Question about Garden
Hi ihave mc culloch wiper snipper 2009 m1325cls, I need diagram for replace the fuel line pleace
  • 708 Answers
SOURCE: What is the oil-gas ratio and the bar oil for a Mc Culloch Mac130
You should be safe with a 32:1 mixture unless you are a logger. And any Bar Chain Oil should work fine.
Posted on Apr 16, 2009
dontbother10
  • 2220 Answers
SOURCE: mc culloch chain saw 742 manual need urgently
Both the OM and IPL can be found here:
http://www.mcculloch.biz/int/support/owners-manuals/
Just type "742" in the "Model Search" window and click Search. HTH
Lou
Posted on Feb 17, 2010
dontbother10
  • 2220 Answers
SOURCE: have a mc culloch chain saw pro mac 10-105. No
I do find a 10-105 could it be a 10-10S model 600111 follows:
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/8f167f396637c29d88256c2e0073560e?OpenDocument
Change the plug and try it, very cheap insurance.
Ignition Coil Test by SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You do not have to bend up the electrode.
Rotating the flywheel in a darkened room with the plug removed and the ignition on may reveal a leaky plug wire. Often a little heat shrink tubing will stop any leaks.
Model "11-600111-06 (02 through 06 suffixes possible) follows:
http://www.ordertree.com/modelinfo/MCC/11-600111-06-PRO-MAC-10-10S-08%2F82-to-Current-IPL-216062-01/139.11-600111-06-PRO-MAC-10-10S-08%2F82-to-Current-IPL-216062-01.1.59.1.html
See the "Powerhead Assembly" item 11; part number 223708-01.
If you determine the coil is bad I found one here:
M & D Mower
http://www.m-and-d.com/parts.html
Coil
http://arinet.lookupparts.com/AddToBasket.aspx?Qualifier=MCH&Name=223708-01&Quantity=0&SellerId=1017594&Username=Default
Ignition module gap
Place a business or index card between the fly wheel and coil, rotate until the magnetic attraction pulls everything tight together. Tighten the coil screws, rotate the flywheel until the attraction eases and remove the card. Ensure nothing contacts when flywheel is rotated.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 12, 2010
suzukiracing
  • 200 Answers
SOURCE: what are the carb. adjs. on a Mc culloch chain saw model cs 38em
If it bogs down like it's getting too much fuel, turn the low side screw out about 1/8 of a turn at a time until it will rev without bogging. If it chokes down like it's not getting any fuel, you probably need to open up the high screw a little.
BTW, you can determine which screw is which by looking at the carb at the base of the screw...it will have a L for Low or H for High stamped near it.
Posted on Jul 19, 2010
  • 173 Answers
SOURCE: My Mc Culloch chainsaw will not start due to
It will spit fuel like that because it sounds like it is not getting any spark to the plug.I would try a new plug first then if that don,t work you have a coil problem.
Posted on Dec 28, 2010
Is there a special tool to adjust the Hi Low fuel mixture on a mc culloch t55 hedge trimmer
Anon, you may need a special type screw drive bit. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Amazon com Lifetime Warranty 2 Cycle Carburetor Adjustment Tool 4 Piece...
carburetor tool
Adjusting weed eater carb without special tool
Carburetor Adjusting Tool eBay
May 25, 2016 | Garden
I need a English manual for a Smash 18 petrol chainsaw
I found information for my saw on line at the Mc Culloch web site.
Dec 11, 2013 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Need manual for mc culloch mdaht 25 hedgetrimmer
Manuals may be downloaded below:
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Jun 02, 2012 | McCulloch Garden
What kind of fuel i need for my older mc culloch chainsaw-1:25 or 1:50?
To be on the safe side i would use 25-1, it will not harm the machine, just smoke a little more.
Sep 17, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Mc Culloch power washer FH140A The "on/off"
easiest way to fix it, buy a new switch at a home improvement center, the two metal piece go on the bottom and the springs are on top of them, when the switch is in the off position the metal pieces are up off the contacts on the bottom and when on the on position the metal pieces make contact. Hope this helps Tim
May 28, 2011 | McCulloch 1400 Psi Electric Pressure...
What are the carb. adjs. on a Mc culloch chain saw model cs 38em
Jul 18, 2010 | McCulloch Garden
Mc culloch chain saw 742 manual need urgently
Lou
Feb 17, 2010 | McCulloch Garden
After having my Mc Culloch sharpened
You may have the chain on backward. The teeth on the bottom of the bar have to have the sharp edge coming at you in order to cut anything. Hope this helps you, Jeepfxr
Jan 28, 2010 | Garden
Apr 15, 2009 | McCulloch Garden
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
