Question about Conair Radio Communications
Can't transmit or receive on my Conair expedition 14 channel two way radio Scanning does not even pick up another radio and it shows busy when trying to transmit????
  • 56 Answers
SOURCE: 1000 scanner radio shack
press the manual button a few times, and make sure there are actually some freq. programmed into the unit. if there are freq other than 000.000000 in there, press the s/s (lockout) button and see if this unlocks the frequencies to allow them to be scanned.
Posted on Sep 12, 2007
SOURCE: how to program a uniden bearcat bc 145xl 16 channel scanning radio
I'am having a problem. I do not have codes for a uniden bearcat 145 xl 16 channel, can someone help me please?
Posted on Aug 03, 2008
  • 55 Answers
SOURCE: uh049sx." BUSY" light on all the time. wont recieve
Contact a service center in your own country.
turn the squelch button down.
Posted on Nov 05, 2008
  • 1654 Answers
SOURCE: Motorola Talkabout FV700 not transmitting nor receiving
To troubleshoot: Unlock your keypad lock, then reprogram your radios to the following settings. (Check function after each change)
1) Shut off the Interference Eliminator (set to zero).
2) Turn off the Qt filter.
3) Vox setting to off.
By shutting off all the "bells and whistles" of the radio, you will take it back to being just simply on a frequency. If your radios do not communicate with one another then, or with your friend's radios, you have radio which is failing to operate.
If the radios do work in this simple mode. One by one add the special features back until you discover the culprit.
Posted on Dec 26, 2008
  • 1654 Answers
SOURCE: Motorla Xtn446 - Kenwood Protalk Dosent Transmit
One or both of your radios have PL ( aka private line, tone code, interference eliminators) activated. Here is a link to a link which contains the XTN446 manual(s). Click on the "support" tab to see the list:
First I would try setting the radio's CODE to off (usually zero) and see if that solves the problem. Otherwise, you'll either need to experiment, or find a user guide for the Kenwood. (You could try posting in the Kenwood forum.)
Best regards.
Posted on Jan 16, 2010
Whats the radious on Conair frs 2 way radio
Are you trying to know how far the Radio can let you to communicate?
It depends on mainly two things , type of terrain and weather conditions. the first is the most important and the seecond sums a little. If you are on a hill it is to connect you with your party as far as you can see, but if you are on the middle of a jungle sorrounded by high mountains it isnt goingo to get you more than two(2) miles.
Jul 15, 2014 | Conair Frs 2 Way Radio 14 Channel...
Whats the radious on Conair 2 way radio
Most handheld radios will talk line-of-sight up to two miles. Obstacles will reduce the range. Talking from inside to outside of a building you might expect 1/4 to 1/2 mile.
Best regards.
FRS 2Way Radio 14 Channel Conair Expedition MODEL FRS200SLV MANUAL
Here is some information that might help.
Range can vary due to topographical and atmospheric conditions. Voice transmissions on some channels are not permitted by law.
Use in DUPLEX mode, Repeater stations can re-transmit your signal over a wider area giving you extended range depending on the location, height and availability of the local repeater station.
For information on the locations of repeater sites in your area visit the manufactures website or look-up UHF channels and frequencies for your area.
Note: some channels / Frequency's are to be Avoided.
UHF Repeater operation is used when long distance communication is required, unless specifically needed use of the repeater channels is to be avoided. Some channels and emergency channels, some are calling channels for establishing communication and some are customary road vehicle channels.
You will need to look these channels up for your Area.
Other stuff on this subject on safety and safe operation.
Electromagnetic Interference/Compatibility
Nearly every electronic device is susceptible to electromagnetic interference (EMI). To avoid the possibility of electromagnetic interference and/or compatibility conflicts, turn off your radio in any location where posted notices instruct you to do so such as healthcaer facilities.
Feb 06, 2014 | Radio Communications
Uniden uh65sx radio has constant busy sign on screen
The squelch control is too far open and results in it thinking the channel is busy.
Jun 13, 2013 | Radio Communications
T5100 : One radio receive but not transmit back.
check batteries, maybe they are on the way out. otherwise its in the lever connection. old?
May 07, 2012 | Motorola Talkabout T5100 (14 Channels)...
In order to get the most out of your new radio, read this reference guide completely before attempting to operate the radio.
Turning the Radio On and Adjusting the Volume
1) Press and hold the key to turn the radio ON.
2) To change the volume level press the volume/monitor up or down key to increase or decrease the volume level.
3) Press and hold the key to turn the radio OFF.
Adjusting the Sound (Key Beeps)
Your radio emits a beep each time one of the keys (except for the PTT button and call key) is pressed.
The sound of the Key Beep will increase or decrease depending on the volume level setting.
To turn OFF this beep:
Press and hold the call key while turning ON the radio.
To turn ON this beep:
Turn the radio OFF and ON again.
Choosing a Channel
Your GMR325-2 radio has 22 channels you can use to talk to others. In order to speak to someone,
each of you must be set to the same channel.
To choose a channel:
Press the channel/scan up or down key to increase or decrease the channel number displayed.
Channel Scan Feature
Your GMR325-2 radio has a channel Scan feature that allows you to easily Scan all 22 channels. When an active channel is detected, the unit will pause on that channel until the channel is clear. Then after a 2 second delay, the unit will continue scanning.
Pressing PTT button while the Scan is paused on a channel will allow you to transmit on that channel.
To turn ON channel scanning:
Press and hold either the channel/scan up or down key. The channel number on the display
will rapidly cycle through the channels.
To turn OFF channel scanning:
Press either the channel/scan up or down key.
Talking on Your Radio
To talk to others using the radio:
1) Press and hold the PTT button and speak in a clear, normal voice about 2-3 inches away from the microphone.
While you are transmitting the tx icon is displayed. To avoid cutting off the first part of your transmission, pause slightly after pressing the PTT button before you start talking.
2) When you are finished speaking, release the PTT button.You can now receive incoming calls. While receiving, the rx icon is displayed.
Transmitting a Call Alert Tone
Your GMR325-2 radio is equipped with a call tone that will be transmitted when the call key is pressed.
To transmit the call alert tone, press the call key.
The tone will automatically be transmitted for a fixed length of time.
Auto Squelch Feature
The GMR325-2 is equipped with an automatic squelch system which shuts off weak transmissions
and unwanted noise due to terrain conditions or if you have reached your range limit.
Monitor Mode Feature
Your GMR325-2 radio allows you to listen for weak signals on the current channel at the press of a key.
To turn ON monitor mode:
Press and hold the volume/monitor up or down key. The rx icon will blink.
To turn OFF monitor mode:
Press the volume/monitor up or down key. The rx icon will stop blinking.
Automatic Power Save Feature
Your GMR325-2 has a unique circuit designed to dramatically extend the life of the batteries. If there is neither transmission nor an incoming call within 2 seconds, your radio switches to the Power Save mode. The radio is still able to receive transmissions in this mode.
Press and hold the call key until the "L" appears. After 1 second, the LCD will return to the channel display.
To exit Keylock on mode, press and hold call again.
Note: While in keylock on mode, it will still receive transmissions.
Roger Beep is a BEEP that is sent to notify the end of transmission.
Roger Beep can be heard through the speaker when Key Beep is on.
Roger Beep is transmitted even if key beep is turned off. However Roger Beep will not be heard from the speaker.
To turn OFF Roger Beep: Press and hold the channel/scan up Key while turning on the radio.
Jun 21, 2011 | Motorola Walkie Talkies 2-Way Radio
Motorola T5420 Transmit Problem
Here are some troubleshooting thoughts:
1. Is your battery indicator showing at least 2-3 bars? (Battery Note: Your rechargeable batteries may fail due to setting without use for a long period of time. They need replaced every 12-14 months usually. A good tip is to charge them once a month to keep the chemical in the battery active.)
2. Check to see your Qt noise filter is shut off. Refer to page 22 of the owners manual. It is possible you have some radios set to Y and others to N. To assure good communications you should set all of them to N.
3. With your radios set to interference code zero, place your radios one at a time in scan mode, while you transmit/talk on one individual radio. See if any of the radios receive. Do this with each radio individually to see if you are transmitting at all. NOTE: This test will determine if you have any ability to transmit. If you do not receive any sound on the 3 radios setting in scan mode, the individual radio you are testing will not transmit.
Aug 25, 2008 | Motorola Talkabout T5420 (14 Channels)...
Radio Communications Logo
37 people viewed this question
Top Conair Radio Communications Experts
Mike Charette
Are you a Conair Radio Communication Expert? Answer questions, earn points and help others
