Question about Seagate Free Agent Go Small 12 GB USB External HD ST600121GSA1E1-RK USB 2.0 Hard Drive
Drive is a blinking brick of garbage.
Device worked fine for a little over a year and then it magically decided to stop being recognized by my computer. I left it plugged into the wall, but it shuts off when you disconnect the USB cable. Well, it decided to keep running without being connected to the computer and *Poof* Tried throwing it in the freezer to recover the files, no effect. Going to try throwing it through a Walmart window.
  • Seagate Master
  • 32,281 Answers
Is the hard drive a USB external device?
Does the hard drive spin up at all or does it make clicking sounds?
If the hard drive spins it may not be faulty, it may be a faulty USB hard drive adapter case.
Put the hard drive in another USB hard drive adapter and connect it to a computer, if it still doesn't work then the hard drive has died.
Posted on Jul 25, 2009
My computer wont recognize my external hard drve and the io magic light is blinking
Try connecting the external hard-drive to a different computer. If it still fails, and it is still under warranty, then exercise the warranty to get it replaced.
If the warranty has expired, open the case, and remove the disk-drive, disconnecting it from the USB-to-disk-drive adapter.
Connect the disk-drive as a "slave" disk-drive in some desktop computer, to see if the disk is recognized.
If it is, then the USB-to-disk-drive adapter has failed, and you could go to any computer-store to buy a new external case and adapter, and mount your disk-drive inside the new case, and work with your files.
If the disk-drive is not recognized, check the warranty on the disk-drive itself.
Jun 24, 2010 | IO Magic Corporation GigaBank (I250HD35)...
Computer is not recognizing my external hard drive
If the light won't blink, there could be problem with the power source. Do scanning hardisk for errors manually ( take off the hardisk from the case, assemble it on other PC Desktop)
May 06, 2010 | IO Magic Corporation GigaBank (I250HD35)...
DVD driver stopped working
ype dvdplay in cmd and try playing it
Mar 19, 2009 | Computers & Internet
External Hard Drive not being recognized (A little different)
IOMagic has become notorious for some faulty power supplies in the past. If you've got it on your internal bus now and it's still not working, you're in trouble.
It all depends on the noise it's making. I've got an IOMagic 500G that's ticking away like crazy right now. The platter doesn't spin up though. Put your ear to it when you start your computer to see. If I give mine a quick twist I can get put a little inertia into the platters to help the motor overcome the standing friction and then it works until it powers down and stops spinning.
I've had others fail where the arm, with the read/write head on it, goes out to read the platter and the alignment is off, whether it's by impact or age or whatever, and you hear the arm go out, then there's a tick tick tick and then it parks itself and tries again. This is a really bad sign.
Some people have suggested freezing the drive. The cold changes the alignment for a while and you can maybe get it to read those first few sectors and then it's relatively fine for a while.
Some people have suggested buying an identical drive, exact same serial, to replace the external pcb incase the electronics have fried. This is not so likely but worth a shot, especially if you've got an old drive and a replacement is cheap.
There are a few other things but it gets more severe from here.
Advice: anything above that you do to it will void the waranty and will likely speed up decline of the drive.
If you get it to spin up and read, start imaging the drive to another drive right away and cross your fingers. It may never read again after that. Hope that you get it all before it kicks the bucket.
Make sure you image to another drive that is bigger. I've had an image of a 500G drive take over 3 days to complete only to fail because it didn't have enough room to close the control file. I was short a couple of kb on the destination drive. I was away when the fail happened and the drive powered itself down. I could never get it to read again. I was lucky enough to manually edit the control file and got almost all of my data back.
If your data is irreplaceable, and means the world to you, then your only real option is to take it to a data recovery company. They will remove the platters in a clean room and make an image to work from if they can't get it to work otherwise. This is of course very expensive. No one likes to hear it though. If you start messing with it first you may severely limit their chances for successful recovery.
If you simply can't afford it then try everything you can.
I've had drives not read for months and then I throw them in an enclosure just for kicks and the temp is just right or something, you never know, and they read long enough to get the info off.
Good luck.
"data doesn't exist unless it's in 3 different places", words to compute by.
Sep 22, 2008 | IO Magic Corporation GigaBank (I250HD35)...
Worked fine for a year, now not recognized or functioning
I had the same issue- light was blinking from red to blue, could not get my computers (I have a Mac and a PC) to recognize the drive, sounded like the drive wasn't powering up...
I replaced the Acom drive enclosure with a new one (CP Technologies). I don't know if the drive enclosure or power supply was at fault-- but it wasn't the internal drive. Plugged it in and amazingly all my data was back. For thirty bucks it was far less than sending out the drive to a 'data recovery' expert!
Jun 09, 2008 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
Appears on Device Manager but not on My Computer
you can still use partition table disk doctor to restore your old partitons and the dat a will be seen back automatically like magic..
May 28, 2008 | Western Digital Passport WDXML800UE...
Blinking green light
Same problem. Blinking green light. Device not recognized. Have my whole life on this drive! HELP!
Apr 03, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Drive not being recognized; blue logo blinking
I have an I/O Magic 320GB drive. It's easily taken apart by gently removing the silver-colored aluminum sticky plate (by the power switch, USB, etc). Then you remove the two screws and remove the black plate. After that you can push out the entire drive harness and remove the screws and connectors to take the hard drive out. It's easily swapped for a different HDD, and the drive is easily placed as an IDE internal drive. If you hook it directly to your computer you can run diagnostics on it and perhaps data recovery software like "Recuva". Most external drives are pre-formatted as FAT32, single partitions but can be reformatted to any other format.
Oct 28, 2007 | IO Magic Corporation GigaBank (I250HD35)...
My PC Will Not Recognize My External Hard Drive ...
Not sure if this will help, but was having the same problem. I separated the power cord to the AC adapter brick and reconnected it. My computer immediately recognized it!
Sep 06, 2007 | IO Magic Corporation GigaBank (I250HD35)...
Seagate Free Agent Go Small 12 GB USB External HD ST600121GSA1E1-RK USB 2.0 Hard Drive Logo
185 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
