Question about Quasar SP-3235 32" TV
I have a toshiba 27a44 with a horiz linein the top 3 inches of picture. how can i fix this?
  • 120 Answers
There is a bad capacitor on your horizontal section on your main pcb board inside the TV. See technician to fix this problem.
Posted on Jul 24, 2009
Problem with my Toshiba 27A44 television. The picture will be fine for maybe 20-30 minutes at a time, then acts up for perhaps 20-30 minutes, then may go back to working fine for a while (there is no set...
there are bad solder connections on the vertical output ic. if you can solder well, get an iron with a fine tip and look for an ic mounted to a metal heat sink. it will be about an inch or so long with 7-9 pins all in a row,on the under side of the board you can usually see the the rings around the pins if you look close or use a magnifying glass. i have fixed dozens of these using only a hot soldering iron and rosin core solder.
Aug 18, 2011 | Televison & Video
Upper 1/4 of picture is distorted by tightly spaced horizontal lines. What do you think is causing this?
This sounds like a vertical fold over.
This happens when the filter capacitors close to the vertical IC have failed or changed value. The are very inexpensive, and relatively easy to replace.
Remove the back panel. Locate the vertical IC. There will be a number of capacitors around it (3-4). I just replace them all. They cost under $1 each, so no testing, just change them.
Jan 02, 2011 | Toshiba 27A44 27" TV
Does the toshiba 27a44 have closed captioning?
Hello
You have two options with closed caption feature.
Captions of Text
A caption is a printed version of a dialogue narration and/or sound effects of a programme. Text is information not related to the programme that appears on half of the TV screen when available.
To view Caption or Text
[1] Select the desired programme. Closed captioned programme are usually marked in your local TV listing as "CC"
[2] Press CAPTION/TEXT repeatedly to select caption or text mode.
[3] Press 1/2 to select the caption or text channel.
[4] To turn to off the closed caption feature, press CAP/TEXT repeatedly until captions or text no longer display 0n-screen.
Ok.
Nov 15, 2010 | Toshiba 27A44 27" TV
HLN507W Samsung DLp Horiz. lines
it sounds like the dmd board is failiing
Mar 13, 2009 | Samsung DLP HL-P5663W 56" TV
We can't turn off the picture
The electronics that controls the power supply operation are having some failures. It is possible that the control circuits for this are also at fault.
The set will require proper service from an experienced TV tech.
Jerry G.
May 19, 2008 | Toshiba 27A44 27" TV
Toshiba TV - 29 inch model 2990 XEL
If don't appear display menu when you press this , your tac switch don't work ( menu switch).
May 13, 2008 | Toshiba 27A44 27" TV
Ok, let see. When do you press menu button, do you see something or not ? , or only for channel display. I recommneded keep press menu for 10 seconds and release.
Tv problem
Bad capacitor in vertical output IC circuit + check power supply
Last, replace IC.......................T.
Nov 09, 2007 | Philips 27PT6441 27" TV
Horiz. sharp line from 2 inch bottom
If the screen is part of your laptop/notebook/netbook, try to connect an external monitor to the VGA port, to see if the video-card in your computer is generating the "weirdness".
If the screen is an external monitor, try connecting it to a different computer, to see if the "weirdness" follows to the new computer,
implying that the monitor is faulty. Also, connect a diffferent monitor to your computer, to see if the video-card is causing the problem.
Sep 22, 2007 | Computers & Internet
Horizontal lines across the top of the screen
it is a fault in one of the capacitors in the vertical part of the schematics it is 33uf -160 volts capacitor , dry out and need to replace refer to qualified , regards , plz don't forget to rate thx
May 02, 2007 | Toshiba 27A44 27" TV
Quasar SP-3235 32" TV Logo
57 people viewed this question
Top Quasar Televison & Video Experts
 Grubhead
Grubhead
jason
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
