SOURCE: brother printer hl 4050cdn suddenly
First, try to check the release lever for the waste toner box. If this is OK you might be looking up to replacing the waste toner box cause this is the common reason for "Print Unable 2A" error
It is possible also that 2A is a fuser thermistor error usually caused by the fuser not
heating properly and needing to be replaced. If the fuser is heating
properly then the thermistat may be failing and need to be replaced.
I'm afraid a little help from a service technician is all you need, if you don't have experience for this kind of printer problem.
Good Luck!
