Question about Pool & Spa
How to replace drain on Beachcomer Hot Tub - Pool & Spa
  • 77 Answers
The last Beachcomber drain I replaced was due to a leak.
It's awkward to explain this one... The drain was slightly protruding out of the plastic and pointing towards the equipment enclosure. I assume that yours is the same......
I had to cut a small section out of the plastic so that I could gain more access to the pipe within the spa cabinet. Only once I had gained more access could I cut the pipe and then begin to glue on a coupler and a new drain valve. If my memory serves me correct, the pipe was a 3/4".
Posted on Apr 28, 2017
Morgan hot tub
if no drain at bottom usually with hose connection on it use a sump pump or syphon make sure power is off until fully refilled
Jun 30, 2014 | Pool & Spa
Hot Tub - Spring cleaning and Maintenance
Spring is a great time to change the water in your hot tub and clean or replace your hot tub filters. Drain and give your hot tub a good thorough cleaning to rid yourself of the winter season. Make sure that you clean your hot tub cover at the same time both the top and the underside. This will help the hot tub cover to last longer and perform better. Hot Tub Spring Cleaning Tips
on Mar 27, 2015 | Pool & Spa
How to stop squeak on Hotpoint Washer?
see the causes:
During fill only
air gap deformed or crack, the tube crack cause leak,inlet spout crack cause leak.
During drain and spin only
main drain hose, inspect the hose,plastic outer tub can rust or split you must replace the entire outer tub
All the time
check hose for cold and hot water,main tub seal, pump leak replace,outer tub replace.
God bless you
Jun 19, 2012 | Hotpoint Washing Machines
Why does the ice bucket not drain into the hot tub!
Ice buckets don't normally drain into the hot tub water. They should drain externally. The drain pipe will go through the cabinet and exit the bottom close to the floor.... or at least that's how all the ice buckets I've encountered drain.
Jul 05, 2010 | Pool & Spa
How do you drain the spa?
There is probably a drain valve somewhere near the control panel ... forgetabout it ... too slow.
Best way is to get a small pump and pump it away. Next best is wet dry (shop vac). My favorite is siphon ... dont have to buy anything or drag anything out ... only a hose. By the time my water is out ... I have had time to do the necessary surface cleaning and waxing.
What does FL mean on my hot tub?? water doesnt circulate but is still sort of warm...
FL could be a code for low flow. If you have no circulation this sounds like it. If your pump runs and you have no flow you could have a problem with your pump. Or if you have the tub drained then it could be an air lock, if you open the drain valve till you get water out that should fix that. Also check to be sure the isolation valves are open under the spa. I hope this helps.
Feb 07, 2010 | Qca Spas Dream Series Dream Master Hot Tub...
We have a dreammaker spa, how do we drain it? the model is Fantasy
The Fantasy has a drain located in the toekick of the spa. You have to first remove the drain cap, attach a hose if you wish, spin the outer black ring counter clockwise to start the water flow, then pull the outer ring out away from the tub to increase the drain to full flow.
I understand that a screw driver is often needed to pull the outer ring out to achieve full flow. Therefore, I suggest another method. Take a garden hose and place it in front of the jet while the spa jets are on. This will force water flow thru the hose and prime the hose. Once you see water running from the other end of the hose, drop the hose in front of the spa jet into the footwell and as long as the loose end is lower than the end in the footwell, a siphon will drain the spa as fast as the spa drain will. Remember to turn off electric to the spa once you have established a siphon. You may have to bucket the last bit of water in the footwell. Goodluck.
Oct 31, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Where is the drain on the Aruba Majestic Hot tub? I have never drained the tub and would like to keep it empty for a few months before refilling
the drain is located on the very lower left corner of the tub. (lower left is decribed as where the control panel is at the top, look at the bottom to find the plug and insert a hose to keep the water flowing away from the tub.
Oct 10, 2009 | Qca Spas Majestic Series Aruba Xl Hot Tub
Hot tub mtor is jets....
you may have burnt the pumps up,pumps like that are water cooled they may have over heated ,you may need to replace the pump.
Jun 29, 2009 | Maax Calla 6042 Bathtub - 101058-000
Fisher Paykel Wash Machine GWL11US
hot drain pump? suggests that the pump is not being lubricated properly...
May 27, 2008 | Washing Machines
Pool & Spa Logo
96 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
