Question about Epson Stylus Photo RX600 All-In-One InkJet Printer
Discoloured bar on scanning from Epson Perfection 1670
Suddenly some months ago, my Epson scanner started showing a one-inch discoloured bar across the bottom one end of scanned items. It doesn't show or print in monochrome, but shows up as in mid-light grey Grayscale and bright yellow in Colour. This happens in all applications.
There's nothing on the scanner that I can see at all. I think it is a software issue, so I've tried unstalling/reinstalling the driver and associated utilities (several times), changing the USB cable, plugging it into different USB ports (direct to computer and on a hub), but nothing works.
I also borrowed a friend's identical scanner - and it showed exactly the same fault on my PC (but not on his).
It also shows up on a plain preview passes, but sometimes it will gradually fade if you carry out a series of previews; but then it comes back on the actual scan… Weird or what?
I'm running XP, fully up-to-date with service packs &c. and I wondered if there's some MS update that's causing a conflict, but I've found nothing useful on the MS site.
Any help at all very welcome. Apart from this, it's a very good scanner and I can't afford to replace it at the moment.
  • Epson Master
  • 511 Answers
It may be caused by driver conflict. Try to reinstalled OS and driver.
Posted on Jul 25, 2009
The scanner light on my epson 1670 fluctuates in intensity during scans which produce darker bands across printouts
check the power souce is conected properly it may be the bulb or pwer converter inside cheapest fix is to replace the whole unit.
Oct 06, 2010 | Epson Perfection 1670 Flatbed Scanner
Scanning Slides from Epson Perfection V700PRO
Hi
Please reinstall Epson Scanner software it will solve your problem
Thanks
Apr 11, 2008 | Epson Perfection V700 PHOTO Flatbed...
I unplugged my epson perfection 1670 scanner because my my mac said it was not connected--now when I scan something there is no image--just some lines--how do I correct this?
try uninstalling the drivers and then reinstalling them if it doesn't work you will need to replace the lamp in your scanner for information onthis go www.epson.co.uk/support
Jul 13, 2010 | Epson Perfection 1670 Flatbed Scanner
No image appears in preview or after scan using Epson Perfection 1670
I had exactly the same problem after moving my scanner to a new location, even though it was locked... it happened blank scanns, so I was about to go get my self a new scanner.
What I did was to get a cotton pad, put alot of alcohol on it and clean both sides of the connection usb cable in/out and then let it dry. Also I unistall all the epson scanner applications and reinstall with the new driver epson 12699.
It worked perfect, try it you have nothing to loose.
Jul 11, 2010 | Epson Perfection 1670 Flatbed Scanner
I keep getting an error that reads "unable to write to file". It was working fine and now I get that error about every 3rd scan.This is on an Epson Perfection 1670 scanner.
Just check if you have enough space where you are directing the scanning software to save the scanned images. You may be running short of disc space.
S. Mohan
Nov 04, 2009 | Epson Perfection 1670 Flatbed Scanner
Epson scanner 1670 scans a blank page
I can not copy scanned pictures from my epson perfection 1670 scanner from windows xp. Everything works from taking the scan and putting into a folder to be copied. When I bring this folder up to copy a blank 4"x4" or so window shows. I've used this scanner for 2 years or more and have had no problems till now.
Mar 15, 2009 | Epson Perfection 1670 Flatbed Scanner
Scanning App won't open.
Actually, it's okay- I just installed the windows drivers under Boot Camp, and that seemed to 'reset' the scanner under OSX.
Oct 12, 2008 | Epson Perfection 1670 Flatbed Scanner
1670 no image scan
Same Problem (WinXP System). I found leaving it off when not using it fixes my problems. (Its like the scanner light overheats or overloads the light receptors and it just sees white from then on, no matter what you do on the pc side of things). Other problems while stumbling into this "fix" include WIA drivers loaded which will stop scanner working properly, and finally scanner drivers seemingly working when USB cable in connected to another port other than what it was installed on but no image is shown (Not 100% sure if it was same problem as detailed at top)
Feb 08, 2008 | Epson Perfection 1670 Flatbed Scanner
Epson Stylus Photo RX600 All-In-One InkJet Printer Logo
64 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
