Multi-color vertical lines across the tv screen.
    Top Expert:
  • Televison & ... Master
  • 75,571 Answers
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Posted on Apr 15, 2017
I have an LG 2009 60ps60 plasma TV with multi color vertical lines on the left side of screen. Is there a board I can change to correct this problem??
1. Identify the TCON board.
2. Reset the Left side ribbon cables on the T-CON board
3. Replace CON board if you find a spare
Apr 13, 2016 | LG Televison & Video
How to fix Multi color Vertical Lines on a Vizio E470i-AO TV
Does the menu function display the same lines? What kind of cables are using ? (HDMI, Component vid, S-video, co-ax)
Were you as tenacious checking all cables/connections as you were the electronics? Lets rule out this all too often over-looked possibility.
Do you still get the lines with nothing connected to the TV? (no source connected)
Feb 28, 2016 | Vizio E-Series E470I-A0 47" LED TV...
Why are there vertical colored lines all over screen?
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/...lcd-flat-panel.../1127410-thin-vertical-lines-cover...
Mar 7, 2009 - 30 posts - ‎25 authors
I have read there could be ribbon cable connection issues so I plan to .... I have a VizioVW22LHD TV,I hooked it up using a HDMI cable to my Toshiba satellite laptop. ... If you have thin multi-colored vertical lines on your tv panel, that do ... my TV on the thin vertical lines come all over the screen and the TV ... my VIZIO E470i-A0 LED has vertical colored lines on ...
Nov 18, 2013
Vizio SV370XVT lines throughout entire display. Not ...
Aug 3, 2012
Thin vertical line on LCD tv
Dec 29, 2007
More results from www.avsforum.com
Vizio P50HDTV Display Problems - Colored Vertical Lines .
Dec 30, 2015 | Vizio Televison & Video
I have multi colored vertical lines across the entire screen. The menu screen is perfectly legible when selected on the remote and will go on and off like it is suppose to.
If this tv vertical colors lines problems happen by itself,tv problems not causes by u or an object by hitting forces to the tv LCD screen panel itself.The tv board that call the T-CON board it is dead,this board sit in the bottom in the middle of the LCD screen panel.Must be replaced the T-CON board to solve tv vertical colored vertical lines.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish T-CON board for the replacement.If causing by u or an object by hitting forces it to the LCD screen panel itself.The tv not worth a whole tv anymore,because by replacing the tv LCD screen panel will cost the same as a new tv.
Jul 28, 2011 | JVC LT37XM48 LCD TV
Vertical color lines
I had the same thing happen to me this morning. I turned on the TV and it had colored vertical lines through the whole screen. I called Sony and they had me unplug the TV for about 15 minutes. This solved the problem. They said the boards just needed to be reset. It fixed the problem and I am happy with my Sony once again.
May 22, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Vertical lines on screen
this is the convergence gone bad. that is what was blowing the fuse. this is the board on the far left. there are two stk`s on this board. stk392-110.
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 05, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
