Question about HP Office Equipment & Supplies
Hp 6500 fake paper jam' - HP Office Equipment & Supplies
  • 54 Answers
SOURCE: HP 5610 all-in-one fake "paper jam"
I request you to please perform the below steps to reslove false paper jam..
Step one: Perform a partial reset
  1. Disconnect the power cord from the product.
  2. Press and hold # and 3 while reconnecting the power cord to the product, and then release both buttons.
  3. Try making a color copy by pressing the Start Copy Color button on the product control panel.
    • If the partial reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next step to try a semi-full reset.
Step two: Perform a semi-full reset CAUTION: Performing a semi-full reset deletes any saved phone numbers on the product.
  2. Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons.
    • If the semi-full reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next solution.
Posted on Sep 04, 2009
sgoswami
  • 114 Answers
SOURCE: Paper jam on HP officejet 6500
Try This :
Connect the printer directly to the wall outlet ; not through any Power strip
Then Unplug the Power cable from the back of the printer
Keep on tapping the power cable for next 30 seconds
Plug in back the power cable;
Open the rear access door and you will get to see some rollers
Clean the rollers with a Lint free cloth Moistened with some distilled water
Try to do a copy if still it doesn works
With one hand press and hold down the (#) and the (6) button and with the other hand plug in back the power cable ; it will do a Semifull reset on the printer; This will take some time ; Follow the instruction on the screen;
If still it doesn't work then you need to contact HP ;
The toll free no. for HP would be : 1-800-474-6836
They will replace the printer for you free of cost (No Charge if the printer is in warranty i.e within 1 yr of purchase)
Still you may check the link below for further issues:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01312792&lc=en&dlc=en&cc=us&lang=en&product=3795406
Regards Soumajit
Posted on Sep 21, 2009
nalin_elliot
  • 224 Answers
SOURCE: hP officejet wireless 6500 printer won't print
Yes I will tell you why Kodak photo paper is a little thicker in size and you should not get this same error message if you use hp photo paper or regular photo paper.See of this helps.....
Issue The Out of Paper message appears on the computer and the product stops picking up or feeding paper. Solution Step one: Reset the product
  1. Without turning the product off, remove the power cord from the back of the product.
  2. Wait 30 seconds and then plug the power cord into the back of the product.
  3. If the product is not already on, use the On button to turn it on.
Step two: Check the condition of the paper and reload it
  1. Replace any paper that is ripped, dusty, curled, wrinkled, or bent.
  2. Make sure that all the paper is the same size and type. Because only one type of paper can be used in the product at a time, paper types should never be mixed.
  3. Tap the stack of paper on a flat surface to align the edges.
  4. Make sure that the stack of paper to be loaded in the product contains no fewer than 10 and no more than 25 sheets of paper.
    NOTE: Do not load too much paper in the product.
  5. Insert the stack of paper into the product and gently push the paper guides snugly against the paper. Make sure that the paper is completely inserted into the product and can be picked up by the paper rollers.
  6. Try printing again. If the issue is not resolved, try loading different brands of paper and different types of paper, one type at a time, into the product and then try printing again.If the issue persists, continue with the next step.
Step three: Adjust the paper settings in the print driver The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
  1. Open a document in the program being used to print.
  2. Click File , click Print , and then click Properties . The product Properties dialog box appears.
  3. Click the Paper/Quality tab.
  4. Choose the appropriate paper size from the Size is drop-down menu.
  5. Choose the appropriate paper type from the Type is drop-down menu.
  6. Click OK and then click OK again to print the document..
  7. If the issue is not resolved, continue with the next step.
Step four: Clean the rollers
  1. Turn off the product and unplug the power cord.
  2. Open the access door to gain access to the rollers. Depending on the model, this is usually the rear access door. See the product user guide for information about locating the rollers.
  3. Clean the rubber rollers with a lint-free cloth, lightly moistened with water.
  4. Make sure that any paper rollers that rest on the input tray, which are located behind the back rollers, are cleaned. A clean cotton swab, lightly moistened with water, might be necessary to reach these rollers.
  5. Close the access door and plug in the power cord.
  6. Try printing again. If the issue is not resolved, continue to the next step.
Step five: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product. CauseAny of the following issues can cause the error message to appear:
  • The paper trays are empty or overloaded.
  • The paper is curled.
  • The print side, or shiny side, of the paper is not loaded in the input tray face down.
  • The paper might not be engaged with the feed rollers.
  • The paper-width guide is pressed against the paper stack too tightly.
  • The paper tray is not completely inserted into the product.
  • The paper settings in the print driver do not match the paper loaded in the paper tray.
  • The rubber paper-feed rollers are coated with dust.
Posted on Oct 03, 2009
MUKHTAR
  • 2022 Answers
SOURCE: paper jam on a officejet 6500 wireless
Unplug the power cord and open the cover and remove all the cartridge and try to look I inside around the roller and try to manually roll the roller and if you can see the paper try to pull is slowly.
Have a nice day and do not forget to rate please...!
Posted on Feb 10, 2010
anujbhatt
  • 66 Answers
SOURCE: I am looking for a fix on hp officejet 6500 E709a
To clear jam , you can perform the link below
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01312792&cc=us&lc=en&dlc=en&product=3795314
if still you get the message, remove the cartridges from printer.
clean them with a cotton swab and distilled water and perform the steps below and once it is done, insert the cartridges when asked by the printer.
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold Plus (#) and 6 while plugging in the power cord.
Posted on Jun 22, 2010
Hp fake paper jam
Usually if it says there is a paper jam, there is. Remove the paper trays, look at the rear, and also open the rear of the machine. If you had a jam and removed the paper, make sure the piece of paper is whole. A mall piece in the sensor will give the error. I had that on a large Dell network printer. Also try removing the power to the machine for 10 seconds.
Apr 14, 2017 | HP Office Equipment & Supplies
How to clear a fake paper jam on an HP 7250 printer
To help you troubleshoot the error 'Paper Jam' issue, please find the link given below and follow the step-by-step instructions mentioned on it:
http://support.hp.com/ca-en/product/HP-Photosmart-C7200-All-in-One-Printer-series/3204782/model/3382182/document/c01079884/
If issue persists, it is recommended to contact HP Support Center for further assistance from the link given below:
http://www8.hp.com/us/en/contact-hp/ww-contact-us.html
GuruAid.com
May 11, 2016 | HP Photosmart C7250 All-In-One Thermal...
Hp 2515 no paper on tray but indicating fake paper jam
May i know the printer model # / name ( full ) to assist you better. ?
Mar 24, 2014 | HP Officejet Pro L7680 All-In-One Printer
Paper mismatch officejet 6500 crumples
There could be a foreign object or torn piece of paper that's stuck further inside the printer mechanism path. Try using a flashlight and inspecting any access or clean out hatches. Sometimes something will be caught inside and cause the paper you feed in to crumple and create a jam. I watched a video on youtube giving different ideas on how to fix this problem. Fixing Paper Pick-Up Issues
May 27, 2013 | HP Officejet 6500 Wireless All-in-One...
My HP 6500 Printer jammed and now everything it prints has a line running down the side. Each segment is about 1/2 inch long and runs down the whole page.
This type of line is cause by a scratch or smudge on the toner cartridge's image drum. You will need to replace the toner cartridge.
Nov 01, 2017 | HP Officejet 6500 Wireless All-in-One...
Paper jammed
Lift up the upper section of the printer (just like you were going to replace an ink cartridge) and look for the smallest torn piece of paper hiding in the gears. Then tip up and gently remove the top (black) paper tray assembly and remove any paper in the tray. Grab a flash light and check the "in" feed area.
Put it all back together and hit "start copy". If noting still clears the jam unplug the printer (power cord) from the wall, wait 30 seconds and plug it back in.
Hopefully that clears the paper Jam message.
If not call HP Support Center @ 1-866-408-5408. They're available 24/7.
Jul 25, 2012 | HP Officejet 6500 AllInOne InkJet Printer
HP Officejet 6500 Wireless one day i come home and when i turn on my printer i get a mssg that there is a paper jam so i look and chek that everything is clear so its a flase paper jam then i resart it and...
You may have to get the printhead replaced but first:-
Was the paper jam cleared?[disconnect everything even your PC and re-connect to start afresh]
Clean the printhead by:-
  • Load a plain A4 size paper into paper tray.
  • On the printers control panel,press the setup button.
  • Select tools nad then press OK.
  • Select 'clean printhead and then press OK.
  • After the printhead cleaning,turn the printer off and then on.
Hope this helps.Thanks!
Oct 13, 2011 | HP Officejet 6500 Wireless All-in-One...
The printer is now saying paper jam and there isnt one
Open the back door pf the printer and look for a black plastic lever.That the paper sensor wich may be damaged and it is saying to the printer there is a paper jam.
Nov 01, 2010 | HP Officejet 6500 Wireless All-in-One...
Paper jam on a officejet 6500 wireless
Feb 10, 2010 | HP Officejet 6500 Wireless All-in-One...
22 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
