Question about Tablets & eReaders
Visual land tablet will not charge and the keyboard in the case will not work
Just got it yesterday was able to set it up but today it came on and went right off so pluged it in and battery showed checked it once still showed charging a hour later nothing and will not turn on
KingDWS
  • 1606 Answers
SOURCE: My galaxy tablet was fine
You can damage the battery but it is very rare to actually do that. What you need to do is plug it in to the wall charger and leave it alone over night. At that point it should be just fine. it will actually start to show some signs of life after a few hours but don't be tempted to do anything wih it. it will first show a charge light or something after maybe 40 minutes if it is a faster charger.
If it shows no life the next day then you can try charging again but at this point you may hae a problem that requires either a battery replacement or warrenty. The battery has a microcontroller on it and when the battey gets real low they do not behave that well and typically you get the stone dead brick behaviour. And most people do not let it charge long enough to get it working. It is possible that there are other problems but those are usually moore serious and require replacement of the unit. The battery can be replaced but requires the etire case to be disassembled.
So charge it then check your warrenty and it may need serious repairs or to be replaced. If it is out of warrenty then you need to be careful on the cost verses replaceemn
Posted on Mar 23, 2012
  • 37925 Answers
SOURCE: battery went flat now it not charging
The battery may have to be replaced.
Posted on Mar 30, 2014
  • 127 Answers
SOURCE: my visual land tablet is very slow to get charged what can I do
Replace The Whole Thing!
Posted on Jan 14, 2015
  • 17 Answers
SOURCE: Visual land tablet wont turn on, had it on charge, what else can I try?
Try removing the battery and replace it then restart it.
Posted on Feb 03, 2015
Terry Corrow
  • 10875 Answers
SOURCE: I have a visual-land 9 inch tablet. Can I charge it with a cell phone charger ?
probably not,only use the charger that goes to it,if the cell charger only charges three volts and tablet is 5 voltsyou will ruin the tablet
Posted on May 04, 2015
How do I connect irulu usb keyboard to my Visual Land Prestige Elite 7q tablet?
Make sure the tablet and keyboard are charged.
On the tablet, go to setting - it looks like a gear icon. Open settings and about the 3rd item down from the top of the drop down menu, you will see "Bluetooth." Make sure it is set to "ON"
Then go to the keyboard. It also has an "ON" button and press the botton. A tiny red light will blink slowly close to the button. There is a second "Connect" that must also be pushed - it is the "Connect" button and it will search for the Bluetooth signal from the tablet.
When it finds te tablet signal, you will see a message on the tablet screen [it must e turned on} instructing you to enter a 5 or 6 digit code on the keyboard. When you enter the code, a "Connected" signal will show on the screen.
Open a document and start typing!
I'm pretty sure this pertains to all tablets and keyboards.
Feb 12, 2016 | Tablets & eReaders
My Visual Land Prestige Pro Android tablet will not charge
Visual Land Prestige Pro 7D Repair - iFixit
https://www.ifixit.com/Device/Visual_Land_Prestige_Pro_7D
iFixitVisual Land Prestige Pro 7D troubleshooting, repair, and service manuals. ... Tablet is fully charged but it won't stay on ... Why won't my device charge? ... The 7D runs on a newer Android 4.1 Jelly Bean, and has 1GB of RAM, compared to the ...
prestige 7 wont power on - Tabletroms.com
www.tabletroms.com > ... > Visual Land Tablets > Prestige 7
Sep 7, 2012 - 9 posts - ‎2 authors
I found this forum from searching about the prestige 7 and watching the videos ... It showed the charging animation for a few mins and then went off. ... I'd like to figure out what the problem is as I quite like the tablet and it was half .... prestige pro 7d won'tturn on. ,. visual land 8q has power but will not turn on. prestige 10D wont turn on after charging help!
Mar 23, 2014
Visual Land Prestige 10 charging issue
Jan 2, 2014
Ack... Help... Major Battery Issue!!!
Jan 24, 2013
Power Port Charging Issue
Jun 12, 2012
More results from www.tabletroms.com
Jan 07, 2016 | Visual Land Prestige Pro 10D 16 GB Wi-Fi...
My tablet was purchased in March of 2015. It will not hold a charge and now will not charge at all
You will need to get back on with Visual Land. all I can offer you is that batteries do go bad, and sometimes need to be replaced. We cannot force Visual Land to replace your tablet.
Oct 15, 2015 | Tablets & eReaders
My visual land android tablet wont charge it started to charge then jst stopped
If it just stopped charging and you have tried other chrgers, then the probable cause would be the battery for the tablet has failed. This is fairly common and would require disassembly of the tablet and replacement of the battery to fix.
Feb 15, 2015 | Visual Land Prestige 7L Android 4.1 Jelly...
Cannot get my visual land tablet to unlock screen
Is your battery fully charged? The software isn't designed to shut down that quickly, so you must need to charge the battery, then try to unlock it.
Mar 29, 2014 | Visual Land PRESTIGE 7 - tablet - Android...
Visual Land Prestige won't charge
take the tablet to a store that sells charger , ask if you can test it before you buy it
Nov 22, 2013 | Visual Land Connect 7" Tablet
My son uninstalled the keyboard
I would contact their support on the link below, describing your problem.
http://www.visual-land.com/support_form.html
If this has helped please give me a thumbs up, thanks, Nik.
Nov 13, 2013 | Visual Land Connect 7" Tablet
Purchased a new tablet and after charging the unit overnight I turned it on and all I get is a blank screen. Its a pretige10 visual land tablet
Can 't go to settings I don't have a screen on. And I won,t, it won't even right up. I can,t even tell if the battery is charged. Its just dead in the water as they say. Anyt thoughts or. Am I going to have to send it back for repair?????
Nov 04, 2012 | Visual Land ME-110-16GB-RED - Prestige 10...
Tablets & eReaders Logo
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
