Question about Building Materials
How do I re-program my genie promax chain guide 2
I have a genie promax chain glide2, and it has open 4 times by could someone in the neighborhood be on the same frequency that's causing my door to open. And if so how can I change the frequency/code.
press and hold the learn button for a count of ten. then press and release the button once and then press and hold you remote your remote until you see the light flash. do this for each remote
Nov 05, 2016 | Building Materials
I cannot program my receiver Genie ACSR3 to work with a remote Genie GITR-3
check age difference, every so often the codes change and older parts will not work with newer parts
Nov 03, 2014 | Building Materials
Genie 1024 remote programming
On model 1024 genie garage door the carriage trolley jumping out of the chain what should i do to fix it or replace parts...
Feb 19, 2014 | Genie Company Genie Intellicode GITR-3...
I have a genie promax chain glide 2 garage door opener. The door will close completely then pop right back up. We noticed their is a black wire (split in a "Y" shape/spliced) haging down about a foot from...
probably the wire fell off one of the Door obstruction sensors
Check the wiring on the little reflector things on the tracks at floor level
Sep 24, 2013 | Garden
Garage door opener Chamberlain - programming problems
I bought a new keypad and 2 VISOR remote (30498). As to programming garage door opener, I did like here:
- it tooks me 20 minutes and works great
Feb 07, 2013 | Sears Craftsman LiftMaster Chamberlain...
Unable to program universal opener with genie pro max garage
Actually, this remote can be used with Genie Garages. See the article here on eHow - I used this to program a KLIK1U to work with my Genie Promax 2 garage. Hope that helps!
Oct 11, 2012 | Chamberlain Clicker Universal Remote...
I can move the chain freely by hand but when I hit
Sounds like you are in need of replacement gears. It is like the transmission going out in your car. I would leave this to a pro but if you want to do it parts can be found at genie.com or overheaddoor.com. Thanks BB
Mar 08, 2010 | Genie Company IntelliCode GICT390-1BL...
The motor on my Genie Chain Glide garage door operator runs but the chain does not run or move.
If the chain does not move but the motor runs then you have stripped the internal gears. I would replace here. These chain glide units are not very strong. There might be a chance the chain is telescoping down the rail but the trolley is not hooked up. Pull the red cord back toward the motor to engage. Thanks BB
Dec 29, 2009 | Genie Company Genie PowerLift Excelerator...
Building Materials Logo
115 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
