Question about Refrigerators
Have A RS265TDRS/XAA AND THE LIGHTS ON THE FRIDGE SIDE ONLY COME ON ONCE AND THIS IS AFTER I UNPLUG IT THEN PLUG IT BACK IN
mikedurland
  • 481 Answers
SOURCE: Warm Fridge
the defrost timer/ board is getting stuck in defrost and when you unplug it and plug it back in it resets the defrost timer/control board. you may need to replace the defrost timer/control board.
Posted on Jul 10, 2008
SOURCE: Freezer o.k., Fridge barely cooling.
Expose the coil in the freezer and defrost it with a hair dryer.
Posted on Aug 01, 2009
aasc
  • 1606 Answers
SOURCE: fridge cooling freeze up i unplug the unit to
You have 2 heaters , behind the inside freezer panel. Both heaters , come together in a kit . This is usually the problem , with magic chef refrigs . When replaceing , use the complete kit with wiring . You will have to put the heater guards , with clips , on the new heaters .
Posted on Dec 09, 2009
tech master
  • 120 Answers
SOURCE: Lg fridge lrsc 26925tt inop fridge lights-inop
repl the mother board and check for error display to see what cause it to turn off in the first time
Posted on May 30, 2010
  • 250 Answers
SOURCE: I have a samsung RS265TDRS
Make sure that some type of child lock isn't on. The most simple panels will have one or two buttons associated with the lock function, or maybe some small writing that says hold down such and such buttons to operate the child lock function. Check the manual if you're having trouble. If that doesn't solve your problem, you may need to get someone to take a look at the fridge.
Posted on Jan 16, 2011
Freezer door code is reading -25 on a samsung refigrater
Error 25 is fridge defrost fault, could be defrost sensor or defrost heater.
Ian.
Aug 19, 2015 | Samsung Refrigerators
Fridge Temperature on control pannel is blinking
If the fridge is cool, the defrost timer has failed.
If the fridge is warm, the thermostat is usually the culprit.
Jul 25, 2015 | Samsung RS265TDRS Side by Side...
Frozen water line on samsung fridge
I did a GOOGLE search using your reforge model number. I came up with several sites that have all of the info you need. The best was RC Repair parts. Here you will find all of the repair parts you need with pictures of same. Look it over I used this service for my Refrige a few years back and it was GREAT! also did a repair on my washing machine again a big help and all the parts were listed and available.
Jan 21, 2015 | Samsung RS265TDRS Side by Side...
Samsung side by side refrigerator RS265TDRS started making loud propeller like noise on the cooler side half way up. Notice bunch of ice around the lights on the back wall of it. I unplugged the fridge for...
A COUPLE THINGS U SAY FREEZER IS FINE FRIDGE IS NOT? THE FAN NOISE MAY BE DUE TO ICE BUILD UP DUE TO A DEFECTIVE BAD DEFROST TERMINATOR. WHICH EVENTUALLY WILL BUILD ICE UP IN FREEZER AND FRIDGE? HINDER COLD AIR CIRCULATION. ANOTHER THING TO LOOK AT IS UR FREEZER AND FRIDGE THERMISTORS AND UR COLD CONTROL THERMOSTAT. EVEN UR AIR FLOW DAMPER CONTROL VENT AND KNOB SETTINGS? ARE THEY TO FAR OPEN OR CLOSED? ARE U ABLE TO HEAR THE FAN AND COMPRESSOR RUNNING? ANY CLICKING SOUNDS?
Feb 25, 2012 | Samsung RS265TDRS Side by Side...
Fridge lights are buzzing and flickering
You need to replace the electrical control board. It's an easy fix. About $75 for the part. No electrical work necessary. Just unclipping and re-clipping wires into their ports. You do not need a repairman to do this! (I'm a 33 yr. old female, so please forgive my lack of technical terms in the post) I ordered one from AppliancePartsPros.com. It came in two days.
1. Pull out and UNPLUG the fridge.
2. Take out the screws that hold the bottom back panel on
(The electrical contol panel is located inside a white box attached to the lower left corner. )
3. Remove the screws that hold the box in place
5. Remove the bunch of wires out of the clip on the side of the box and pull the box out. Open it by releasing the clips on either side.
6. Disconnect the three sections of wires that plug into the board
7. Remove old board out of the housing
8. Insert new board,
9. Reverse above steps to complete installation.
Note: What triggers the buzzing sound is the door being opened. If you want to stop the sound and prevent the electrical current from going to the fried board until your new one comes, put a piece of tape tightly over the switch that pops out when the door is opened (located inside the unit near the door hinge).
Apr 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE Refridgerator
I suggest that you check your defrost heater in the freezer. If this is the problem, then if you empty out the freezer section you will see a solid sheet of ice on the back panel. If the ice is there, then you may need to replace your defrost heater, we had this same problem just a few days ago. Once the heater was replaced, the fridge started cooling about an hour or so.
Oct 12, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Warm Fridge
Jun 19, 2008 | Frigidaire PLHS237ZD Stainless Steel Side...
How do i defrost a fridge?
To defrost a fridge, you simply move all of the food to somewhere it can stay cold and unplug the fridge. That's it!
The purpose of defrosting a fridge/freezer is to melt the ice that has accumulated around the condenser to restore it to maximum efficiency. Once it has melted (using a hairdryer can speed it up) you can plug it back in and put food back.
Mar 26, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
24 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
