Question about Samsung SyncMaster 204B (Silver, Black) 20.1 inch LCD Monitor
Samsung monitor picture clicks off after 2-5 seconds...
I have a Samsung flatscreen monitor (not sure of model, I am at work). I have had it only a little over a year. Yesterday a problem began. The monitor power stays on, but after viewing screen 2-5 seconds it clicks and goes black. To get a picture I have to turn it off and on again...to be able to view screen for another 2-5 seconds. Any suggestions on what this might be?
  • cisnerosfami Jul 24, 2009
    Just to clarify, here is what is happening:
    Power stays on to the monitor, never shuts off. If I turn my monitor on, there is a beautiful display...then in just a few seconds you hear a click and my screen goes black. I have to turn off the monitor, turn it back on again and I have a picture once again for a split second and then a little click again and it goes black. Just like it would if I had it set on screensaver mode. Power stays on, but picture goes away...until it is turned off and on again. I have plugged in another monitor and it works fine, so I do know it is the actual monitor having an issue.
  • Buddy Mcsparrin May 11, 2010
    Hello, It sounds like you have a monitor with a common problem. After a few years some LCD monitors
    will blow a power supply. The problem is caused by parts called
    capacitors overheating in the confined space of the monitor. If you are
    good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work
    fine. The capacitors do need to be installed with the correct + and -
    connections, note the stripe on the old one and insert the new one the
    same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution. Buddy Corporate Computer www.ccl-la.com Over 21 years of computer and printer support/repair
  • Samsung Master
  • 1,684 Answers
Yes, It sounds like the backlight inverter circuit is shutting down. No inverter power, no backlight. On some monitors the inverter circuit will shot circuit the power power supply which makes the power light flash on some it just kills the backlight. You can usually check with a flashlight. Hold the flashlight pointed at the screen and see if you can see any of the icons or background picture. If you can then it is the backlight circuit or backlight tubes, usually the circuit.
Buddy
Posted on Jul 24, 2009
    Problem Solver:
  • 13 Answers
Try wait few a hours or days...i have samsung 204b and keeps flashing on or off...just try few hours and days...or if nothing resolved, check the circuit.....or consult the expert...
"hope it helps"
Posted on Jun 17, 2010
Samsung s42ax-yd01 - No picture / Sound OK problem
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
If your TV, flatscreen, or monitor is more than 5 years old it is more like to have suffered a component failure.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
May 22, 2015 | Samsung Televison & Video
The screen on my acer aspire 3100 crack so i bought a vga cable to connect to my flatscreen but the picture switches back to my laptop when its starts up the only way that it works on my flatscreen is when...
Go into your display settings. It should show at least two different monitors. Your laptop monitor and the external one your plugged into. Click on the external one and click on the two check boxes. Click on extend the desktop into this monitor first. Then click on this is my main monitor. Reboot your computer and it should be on your external monitor.
Jun 12, 2013 | Computers & Internet
My insignia flatscreen tv monitor doesn't work. I
Shut off the tv, unplug it, hold the power button on the tv for 90 seconds. Plug it back in. Hit menu? Do you see a menu? (if not, your tv needs serviced)
You might also have a cracked LCD.
Jul 01, 2012 | Televison & Video
How to adjust monitor screen brightness?
hi. turn on the tv and then use the remote. click on the menu and scan thru til you find picture brightness or picture quality. J.
Jul 29, 2010 | Acer X223WB 22" WIDESCREEN LCD Monitor
I have a samsung 920NW Black 19 monitor that will not stay on beyond 2-3 seconds. I've check cables and tried on two different computers with same result. Is the monitor ready to be trashed? I found a...
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault. It can be repaired, all you need to do is just to replace the picture board on the monitor, after replacing the picture board, you will see that the monitor will work fine, just as before.
Take care.
Jul 17, 2010 | Samsung SyncMaster 920NW Monitor
Monitor keeps going of then coming back on in 5
right click on desktop.go to properties.in properties go to the screen saver tab.under the screen saver tab u will see something called power.click on power.change the settings of the monitor there.let me know if it works
Sep 05, 2009 | Computers & Internet
Can't get external monitor to work properly
  1. Right-click on your desktop (anywhere there is not an icon).
  2. Click Properties.
  3. Click the Settings tab.
  4. You should see two monitors with a "1" & a "2."
  5. Right-click on "2" and click enable
  6. Your external monitor should come to life.
  7. You may want to make some adjustments with the resolution, and this option is on the same screen.
Apr 23, 2009 | Computers & Internet
My flatscreen monitor has went a bright green colour, you can still see a picture (part from everything is green) I have tryed puttin another monitor connected 2 the computer and it works fine, so i no its...
you should check your monitor display cable first and second may be back pcb socket and ic is loose so it leave color combination and your screen will be green.you should repaire your monitor very soon otherwise it will be more damage.
Dec 03, 2008 | Computers & Internet
Pl716s2 flatscreen
Hey...
Well, your lucks just run out....you got a busted backlight inverter.
Aug 22, 2008 | Proview PL713S 17" Flat Panel LCD Monitor
Samsung SyncMaster  204B (Silver, Black) 20.1 inch LCD Monitor Logo
2,064 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
