SOURCE: spider gears fell on rear differential 95 ford explorer
It's not easy to put them back, but if you get the side gears in position with the axles bumped out as far as you can, the smaller spider gears can be "walked" into place. Try having your buddy rotate one of the wheels slowly until each one fits in. It's tricky but you'll get it.
SOURCE: Ford 8N has a broken tooth/teeth on ring gear. How
Hi..my name is Keith..and i restore 9N's,2N's and 8N's....and to replace the ring gear..you split it there at the back of the engine..and its kind of a big job..so i would check the starter 1st..to make sure its not a starter problem..i hope this helps..if not please write back..i love tractor problems
SOURCE: In 3rd gear the front wheels shake on 8N ford Tractor
The quick easy answer is put your feet on the steering shafts just ahead of your feet when sitting on the tractor when driving at speeds causing the shimmy.This is what most people do.
The longer answer is a new or rebuilt steering box or possibly adjustment.
Some (most) boxes have play that cannot be adjusted tight even with a rebuild.
SOURCE: my 1949 8N Ford tractor, the starter just spins
My thought is you need a new "bendix" for lack of a better word. The device I speak of spins out and connects with the flywheel. There is the possibility you have electric problems but based on what you say, I think it is mechanical.
Thanks for posting your question at FixYa.com
Pleae vote
thank you
a
