You would need to change the BIT Settings on your Blue-Ray player to 24HZ this can been done through accessing the customer on screen menu
  • 3 Answers
SOURCE: blue ray player wont play blue ray ''Kung Fu Panda'' disc.
i fixed this exactly as previous posted solutions, however a couple of points.
a) recordable CDs work if you don't have a DVD burner.
b) I didn't have a CD burner that would do an "image burn", I downloaded a free copy of "Express Burn" and that worked fine. The disk needs to be "finalised" or "fixated", it should do this automatically, or it may be a tick box selection.
c) I got a "No DWLD 09" when I put the disk into the player. I found this was an incompatibility with the CD-R (Maxwell) I was using. I changed to JVC and it worked fine.
Posted on Dec 29, 2008
SOURCE: PS3 - green Bar when playing blue ray on my 50" Phillips Plasma
Green bar or border is due to wrong AV Setting. To resolve this just insert the Blue-Ray DVD and begin to play. Press the Triangle button and select "AV Setting", in AV Setting change Video Output to RGB.
Posted on Jan 14, 2010
SOURCE: how to access optipoint 410 config menu
Press 1, 0 & 3 at the same time, this can be quite awkward & may need several attempts to succeed, but it does work.
Posted on Feb 08, 2010
  • 3 Answers
SOURCE: My Sharp Aquos Blu Ray player cannot play my blue ray disc.
goto sharpusa.com and put in your model number. download the update to flashdrive and the update your blu ray..and it will then play
Posted on Apr 24, 2010
DINSPIRED1
  • 15 Answers
SOURCE: I can't get my blue ray player to play Avatar Blue
Like Kelt67 said a firmware is needed....Avatar holds a lot of memory on the blu ray disc as that's one reason there are no trailers just strictly the movie and that's it on the blu ray....Avatar works perfectly fine in my PS3 but then my fiance tried watching on a regular Sony blu ray player and it just sits and loads forever....needs a firmware upgrade need to pop the firmware disc in and download by contacting your blu ray manufacture if no ethernet port on your blu ray player.
Posted on Apr 25, 2010
How do I reset my funai blue ray player to factory settings?
Macgo Windows blu-ray Player, with detailed Menu for you operate, and you can reset to factory setting easily. You can try for free.
http://www.macblurayplayer.com/windows-bluray-player.htm
Nov 17, 2014 | Funai Televison & Video
How do I change video settings back to NTSC on a Philips DVD player?
call the manufacture service # or look in the manual for the reset button on the player
Aug 21, 2014 | Philips Televison & Video
Hello. I switch an option, i switch to progressiv option and i dont see anithing how can i reset the DVD player? It is a piooner DV-300-K DVD player. Thanks for help.
According to the Pioneer FAQ for this item :
"You can reset all models of DVD Players with the following method:
1) Switch the player into standby and empty the disc tray.
2) Using the front panel buttons, hold down the STOP button and press STANDBY/ON to switch the player back on."
Mar 03, 2011 | Pioneer DV-300-K Player
I am trying to connect a wireless ready Samsung blueray player to my Motorola Surfboad and it says to press the wps button on the surfboad, where is it?
NOTE: [] & "button(s)" represent features on the remote controller. {} & "key(s)" represent features in on-screen menus.
ROUTER INFO: WPS is on the SBG901.
BLU-RAY DISK PLAYER: You did not mention the model # of the Samsung Blu-ray disc player, so this information is somewhat generalized.
PREREQUISITE: Once you have attached Samsung's proprietary wireless adapter to that Blu-ray player, have connected that Blu-ray player to your TV, & have powered on that router & Blu-ray player & TV, access that Blu-ray player's initial settings menu.
STEP ONE: From the Home menu, press ?? buttons to select "Settings." Press [ENTER].
STEP TWO: Press ?? buttons to select "Network." Press [ENTER].
STEP THREE: Press ?? buttons to select "Network Settings." Press [ENTER].
STEP FOUR: Press ?? buttons to select "Network Type." Press [ENTER].
STEP FIVE: Instead of using the the "PBC (WPS)" selection, press ?? buttons to choose the "Wireless" selection & press [ENTER].
STEP SIX: Press ?? buttons to select "Internet Protocol Setup." Press [ENTER].
STEP SEVEN: Press ?? buttons to select "Auto" or "Manual." Press [ENTER].
IF SETTING UP WIRELESS CONNECTIVITY VIA AUTO NETWORK SEARCH: If you selected "Auto," press the ? button to go to "Access Point Selection." Press [ENTER]. Upon searching for available wireless networks, it will display those choices in a list.
A.) In the list of networks, press ?? buttons to select your network. Press [ENTER].
B.) IF "PIN/Security" DOES NOT POP UP, THEN SKIP THIS STEP; otherwise, press ?? buttons to select PIN or Security (Security Key--the usual option), & enter your network's Pass Phrase on the Security screen. (This Pass Phrase would be what you would use to access the network. IT SHOULD NOT THE PASSWORD WITH WHICH YOU SET UP YOUR ROUTER!)
Press number buttons on the remote to enter Pass Phrase numbers OR use arrow buttons on the remote to move from key to key in the Security Key screen. Change the type of on-screen accessible characters by moving to the on-screen {a/A/1/?} key & pressing [ENTER] on the remote. (The character set changes with each press of [ENTER]. Once displayed on the screen, you can enter a letter by pressing the number button on the remote which corresponds to that letter key. Pressing that button repeatedly changes the letter. You can move to {Delete} & press [ENTER] in order to remove the last character entered. You can move to {Clear} & press [ENTER] to clear all entered characters (or just press the red [(A)] button. When done, press the yellow [(C)} button (or the {Done} key followed by [ENTER]).
C.) WAIT UNTIL THE CONNECTION CONFIRMATION MESSAGE DISPLAYS & THEN PRESS [ENTER]. You're back at the Network Selection menu.
D.) To test the connection, press ? to select "Network Test." Press [ENTER].
IF YOU REQUIRE ASSISTANCE WITH SETTING UP THE WIRELESS NETWORK CONNECTION MANUALLY, I SUGGEST THAT YOU READ THE MANUAL (http://www.samsung.com/us/support/).
Jan 08, 2011 | Arris SURFboard SBG900 Wireless Router...
For some reason mt blue ray player was saying 1080i and not p so i went into menu and changed to 1080p but tv is now saying mode not supported and i cant get back into the menu on the blue ray player to...
Try to make use of the yellow video cable, the cable that is part of the RCA cable and try to set the TV to AV1 as soon as the video cable is connected from your BD player to your TV. Turn on your Bd player and you can now set the TV to its correct resolution. Best thing also to reset oyur bd player back to its factory settings.
Oct 22, 2010 | Samsung BD-P1400 Blu-Ray Player
How can I get my bought today ps3 to play a blue ray movie? It isn't even 12 hours old. I put the movie in and I get nothing. Please help me.
You may, need to update over the internet for that to work, properly. Also try this go to BD/DVD Settings, then BD 1080P 24Hz Output (HDMI) and changed the setting from "automatic" to "off"... Then try & replay the movie.
Feb 16, 2010 | Video Game Consoles & Games
I did some stupid settings with progressive output. now the tv screen is blue and i can hear the DVD running. Menu is also not visible.
Put player in standby mode, Press 369 on DVD player remote, power up. This will turn off progressive mode.
May 26, 2009 | Sony DVP-NS67P DVD Player
Changed HDMI settings and can't now see image on screen
I did the same thing, if you hold the hdmi select button on the player (not the remote) while ejecting and inserting a dvd, it will reset so you are able to access the setup menu again.
Feb 08, 2009 | Toshiba SD-4700 DVD Player
Bypass
1) Insert the DVD and you'll get the blue screen.
(If you have more than one tv, the unit itself will have the blue screen but the additional tv's you have plugged in will NOT, they will show the dvd menu. Thus you will be able to see the hidden menu on the additional screens after inputting the code, but not on the main unit because of its blue screen.)
2) On the main remote, push stop twice and then 1, 2, 6, 4
3) Push the joystick on the unit SOUTH twice and then click it once.
4) Press SYS SETUP on the main remote twice to save your settings.
It may take a few tries but you'll get it. This method can be done if you don't want to bother temporarily activating the brake sequence, but if you only have the unit and no additional tv's, its #$%^&* damn hardbecause you can't see the settings your changing.
Jan 21, 2008 | Audiovox VM9311TS
Samsung LCD tv and PS3
the problem is with the frames per second that the ps3 is putting out. i wound up calling both samsung and sony and the problem was in the settings. the ps3 allows you the option of playing in 24hz and for some reason if the option isn't turned off our tvs won't display frames at that rate. just go to the dvd settings and deselect the 24hz option, changing it from AUTO to OFF... the only problem i have with this is that this should effect the picture quality, becasue if it isn't displaying in 24hz that means it is downscaling the display and if it isn't upscaled by the tv's processor, then the display should be worse. i might be imagining it, but it does seem worse.. atleast they play now though. hope i helped.
Nov 03, 2007 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
Top Televison & Video Experts
