Question about The Office Equipment & Supplies
I cannot get the alarm light to shut off on my new printer thereby not able to turn wifi button on have tried all the troubleshooting tips?
4 Suggested Answers
SOURCE: Alarm light Microline 320 Turbo 9 pin printer - won't print
We swapped out the printer for another one we had in the office that was working. The new printer also got the alarm light. From that we concluded that it was a bad serial card. We swapped the serial card from another printer, and the original printer started working perfectly. Now we just need to find out where we can purchase another serial card, as we have no more 'spares' around here.
Posted on May 23, 2008
rouseinator2
  • 24 Answers
SOURCE: On light flashing and stop light flahing
You might want to try a chip resetter as these carts are a smart chip design. Heres the link for one:
http://cgi.ebay.com/CHIP-RESETTER-For-Reset-EPSON-7-PIN-9-PIN-ink-Cartridge_W0QQitemZ290285956034QQcmdZViewItemQQptZPrinter_Accessories?hash=item290285956034&_trksid=p3286.c0.m14&_trkparms=72%3A1234|66%3A2|65%3A12|39%3A1|240%3A1318|301%3A0|293%3A1|294%3A50
Posted on Mar 03, 2009
pineworks
  • 4041 Answers
SOURCE: ALARM BUTTON
Hello there please try see if it work
To reset waste tank full error in MP730.
1. Hit the "menu": Key
2. Hit "Copy" Key
3. Hit "#" Key
4. Scroll thru the menu headings until you come to "Test Mode" - 12th heading
5. Hit the "3" button- this will bring up Eprom Clear
6. Hit "0" button
7. Hit the "Stop" button
Can only try then your printer go on longer but some time the other you need to clean out the waste ink it inside the printer go to open up all.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 11, 2010
5 yellow blinks and nobody else ,
Issue: Alarm / Power light flashes orange 5 times consecutively (Print Head / Cartridge Error)
Solution: Reseat the print head iP3000
  1. Confirm that the printer is powered on.
  2. Open the paper output tray and top cover.
    Note: Gently open the paper output tray while holding it.
  3. After confirming that the print head holder has moved to the center, open the inner cover.
  4. Remove all ink tanks
  5. .Raise the print head lock lever and remove the print head.Re-seat the print head into the print head holder and lower the print head lock lever until a click is heard.Insert the appropriate ink tank into the slot at the right end and push down on the PUSH mark on top of the ink tank until a click is heard. Install the other ink tanks in the same manner.Close the inner cover and top cover.Properly installed: Note: Check that each ink tank is installed in the correct position
Solution: 2 Reset the printer
Resetting the Printer By resetting the printer's power, the print buffer is cleared and certain sensors are reset. If there is invalid data in the buffer, or sensors are stuck in a particular mode; errors may occur. Follow these steps to reset the printer:
  1. Turn the printer off with the Power button (if available).
  2. Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
  3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. If troubleshooting a communication issue, reconnect the data cable (not applicable to WiFi, Bluetooth or Infrared).
  4. Turn the printer back on.
Aug 30, 2011 | Canon PIXMA iP3000 InkJet Photo Printer
I have a Canon Pixma MP250 this is the third one I have owned. Every time I get the same error. It says a paper is jammed when there is no paper in it. I really like this printer when it works. The last...
They are great printers once you learn this reset technique.
Try this first. By resetting the EEPROM, you may be able to clear the alarm and resume printing. Turn off printer. Hold down Stop/Reset button with one hand and turn printer on with other hand. After green light comes on for the ON button, press the Stop/Reset button two times and you should see the green light blink off and the orange alarm light blink "on" with the first press and then the green light comes back on for the power button and the orange light goes off with the second press (if you did it correctly). Now, you need to hold down the ON button about five seconds, then let go to shut OFF the printer. When you turn it back on, the printer should be back to the factory original condition. Make sure you set all your printer properties the way you want them again from your printer properties dialog boxes because some of the settings may have been stored in the printer's EEPROM, which you just reset to get rid of the offending alarm code. This is a cheap printer and it is EASILY FOOLED by it's own internal software. I had to send a brand new one right back to the manufacturer because it was already throwing a fake code when it was first unwrapped.
Jan 24, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Canon mp250, not printing. Print screen says "creating print data" and freezes there.
This sounds like an internal memory problem and I don't have a workaround. Before you give up, try this technique to reset the printer to factory. They are great printers once you learn this reset technique. Turn off printer. Hold down Stop/Reset button with one hand and turn printer on with other hand. After green light comes on for the ON button, press the Stop/Reset button two times and you should see the green light blink off and the orange alarm light blink "on" with the first press and then the green light comes back on for the power button and the orange light goes off with the second press (if you did it correctly). Now, you need to hold down the ON button about five seconds, then let go to shut OFF the printer. When you turn it back on, the printer should be back to the factory original condition. Make sure you set all your printer properties the way you want them again from your printer properties dialog boxes because some of the settings may have been stored in the printer's EEPROM, which you just reset to get rid of the offending alarm code.
Jan 20, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Yellow light flashing saying replace cartridge that is flashing when I replace it the yellow light is still flashing
Solution: Install the print head and ink tanks correctly iP4500
Reseat the Print Head and ink tanks iP4500
Jan 17, 2011 | Canon Pixma iP4500 InkJet Printer
How do i clear an error 5100 from my canon pixma mp250?
Try this technique. Turn off printer. Hold down Stop/Reset button with one hand and turn printer on with other hand. After green light comes on for the ON button, press the Stop/Reset button two times and you should see the green light blink off and the orange alarm light blink "on" with the first press and then the green light comes back on for the power button and the orange light goes off with the second press (if you did it correctly). Now, you need to hold down the ON button about five seconds, then let go to shut OFF the printer. When you turn it back on, the printer should be back to the factory original condition. Make sure you set all your printer properties the way you want them again from your printer properties dialog boxes because some of the settings may have been stored in the printer's EEPROM, which you just reset to get rid of the offending alarm code.
Jan 14, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Alarm red light stays on after you shut the car off 1998chrysler
I would turn the key on without starting the car then press and hold the black button till the alarm light flashes.Then turn key off take out of car and try the fob again.
Mar 29, 2009 | 1998 Chrysler Cirrus
Why isn't my pixma mp145 printer not working?
you have to make sure the correct driver to be installed on the correct OS.. Not sure what OS you are using but below link might be able to help you to get the correct driver.
http://etech.maiila.com/canon-pixma-mp140-driver-manual-software-download-and-troubleshooting-tips
hope this helps
Nov 11, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon BubbleJet i320 Printer Problem
The Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
What you can do is:
· Resetting the Printer By resetting the printer's power, the print buffer is cleared and certain sensors are reset. If there is invalid data in the buffer, or sensors are stuck in a particular mode; errors may occur. Follow these steps to reset the printer:
· Ink Absorber Replacement Options
This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible by pressing the <Resume> button on the printer. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Jul 11, 2008 | Canon BubbleJet i320 Printer
May 22, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Printer alarm Brother 1440
Use the following steps to perform a Factory Reset:
  1. Turn the printer off.
  2. Hold in the circular button on the front panel of the printer.
  3. Turn the printer back on.
  4. When the DRUM light is lit by itself let go of the button.
  5. Hold in the circular button on the front panel again.
  6. Once the Alarm light comes on, let go of the button.
let us know if this works.
Oct 29, 2007 | Brother HL 1440 Laser Printer
29 people viewed this question
Top The Office Equipment & Supplies Experts
Gareth Cockram
Gareth Cockram
Tygh Duval
Tygh Duval
Jerry Greenberg
Jerry Greenberg
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
