Question about The Computers & Internet
Mine tgm inverter airco gives e 1.I do the steps but it is the same.Please advise
3 Suggested Answers
SOURCE: Tgm Inverter air conditioner
Assuming it is brand new, are you certain that the compressor does not run at all or is it simply not pumping? Even being new, it is possible that the main compressor capacitor is faulty, this is on the top of the outdoor unit, replace and check.
Posted on May 07, 2013
pjhislay1
  • 810 Answers
SOURCE: How or where do I unplug my TGM inverter
at the plug seems to be a good place to start
cheers
Posted on Nov 03, 2016
cheers
Nov 03, 2016 | Televison & Video
Teco inverter airco LT404y will not go to heat cycle anymore why not must be a valve
The thermostat may be bad or the change over valve in the outside unit has stopped working.
Oct 15, 2014 | Heating & Cooling
Backlight Inverter Repalced still not working
dim the lights in the room, turn on the set, and shine a bright flash light on the screen. Do you see a faint picture? Also be advised that there are a lot of bad parts floating around on EBay. No backlight condition could be cause by a bad main board, power supply, inverter board, high voltage short on the inverter output, or a bad backlight bulb.
Nov 07, 2013 | Toshiba Regza 42RV535U 42 in. LCD HDTV
Tgm Inverter air conditioner E5 problem don't know what that means and it doesn't do anything. Please help!
May 07, 2013 | Heating & Cooling
Dear sir i have an A12AW1 art cool when i use the airco in the winter outsite temp -10 °C the airco somethime stops althow the roomtemperature is not reached. The airco is also outside...
Not sure the specs of 134. But, at 20 to 30 degrees Fahrenheit your heat pump is not going to be working very efficiently. Now, the ice on the coil is another story. Possibly your defrost is not working BUT, you don't have backup heat anyways. Yes, you should have a low pressure error code, I don't think it's a refrigerant issue.
May 26, 2017 | LG Heating & Cooling
How to inverta matrix woth Casio 9750G?
Only square matrices that have a non-zero determinant are invertible.
Create a square matrix
Enter the coefficients, pressing the EXE key after each entry.
Press [2nd][QUIT] to go back to main calculator screen (RUN).
Press [OPTN]. You get the following screen. Enter a left parenthesis then press the F2 key to a access the matrix functions.
Press the F1 key in screen above: The Mat identifier appears on screen.
Press [ALPHA] A to insert A after Mat.
Close the parenthesis.
Press [SHIFT][X^-1] sequence. This is what you see on screen.
You can also use the universal power key [^] with -1 as exponent.
When you use the [X^-1] key to invert the two enclosing parentheses are not necessary.
For additional information on other matrix operations, see an earlier post of mine. Here is the link to it.
Jun 25, 2010 | Casio FX-9750GPlus Calculator
Start light is flashing, full of water at the bottom
I just went through this with my Kenmore dishwasher, if you look in your manual (mine says: The dishwasher has malfunctioned. Call for service to check heater circuit:, DON'T call for service, I made that mistake and would up being asked to give my credit card # for $200., then a service tech would come to my home, did all that, HE NEVER SHOWED UP, but reported in that he attempted and no one was home, "garbage", so I got my answer right here on this site.
1. Open door
2. Press Normal Wash
3. Press Hi-Temp
4. repeat steps 2 and 3 a multiple of times until all lights come on.
Close door.
This fixed mine.
The advise I was given was to reset the default by performing the steps listed above.
Sep 25, 2009 | Whirlpool Dishwashers
I have a Heart Interface Freedom 20 Inverter/Battery Charger installed on a powerboat. The fan (cooling fan?) is making noise - it seems to be rubbling inside the unit. Is there a way to repair? Replace...
The fan can be replaced. It is very similar to some of the PC cooling fans. I've got the same problem (again) and will be replacing it soon. I will give you the fan specs once I remove my fan ( I think it is 4" 120VAC - will let you know when I repair mine).
Jun 14, 2009 | Xantrex Technology Heart Freedom 20 12...
Replacing Inverter Board
I did some poking around and only found a few places that sold inverter boards for this monitor. Ebay has one that sells for about $80: http://cgi.ebay.com/Backlight-Inverter-for-Gateway-FPD1930-LCD-Monitor_W0QQitemZ160070918225QQcategoryZ174QQrdZ1QQssPageNameZWINQ3aPOST0Q3aRECOQ3aBINQQcmdZViewItem I wasn't able to find any specific instructions posted, however, taking a typical LCD panel apart and replacing the board shouldn't be too difficult. The only hard part is not getting shocked, which is why this is not a job for the typical user. Anyway to disassemble the typical LCD you remove the pedestal from the back of the LCD then remove the screws around the back of the LCD, remove the back and look for the inverter board. Typically it is covered with a metal shield; again the hard part is knowing how to correctly handle the parts. Considering you can buy a new 17" LCD for $120 to $150 (and has a 1 year warranty) you might want to consider investing in a new monitor instead. If you have any other questions let us know, otherwise please don?t forget to rate this posting.
Feb 03, 2007 | Gateway FPD1760 17" LCD Monitor
Computers & Internet Logo
27 people viewed this question
Top The Computers & Internet Experts
tim brauer
tim brauer
Dilum Senarath
Dilum Senarath
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
