Question about The Computers & Internet
When i turn the scanner on only one light is green the other remains amber and won't scan
Amardeep46
  • 129 Answers
SOURCE: blank screen
This looks like a problem with the video card or the power supply to the monitor. Try connecting a different monitor and if you still face the same problem then probably you may need to have a look at your video card or its connection in motherboard
Posted on Feb 01, 2009
pineworks
  • 4041 Answers
SOURCE: my canon i850 printer head will not move. When I
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. Release RESUME
3. Press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i850)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
Posted on Feb 16, 2010
  • 32 Answers
SOURCE: stuck on amber light will not turn on
An amber light normally means that there is no signal getting to the screen, if it was stuck in standby then the LED would be red.
Please check your connections to cure the fault
Posted on May 31, 2010
budmrtn
  • 11361 Answers
SOURCE: Blinking led light on monitor, amber and flash
Look for poor solder joints and caps in the power supply/inverter bd first.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Jun 13, 2010
SOURCE: The light on the power switch turns green when the switch is pressed on, but soon after it turns amber and keeps blinking. Therefore there is no display on the monitor screen. The amber light keeps bl
SOLUTION FOR THAT- JUST UNPLUG THE MONITOR AND PLUG IT AGAIN
Posted on Oct 09, 2011
When i turn on my Dell Inspiron 2400 Desktop Computer why won`t it start.
Is the computer plugged in to a known good power source with a known good power cord? Also, make sure the power is fully seated on both ends. When you press the power button are you getting any indicator lights? The power button itself has an LED that will be either solid green, blinking green, solid amber, blinking amber, or off. Do you hear any beeps?
May 19, 2014 | Dell Inspiron 530s Desktop Computer...
I purchased a new battery for my Dell Latitude 810 and it still won't hold a charge. The battery indicator light is green for a brief period, turns amber and then shuts off.
If you installed a new battery in your Dell computer and still can't get it to charge, there is a strong possibility that there is something wrong with the charging system
Mar 07, 2013 | Dell Latitude D810 Notebook
Notebook won't turn on
my nb500 netbook wont turn on i slamed it shut now wont turn on
Apr 23, 2012 | Toshiba NB500-12X
What's your problem?system turned off green light then amber then flashing red
it's a hardware fault. If it's under guarantee send it back. If not then your fault might be able to be repaired at a cost. The fault is likely to be caused by overheating. turn it off on the back and let it cool. if the fault remains or reoccurs (which it most likely will) then it needs looking at by an electronics guy :O)
Jan 08, 2012 | Sony Playstation 3 (PS3) Console
E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
May 12, 2011 | Computers & Internet
Tv shutdown
check your lamp door interlock switch.
Jul 31, 2010 | Mitsubishi WD-65733 65" HDTV
When i turn the printer on the light flashes amber several times, then green then repeats flashing amber, and back to green etc. turning it off and back on made no difference. last time it worked...
when i turn the printer on the light flashes amber several times, then green then repeats flashing amber, and back to green etc. turning it off and back on made no difference. last time it worked normally after being off for a couple of days, but now it is doing that again.
Amber light flashes 7 times, then green for a couple of seconds, then amber 7 times etc.
Jun 02, 2010 | Canon BJ I6500 InkJet Printer
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
replace the sustainer boards should correct this problem. New sustainer boards may cause red and green pixilation. If this happen, replace control board and TV is as good as new.
Apr 05, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Computers & Internet Logo
24 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
