Question about Home
The cassette toilet in caravan is smelly does this mean the lip seal needs replacing
2 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: Toilet - replacing a wax seal
No when you put the toilet on a new wax ring you need to push the toilet down to the floor to make a good seal. You will be fine just put some waight on top of toilet to push down wax.
good Luck
Posted on Oct 18, 2009
Jayco manuals
see this link for toilet pumps
cassette toilet pump Google Search
and this for Jayco
Owner Manuals
Dec 18, 2017 | Computers & Internet
Campa potti XG -when you carry the bottom to empty it-it leaks at the point of where the flush handle seal is-is there a solution to this??
Yes I think the problem is that you need a new lip seal'I believe the part number that you need is 07101.You can find the location and e-mail and phone number of a dealer near you by going to home>parts>portable">www.thetford.com>home>parts>portable toilets.Hope this helps you and have a good day. Thank you.
May 02, 2011 | Home
1997 Caravan SE 3.3l auto trans. How to remove the transaxle output shaft seal. I have both axles removed, but can't see a way to pull the seal out. Do i need a special tool?
They make a tool to pull it out but not necessary. If the seal has an outer lip, simply get a sharp flat punch and hammer inward until the seal gets loose.If no lip then get a screw #8 or #6 approximate size. Carefully drill a hole in the metal part of the seal just smaller the the center shaft of the screw, until just thru the metal. Insert the screw so it bits a couple of threads no more. Get a hold using vise grips or pliers. Pull and bend inward at the same time it will come out.
Jan 29, 2011 | 1997 Dodge Caravan
Glacier bay gal toilet.
Does the tank lid have a seal on it to keep water from coming out?
May 30, 2010 | Home
Leaking crankshaft seal
The manual on the 750 says put new seals on the crank as you install it, and I believe they have a locating lip on the seal that fits in a groove in the cases. which means a split.
I have trimmed the lip off the seal, and installed them with loctite master gasket, the old seal is hard to remove due to the lip
Mar 21, 2010 | 1977 kawasaki Z 650
I have the bellevue model and it keeps running even when the toilet has been flushed. It continuely seems to need more water and leaks a bit of water all of the time. It is a new toilet!
Your flapper is not sealing at the bottom of the tank. You can either return the toilet, replace the flapper, or try smearing a little vaseline on the underside of the flapper lip where it contacts the tank bottom. The latter may be all it needs to seal a tiny leak.
Dec 03, 2009 | Villeroy & Boch 98M2 S1 01 Bellevue Toilet...
Need take out thetford toilet of ace award
can anyone tell me where is the fuse fits under a thet ford cassette toilet model ppc2r and wot size
Apr 27, 2009 | Maximum Thetford Porta Potti 365 Portable...
Home Logo
27 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
