is broken. If that is the case you will have to pull the wheel off and replace the shear pin. You can tell if it's broken by lifting the right side and trying to turn the wheel by hand.If it turns easily its broken.
This is an idea only. You might want to check both wheels as I'm not sure as far as the steering is concerned.
Feb 07, 2014 | Craftsman 30 In 357cc* Dual-Stage...
John deere 185 transmission
The easiest to check would be to remove the wheel and check to make sure the key is in the shaft on the axle. The rear wheels are keyed to the axles from the transmission and they are possible to shear. Also when the wheels are removed there will be an e-clip holding the wheels on. If one has broke that could be a reason your wheel seems to be coming off. If all there checks ok, the transmission will have to be replaced as John Deere does not make replacement parts for most and if they are available it is cheaper to replace the transmission. Let me know how you come out and if you need any more assistance, Daniel.
Nov 17, 2011 | John Deere Garden
Ignition switch not working
Have never heard of the pin shearing from a little bump chrysler double sided ignition cylinders usally start haveing problems at about 100,000 miles or so earlier if you have a bulky have key ring i would suggest spraying the inside of the cylinder with spray lubricant wd-40 I like tri flow little more exspensive but worth the money last a lot longer the run the key in and out very rapidly a few time let it sit a moment and the take pressure off wheel and try and turn the key
Aug 03, 2008 | 2003 Dodge Caravan
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
