Question about Toro Garden
I recently replaced a traction cable on my Toro model #20041 it's a personal pace mower. I completed the task but now the mower moves in the wrong direction. This mower was produced in 2005.
3 Suggested Answers
  • 67 Answers
SOURCE: How do you replace the belt
this is not easy you have to turn the mower on its side <make sure the carb is down > take off the blade belt guide and look at it the space is really tight and you have to hold the trans with two fingers and then walk the belt on. its hard because the trans is spring loaded to twist backwards to keep the belt tight
Posted on Sep 01, 2009
ftw1952
  • 10319 Answers
SOURCE: I need to replace the
I havent worked on a Toro Personal Pace self propelled mowers in a long time.But unless they have changed a lot the transmission should have a braket on the back of it looking like a hook and a place to clamp the cable housing still.All ya do is hook the cable end to the tranny and under the clamp.Then is run it through a hole in the deck an up the handle and hook it to the braket on the lever that controls the tracton.
Make sure to go back and tighten the clamp.
Hope this helps
Posted on Jun 15, 2011
What is spark plug gap on toro lawnmower model#20332?
Toro has your manuals here depending on year of purchase. If they don't mention the gap, I would use to the contact page to ask.
https://www.toro.com/en/homeowner/walk-behind-mowers/22-personal-pace-20332
22 56 cm Personal Pace 50 State 20332
Apr 14, 2016 | Toro Power Lawn Mower
Toro Personal Pace sounds like it is running at half power
got oil in it, or do you add oil. Left outside alot, fuel line clogged. Is the gas old. Check the blades and the exit portion of the clippings. Does it have a drive train for ease of moving. those can bog down a mower. good luck
Apr 30, 2013 | Toro Lawn Mower. 22 in. Personal Pace with...
Toro 2009 personal pace mower transmission went out
You should post this question in the lawnmower section so the proper expert will see it..
Aug 29, 2012 | Toro Lawn Mower. 22 in. Personal Pace with...
How do you change the transmission in a 20067 toro personal pace lawn mower
I followed this video and it was pretty accurate. http://www.youtube.com/watch?v=eSaNVZaUi-k This is for a newer model mower but most steps are the same.
Jul 07, 2011 | Toro Personal Pace CARB Walk Power Mower
Toro Model 20041 sputters and stalls out; If I cover the primer bulb the engine will rev up and run. Also the mower won't start unless I clean the spark plug. What do I need to do?
Most likely you'll have to remove the bowl nut, under the carb's bowl. You'll most likely find varnish in the jet, or maybe water. These are some typical jets, Tecumseh. Briggs, similar (baymee Lehigh Valley PA, 2009).
Jun 08, 2011 | Toro Personal Pace CARB Walk Power Mower
How do i change the throttle cable on a toro personal pace mower model 20031
Run new cable under right side of mortor put cable through throttle brake bracket hook end into slot. Then run other end to handle and hook in slot.
hope this helps.
Joe
Aug 07, 2010 | Toro Lawn Mower With Toro Power Tools
First start is excellent when cold, will not restart again warm
It sounds as if your engine may be getting too hot. I suggest that you check under the covers and make sure that all the debris is cleaned out. These are air cooled engines and as such need to be kept relatively clear of debris, especially anywhere there are cooling fins.
May 09, 2010 | Toro Lawnmower 20099 Mower Mowers Lawn
Aug 13, 2009 | Toro Garden
Where does cable go at top
It depends on the model, but it hooks up to the handle, on the underside. If it is the personal pace handle (the one where the whole handle moves) It is usually on the lower right corner of the handle. if it does not have personal pace, and just regular self propel, there should be a small hole somewhere on the lower handle. The hole would most likely be on the left side.
Mar 06, 2009 | Garden
Cable traction needs adjusted
To adjust the self propel cable, loosen the cable
clamp, pull the cable downward to remove all the slack
then push the cable jacket up 1/8”
and secure with the cable clamp
good luck
Jan 26, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
32 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
