Question about HP Office Equipment & Supplies
Hp fake paper jam - HP Office Equipment & Supplies
  • HP Master
  • 20,350 Answers
Usually if it says there is a paper jam, there is. Remove the paper trays, look at the rear, and also open the rear of the machine. If you had a jam and removed the paper, make sure the piece of paper is whole. A mall piece in the sensor will give the error. I had that on a large Dell network printer. Also try removing the power to the machine for 10 seconds.
Posted on Apr 14, 2017
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
How to clear a fake paper jam on an HP 7250 printer
To help you troubleshoot the error 'Paper Jam' issue, please find the link given below and follow the step-by-step instructions mentioned on it:
http://support.hp.com/ca-en/product/HP-Photosmart-C7200-All-in-One-Printer-series/3204782/model/3382182/document/c01079884/
If issue persists, it is recommended to contact HP Support Center for further assistance from the link given below:
http://www8.hp.com/us/en/contact-hp/ww-contact-us.html
GuruAid.com
May 11, 2016 | HP Photosmart C7250 All-In-One Thermal...
Fake paper jam Laser jet M176n
have you unplugged it and turned off the computer and restarted if essentially you have it hooked to it?
Mar 07, 2016 | Laser Office Equipment & Supplies
How to clear a fake paper jam in oki B6250 printer
The usual cause of "fake" paper jams is a prior "real" paper jam. One of two things occurs.
  1. A small bit of paper tears off the jammed stock and hides from view, but keeps the printer jammed. These can be hard to find and remove, depending upon where they are.
  2. In the process of yanking the jammed paper out of the unit, the sensor(s) become damaged or misaligned and give false jam indications. This usually needs repair or replacement.
Jul 30, 2015 | OKI Office Equipment & Supplies
How do i fix a "fake" paper jam in my HP Officejet 6700 Premium
Try using compressed air to blow it out.. or use a compressor that can do 150 psi.. you might have dust in the sensor..
Aug 27, 2014 | Office Equipment & Supplies
Hp 2515 no paper on tray but indicating fake paper jam
May i know the printer model # / name ( full ) to assist you better. ?
Mar 24, 2014 | HP Officejet Pro L7680 All-In-One Printer
Printer says to clear paper jam, can't see paper jam i clear it out.
Here is a post I found how someone else fixed their problem. Good Luck
I was getting the same fake paper jam and improper shutdown error messages on this POS printer. I blew it out with compressed air - but that was no help. To watch what was going on, I stuck a pen top in the open cover switch sensor (see top image at http://windowshopusa.com/hp_8500_POS.html ). It didn't appear that the cog wheel was the problem - it made no clicking noise or anything - the print head just traversed from R to L, then errored.
After I removed the sliding cover on the right, and with the print heads out of the way, I noticed that the chrome hold-down clip (bottom image) was crooked, and this prevented the print heads from traveling all the way to the right, causing the fake paper jam. Straightening the clip fixed the problem. (I didn't have to remove the clip, just pushed it straight - it's not in very tight.)
Nov 14, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Get Paper Jam everytime I print
its general problem with commen soln. just put the all pages properly & neatly in ur printer & turn on ur printer whenever u required & after finishing ur printing process turn off it everytime.Also dont give the fake printing commands it also affect ur printing process.
Dont turn off ur printer while process is running. its main reason of paper jam.
Aug 04, 2009 | HP Officejet Pro L7680 All-In-One Printer
Paper jam
Hello
Please follow all steps here:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00310229&cc=us&lc=en&dlc=en&product=91472
Apr 20, 2009 | HP OfficeJet 7110 All-In-One Thermal...
Fake paper jam
the roler, which picks the paper need to clean, try it
Oct 28, 2008 | Samsung ML 1610 Laser Printer
63 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
