Question about Hoover Cooktops
Hi my Hoover hob is flashing error 22 can you help me please
Hi weve just moved to new house pre installed Viceroy electric hob when switch on button it gives L code for all 4 rings when i press and hold the on button it flashes error where L was?? help!!
if it is a new house check the kitchen drawers for a user manual for all the installed equipment
If you can't find any ask the builder /retailer for them
May 26, 2016 | Cooktops
Neff gas hob on T2124 not lightin when turning on ignition.
make sure you have gas to the hob then make sure all the rings are clean and not blocked and that the ignition electrodes are clean
Dec 09, 2010 | Neff 22 in. T2124 Gas Cooktop
Eurokera hob - lights flashing, buttons not working
hi i have a eurokers ceramic hob and it has not worked in about a yr. it is touch screen and only 1 mth old when problem happend it was like it over heated and now when you turn it on it flashes on the dial i cnat make out it and the hob wont come on. pls help it is brand new and dont want to throw it out.HELP PLS
Dec 26, 2009 | Cooktops
Gas hob is permanently igniting
hi gud day,try to clean the area of knobs by using vacium,remove all the knobs firts then clean it,unplug the unit before u clean.
tnx gerbee
May 19, 2009 | De Dietrich DTG775X Gas Hob 22 in. Cooktop
ZKT 623 LBV digital hob
hi gud day,all hob is almost the same to use,if touch control ur unit,put ur tumb wer the place sign of child lock & off sign..tnx
Jan 29, 2009 | Cooktops
Hob not working
replace the hob. the f1 error is not sensing a temp change and if the burner is broke it wont sense it.
Dec 05, 2008 | Cooktops
Hob turns off
hi im gerbee my suggestion is replace the pcv control wat brand u have,always also in philipines the electric hob is so very sensitive,the pcv cotrol is not repairable.or next time u by a new one gas cooktop more ok compare to electric ceramic hob, or use electric ceramic hob w/knob control compare to sensor type,i think the part of the sensor or pcv control is so very expensive,that why i buy an another one.dont try to repair more difficult to com.tnx
Nov 24, 2008 | AEG 23 in. 6410KF-N Electric Cooktop
Safety lock on Neff hob
I have a Neff T4344N0/08. I cannot stop all four hobs flashing - ie: I press the 'on' button all four flash, I then choose which one I want to use plus the number but they all keep flashing instead of stopping after the usual three or four. Please help - have I pressed something I shouldn't, perhaps a child lock?
Sep 27, 2008 | Neff 23 in. T4343 Electric Cooktop
Cooktops Logo
103 people viewed this question
Top Hoover Cooktops Experts
Paul Carew
Are you a Hoover Cooktop Expert? Answer questions, earn points and help others
