Question about Shoprider Health & Beauty
My shoprider scooter lights up when key is turned on but cannot get any forward or reverse movement...any suggestions please
  • Shoprider Master
  • 9,639 Answers
Make sure the freewheel lever is engaged. The connections on the controller may be loose or the large connections where the front and rear separate aren't making a good connection.
Posted on Apr 15, 2017
  • 32 Answers
SOURCE: no movement, forward or reverse
sounds like it is in neutral, look for a lever on the bottom, rear of the scooter to pull up
Posted on May 07, 2009
  • 16 Answers
SOURCE: shoprider sovereign
If the freewheel lever has been operated while key is in on position the scooter will not operate until key is turned off and then on again, make sure freewheel lever is in drive position. hope this helps.
Posted on Aug 04, 2009
  • 29 Answers
SOURCE: Hi I have a shoprider cadiz .. when i try using
your throttle pot needs replacing. your thumb lever attaches to the throttle pot.
Posted on Nov 20, 2009
Testimonial: "Wonderful information Thank you ..before i read your answer i sprayed the throttle pot as you call it with switch cleaner Been great since .. "
skaterkid307
  • 86 Answers
SOURCE: scooter stops then jumps forward
mait be problem with moter
Posted on Feb 20, 2010
  • 50 Answers
SOURCE: hi my scooter will drive
Hi tandseaster,
I have owned my own business for 3 years and have been working on scooters and powerchairs for 15 years. I know exactly what the problem is. I can almost tell you what kind of scooter you have. In the future give as much info about the scooter as possible.
Your problem is the throttle pot or somtime called the engager.
You can do one of two things. 1. Open the faceplate to your tiller. look for a lock nut on the throttle pot. loosen it, on the bottom of the pot is a slot for a flat tip screwdriver. Take the key out before you start this procedure. You can turn the screw slot on the pot a little at a time, one way then the other. Turn the key back on, turn the speed pot to lowest speed so the scooter won't take off on you. Once you align the throttle pot to neutral tighten the lock nut. The easiest way to fix your problem is:
2. Replace the throttle pot.
Your problem will be fixed.
Good Luck
Tim
Posted on May 02, 2011
My shoprider jolts and shakes on reverse it is only 3 months old
The result of data corruption that can occur when power is low enough to get interupted by the load of a motor. The above solution it the correct thing to try first/
Jul 11, 2012 | Shoprider SL73 Echo 3 Wheel Scooter ()
The forward/reverse lever on my shoprider cooper is loose. How can I repair it?
hi, you need to take the tiller apart and refit the spring ... this does happen, a picture will help and i can advise you what to do ...
Regards
Rob
www.gewizrepairs.co.uk
Jun 09, 2012 | Shoprider Cooper Scooter in Red
Nov 16, 2009 | Pride New Mobility Legend 4 Wheel Scooter
Shoprider sovereign when switching on and pressing reverse scooter will not move but reverse bleeper sounds nor will scooter move forwards. switch off and on again and on then works correctly
Jun 29, 2009 | Kitchen Appliances - Others
No movement, forward or reverse
Apr 24, 2009 | Health & Beauty
Shoprider deluxe te-889af loses power when reversing
I think that this is usual to have a slower reverse speed for safety.But on your shoprider you should have 4mph and 8mph ,usually if you are at 8mph it won`t reverse at that speed, you have to go to 4mph ,look infront of you there is a dial this controls the speed that you go forward and reverse.If reverse speed needs to be increased turn the dial up,but don`t forget this also increases forwards.
Jan 14, 2009 | Shoprider Sprinter 889B-4 Scooter by
Health & Beauty Logo
Top Shoprider Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you a Shoprider Health and Beauty Expert? Answer questions, earn points and help others
