Question about Kubota Garden
Where is the stop switch located on a kubota zg227 zero turn mower
5 Suggested Answers
  • 12 Answers
SOURCE: Where can I get free download manual for a Kubota Mower ZD21?
http://www.mckeelequipment.com/kubota-mowers.htm
Posted on Jun 26, 2009
mickey813
  • 472 Answers
SOURCE: Kubota Z18 zero turn mower won't start.
souns like the key swich is bad ck that
Posted on Oct 01, 2009
cardenderek
  • 783 Answers
SOURCE: I own a 42" Troy Bilt zero turn. The PTO switch
What the problem is (im not sure if they are called this) but the deck pulley brakes are worn out.
Basically if you look under the rider frame side (on top of the deck). There are on each side for each spindle pulley a flat metal tab. On the underside of that is just like a brake on your car. So when you raise the deck the pulley brakes hit the top of the pulleys and stop them from spinning. Which cause the blades to stop spinnign. There are probably turning at 10% of there normal speed. If that sound like what its doing check the brakes.
They are a replaceable part. Sorry I just cant remember exactly what they are called. Over the years they just wear out like a set of brake pads on your car. And the mower cuts and just work fine. Thats where I would start. When they wear out, the friction material is gone. Best Reguards, Premium FixYa Support
Posted on Jul 27, 2011
  • 19 Answers
SOURCE: I have a zero turn Yard Man 42 inch mower, it
It could be a problem in your seat safety switch. You can enter your model number here: www.mtdparts.com and see a schematic.
Posted on Oct 31, 2011
My KUBOTA ZD326S Zero Turn mower (diesel) makes a ringing sound as it is running. What is causing this?
something loose on a crank shaft or cutting shafts
I would be looking at failing bearings on the pulley shafts for the cutters
Mar 23, 2018 | Kubota Garden
Find the relay on a kubota
jump starter with battery if starts look for bad ignition switch or battery dosnt have enough amps or bad contact in silinoid you have to buy one to find out
Sep 12, 2014 | Kubota Garden
Kubota zero turn mower
You probably picked up some contaminate from the bottom of your tank... Try some carb spray but it will probably require a good carb cleaning...
Aug 02, 2014 | Kubota Garden
I have a DZ21 kubota zero turn mower that will not start with key
I would check for power at the starter solenoid. Use a test light and check for power at the start terminal of the solenoid. Also check for power at the switch terminals.
May 07, 2014 | Garden
Pto onmy kubota zero trun zg 23 wont work
Check to make sure you are getting power on both sides of the switch. Check the connectors going to electromagnetic engagement PTO unit. This is mounted right on the base of engine. Check ground wire coming from unit to make sure you have agod grounfd connection.
Feb 27, 2014 | Kubota Garden
Garden Logo
317 people viewed this question
Top Kubota Garden Experts
Vernon Taylor
Mike Henne
Level 1 Expert
Are you a Kubota Garden Expert? Answer questions, earn points and help others
