Multi-color lines across my screen. Can I do something to fix this, does it require a technician, or is it dead.
  • 372 Answers
SOURCE: Color line across the center of a black screen
Hi. this is caused by dry solder joints on the frame o/p IC. Resolder all legs of frame chip. Should sort that out.
Posted on Sep 12, 2007
  • 320 Answers
SOURCE: Multi colored vertical lines
Probably you need an optical block, but it would take a tech looking at it to be sure
Posted on Oct 18, 2008
  • 814 Answers
SOURCE: Insignia 27" lcd tv vertical colored lines across screen.
This television, appears to have had a failure in the mainboard. This is the board that controls the video functions and sound functions. The unit should be taken or sent in to a service center for testing and servicing. The service center will have all the correct service information to determine the problem for you. You can call Insignia customer support at this telephone number 1-877-467-4289. You can also got to the customer support website at Go to the support section and ask them for help on how to get service for your television. I hope this information helps you with your problem.
Posted on May 23, 2009
SOURCE: Phillips 50 inch Plasma
Philips 50 inch plasma tv no video but has sound
Posted on Sep 21, 2009
  • 11361 Answers
SOURCE: Screen has multi color vertical lines, no
Vertical lines from top to bottom is the indication of bad LCD panel. It will get worst.
Posted on Jan 07, 2010
On my HP Pavillion laptop I have a static line and ghost URL across the bottom of my screen
Reinstall browser. Is that only in browser or everywhere ? Consider reinstalling Windows again
Jan 03, 2013 | HP Pavilion dv4-1430us Notebook
I have a multi colored line running across my screen and I can't get my digital antenna channels? Any ideas? Tv is only about a year old and I have unplugged it for an hour to reset it but it didn't w
Hi it sounds like you have multiple problems with your tv. First you said that there were no digital channels. The tv has a bad signal board. The second problem is the colored line running across the screen. That could be two things either the screen itself is bad or your t-con board is bad. The t-con board would be the cheapest of the two to try. You can get parts from
Dec 13, 2011 | Sylvania LC260SS8 26 in. LCD Television
I have multi colored vertical lines across the entire screen. The menu screen is perfectly legible when selected on the remote and will go on and off like it is suppose to.
If this tv vertical colors lines problems happen by itself,tv problems not causes by u or an object by hitting forces to the tv LCD screen panel itself.The tv board that call the T-CON board it is dead,this board sit in the bottom in the middle of the LCD screen panel.Must be replaced the T-CON board to solve tv vertical colored vertical lines.Tries websites like, to buy a whole new refurbish T-CON board for the replacement.If causing by u or an object by hitting forces it to the LCD screen panel itself.The tv not worth a whole tv anymore,because by replacing the tv LCD screen panel will cost the same as a new tv.
Jul 28, 2011 | JVC LT37XM48 LCD TV
If looking directly into screen you see all three lights Red Green Blue next to each other illuminating parts of the screen that color.
U mean on tv screen colors lines R,G,B colors are all mixed up and mis alignments all those R,G,B colors lines on the tv screen?Yes,u have colors shadow picture or 3D picture look alike?Yes,ur tv have a problems known as a convergence problems,it is dead.This tv convergence board it is dead must require replacing 2 STK of convergence ICS and some or all of it resistors too.To fixed the tv convergence board to fixed the tv picture convergence problems.The shop will cost u like $300-350 for parts and labors.
Jun 22, 2011 | Panasonic PT-52DL52 52" Rear Projection...
There a multi colored lines across the entire screen how can i fix this? you can see the TV on.. behind these multi colored lines... very faintly.. please advise how this can be fixed.. chris trizano-...
Hello; Not much info given. Are the lines from top to bottom? , and does EVERY line go fully from top and bottom. If the lines don't go FULLY from top to bottom, you have a cracked LCD panel ( cost more than TV sold for ). If they all go fully from top to bottom, It can still be the LCD panel OR the LCD controller board ( much less expensive ) John
Dec 19, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Nothing but multi colered lines verticly on the screen
Try this:
Turn it off.
Disconnect power cord and any other device attached to it.
Take battery out.
Without anything attached. Hold down the power button for 10-15 seconds.
Connect the power cord only.
Hold down F2 (while it's off)
Turn it on while holding down F2.
Let go of F2 when something comes out of the screen.
If multi colored lines still appears.
You have either defective LCD(screen) or video card.
Jan 30, 2010 | Toshiba Tecra M2 Notebook
Screen had multi-color vertical lines, then went black
the monitor has power board issues it is not your video card. its not dead but it will require some soldering work to repair.
May 22, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
Vertical lines on screen
this is the convergence gone bad. that is what was blowing the fuse. this is the board on the far left. there are two stk`s on this board. stk392-110.
Dec 05, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Sep 06, 2007 | Toshiba 32A60 32" TV
Televison & Video Logo
Top Televison & Video Experts
