Question about Toshiba Televison & Video
Toshiba 32 inch color purple takes over and faces distorted
    Top Expert:
  • Toshiba Master
  • 75,452 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Posted on Apr 15, 2017
Blurry, purple bar across middle of plasma tv screen
Plasma screens are extremely susceptible to getting broken from any impacts to the face of the screen. What you are describing sound very much like distorted or dead pixels. It may not be a fixable issue, you may have to replace the entire unit or live with the purple bar. The reason you don't notice it as much when the screen is dark is because purple is on the darker end of the spectrum, and will be most visible in contrast to lighter ad brighter colors.
Apr 01, 2016 | Samsung Televison & Video
32 inch sony bravia EX400 showing distorted colors and red screen on start up
reconnect the cable that goes from main board to tcon.. if this dose not work out change the tcon board which is cheap arond 25 US dollors..
Mar 29, 2012 | Sony Televison & Video
Toshiba 32 inch tv.colour flicks from blue to purple and green giving different coloured faces etc
T-Con Board or Display panel . Encompass Parts Distribution 1-800-638-3328
Dec 13, 2010 | Televison & Video
My toshiba 32 inch lcd tv has green ,red,and purple squigly lines on the screen Model # is 32AV500U
Change Your Regulator on your Color Mixer check the choke beside it the little yellow trasfomator beside.... It maybe damage too....
Sep 21, 2010 | Toshiba 32AV500U 32 in. LCD HDTV
My rca toshiba 50 inch projection tv is showing a 3d color curve
Need the model number to help as I am not sure of you have a RCA or a Toshiba
Dec 19, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Vertical Distortion fix for Toshiba 32 inch TV
You have bad capacitors and possibly a vertical IC that is going bad. And check for bad grounds in and around the IC and caps!
Dec 10, 2009 | Televison & Video
Toshiba Big Screen Tv Has Bad Colors
this is a rear projection tv not lcd the color is off because the convergance chips are bad take the board out that has the tow stand up chips attached to heatsinks out order the stk number search for on google then take a om meter check all the resistors aroung the chips replace them also you must be a excellent soilder person or a tech to install and remove these chips
Oct 19, 2009 | Toshiba 32 AV 500 PG 82cm 32 in. LCD TV
Bottom left corner of my toshiba 65h83 is blurred with color distortion mainly magenta and green. Distortion Is a half moon shape with the open end facing the edge of the set. Total distortion takes up...
Have you tried the "Magic Focus" Button/Option in the Menu Setup Screen? If you have and it still is there, You Have a Burned out Color Tube. It is Cheaper to Throw it away and Buy a New one.
Good Luck..
May 12, 2009 | Toshiba 42H81 42" Rear Projection...
Toshiba 32 inch tv picture is distorted
have you tried pic size on the remote to adjust the image. normal is the factor default.
Jan 29, 2008 | Toshiba 32AF43 32" TV
Distorted television image
bad caps in power supply and poss. pincushion section.
Dec 06, 2007 | Toshiba 32AF43 32" TV
Televison & Video Logo
29 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
