Question about Electric Health & Beauty
Hi, I have a 3 wheel Davinci Electric Scooter. Where to get the manual for it. It stopped on me and will not charge for me for some reason. Thank-you
jmgldsmth
  • 2005 Answers
SOURCE: electric scooter won't start
you must completely discharge your battery and recharge it three times (you see your battery has a "memory" and, charges half way less each time you charge it) so doing this will "reset" it unless you "burned it out"
Posted on May 05, 2009
my-mobility
  • 9 Answers
SOURCE: Problems with Pride Celebrity X 4-Wheel Electric
It is often a damaged accelerator (Potentiometer). Sometimes the shaft on the wigwag breaks the contacts in the accelerator from being moved too vigorously when going over a bump too fast. A technician would need to repair this for you. Happy scooting. Regards Chris… info@mymobility.co.nz
Posted on Jun 22, 2009
  • 175 Answers
SOURCE: The battery takes a charge, but will not power scooter
This scooter require two batteries, not one. It is usually a good idea to replace both batteries at the same time, even though one is obviously bad, and the other "seems" okay. These 12 volt DC batteries (VDC) work in tandem to produce the 24 volts that the scooter operates on. In a perfect world, they would both live a long and happy life, but reality is that some die young, others old. Since they are joined together, the one that's going out saps the life out of the other one, so take a bullet and replace both batteries. Make sure you completely charge the scooter when you get the new ones in. Verify that your charger is working properly. To properly charge the 24 VDC system, the chargers have to have an output of about 26-28VDC. The output must be higher than the rated voltage of the two batteries put together to charge. While you have the shell off the scooter, you can see if the charger is working by measuring across the terminal on each battery with the charger off. Note the meter reading. It should be 12-13 VDC. Put it on the charger and retake the reading, and each battery should show an increase in the voltage due to the boost from the charger. After three hours, each battery should show about a 13.5 VDC reading which should hold above 12 for a good 8-10 miles. Always charge your batteries overnight, and if not in use, disconnect them completely with a full charge on the batteries.
Posted on Jul 12, 2009
gewiz
  • 1271 Answers
SOURCE: Pride Legend scooter won't hold charge
check the wiring from the batteries as a wire could have come loose.
Regards
GeWiz
Posted on Oct 01, 2009
FixinFax
  • 3085 Answers
SOURCE: Electric 3 wheeled mobility scooter wont move
Look at the rear of the scooter, make sure the Free Wheel lever is engaged
Posted on Jun 27, 2010
Scooter stopped while going up an incline. just slowed down and stopped. now when activated it just make a ratcheting sound. same after charging overnight
hi, now that could be a seized brake,,,, a faulty break so remove it but keep it connected... and test.
Regards
Rob
www.gewizrepairs.co.uk
Apr 29, 2014 | Pride Sundancer 3 Wheel Electric Scooter
Wont charge the batterys
hi, is this a built in charger ?
where you insert a mains plug ?
Regards
Jan 10, 2013 | Pride Celebrity X 3-Wheel Electric Scooter...
What does it mean when the green light which comes on with the ignition flashes please? I have a Mayfair economy scooter but it is second hand and I have no user manual with it. The battery shows 3/4...
I AM A TECH FOR ELECTRIC MOBILITY # 1-800-MOBILITY
THE FLASHING LIGHT USUALLY MEANS LOW VOLTAGE AND THE BATTERIES ARE TOO LOW TO RUN THE SCOOTER. REPLACE THEM.
GOOD LUCK
TIM
Apr 29, 2011 | Electric Mobility 4 Wheel Power Electric...
Hi do you need to turn on key to charge up battery on a wheeltech mobility scooter i just purchased with no manual thanks
No, you don't need to turn on the key to charge. Just plug in the charger and turn on the charger if there is an on/off switch on it. The charger indicator and the scooter meter will read full when the scooter is fully charged. Hope this helps.
Mar 02, 2011 | Electric Mobility 4 Wheel Power Electric...
Jun 27, 2010 | Electric Mobility 3 Wheel Motorized...
Pride Celibrity 3 wheel electric scooter. The motor isn't working
the click is the electric brakes releasing , most likly the problem you are having is the brushes in the motor may be shot cheap easy fix on each side of the motor there should be what looks like a flat head screw those are the brush covers remove them and check them replace as need , otherwise the motor may be shot
Apr 22, 2010 | Pride Mobility Products Celebrity X - 3...
Regards
GeWiz
Sep 23, 2009 | Pride New Mobility Legend 4 Wheel Scooter
The scooter rar wheels locked up nothing moves
hi, if the freewheel lever is jammed which is located on the drive motor, take the rear cover off and make sure the lever is not bent,
you will see how the freewheel lever is mounted under normally a rubber cover on the side of the electric motor ,
Let me know
May 16, 2009 | Pride Mobility Victory 3 Wheel Electric...
Health & Beauty Logo
47 people viewed this question
Top Electric Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you an Electric Health and Beauty Expert? Answer questions, earn points and help others
