Question about Garden
Husq YTH24k48 riding mower; hit something and now front wheels don't seem connected - one canted out and one straight. Feels like you're mowing drunk and mower won't go straight.
    Top Expert:
  • Garden Master
  • 12,962 Answers
So now you have to re align the front wheels, don't you?
U have no recourse unless you want to get another mower.
Posted on Apr 15, 2017
HOW DO I ALIGN THE FRONT WEELS ON A D130
loosen up tie rod unhook tie rod from spindele turn tie rod in hook tie up to spindle see if straight if not repeat till straight make sure tie rod end is not bad replace if is make sure spindle not bent replace if it is
Sep 04, 2014 | John Deere D130 22HP V-Twin Foot Pedal...
How do you Assemble the anti-sway rod on a Husqvarna mowing deck?
The anti-sway bar fits into the frame. Then the sway bar then fits into the deck and connects with a washer and clip.
Sep 04, 2014 | Husqvarna Fast Tractor YTH24K48 48" 24HP...
My riding mower front tires are hard to turn cause they want to point in different directions and not straight. what could cause this
1) The tie rod between the front wheels is bent or the adjuster nut has come loose.
2) The plastic wheel bearings have gone to sh*t on either or both sides
3) The steering knuckles were never greased and their bushings are shot to sh*t.
4) The front tires have come off the rims
5) The front axle beam has been bent
Find a small engine repair shop in the yellow pages and have a person with know how put his eyes and hands on it, you will know within a few minutes what is wrong.
Sep 22, 2011 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
I have a riding mower model # 96040015 02 ser. # 1001094003997 and when the steering tires are straight forward one tire is straight and the other tire is at least 20-30 degrees to the outside....
You have a bent steering rod or misalignment. Either way git down there by the steering wheels and check it out.....You must have hit something in your mowing dreams??????
Apr 19, 2011 | Garden
How do you fix the front wheel alignment on a 48 inch lawn tractor by Craftman. The wheels are turned to the outside. Theres no bent rods or anything. Whenthe wheels go one way in the frony. you mow the...
make sure tie rod between wheels is straight. if bent will cause wheels to turn outward. take tie rod loose at each wheel, straighten rod reinstall wheels should be straight.
Aug 21, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have an early-2000s Troy Bilt Bronco, 42 inch deck, 18hp Briggs Inotek engine, hydrostatic drive. It broke or threw a drive belt (not for the mower deck, but a transmission belt). How to you go about...
While mowing the yard, the mower went dead. I tried to recrank it and it won't crank. The gas pedal goes straight to the floor and doesn't work to crank the mower. I do not know anything about mowers and don't know where the problem could be. Can someone help?
Jun 14, 2010 | Troy Garden
I have a John Deere X304 that mows unevenly.
Make sure that your gauge wheels are not running on the ground during mowing,they should only hit the ground when you engage a high spot on one side.also when you level the deck the front should be a 1/2" lower than the rear.
May 12, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Steering
Look under the front between the wheels at the tie rod that connects the two wheels. It is probably bent up and should be straight. If it's bent, remove it a straighten it.
Jun 19, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
My riding mower is stuck in gear. I can shift
If the wheels aren't facing straight forward you may have broken an axle.
May 18, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
