2005 GMC Envoy Logo
kammy stone Posted on Apr 14, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My 2005 GMc envoy stopped when I stopped at stop sign the service brake system warning keeps coming on when push brake pedal. Gear shifter won't move out of park and it will not start.
Jeff Armer
Level 3:
  • GMC Master 15,575 Answers
  • Posted on Apr 14, 2017
Jeff Armer
GMC Master
Level 3:
Answers
15575
Questions
Helped
7109019
Points
73899
Hello Kammy ,you have electronic problems ! Your best bet would have it towed to a qualified repair shop .
SERVICE BRAKE SYSTEM
Refer to Brake Warning System Description and Operation !
The instrument panel cluster (IPC) illuminates the brake warning indicator when one or more of the following occurs:
• The body control module (BCM) detects that the park brake is engaged. The IPC receives a class 2 message from the BCM requesting illumination.
• The electronic brake control module (EBCM) detects a low brake fluid condition. The IPC receives a class 2 message from the EBCM requesting illumination.
• The EBCM detects an ABS malfunction which disables dynamic rear proportioning (DRP). The IPC receives a class 2 message from the EBCM requesting illumination.
• The IPC performs the bulb check at the start of each ignition cycle. The brake warning indicator illuminates for approximately 3 seconds before turning OFF.
• The IPC detects a loss of class 2 communications with the BCM or with the EBCM.
When there are electronic problems the computers will not allow the vehicle to start , hooking up a factory or professional scan tool to see what the problem is is the first place to start .
5 Related Answers
Anonymous
  • 11 Answers
  • Posted on Sep 13, 2008
SOURCE: 2002 GMC Envoy Stuck in Reverse
broke cable
transit360
  • 74 Answers
  • Posted on Feb 10, 2009
SOURCE: Engine will not turn over or start when in park with key on.
You linkage is working properly it sounds like, especially if the indicator for "D, R, N", etc are lining up. However the linkage or the neutral safety switch may need to be adjusted. More than likely, it's your neutral safety switch.
The brake pedal release has nothing to do with the neutral safety switch when switching gears.
The brake pedal release is just a safety to prevent you from pushing the gear shifter accidentally. Actually, you should be able to start the truck without holding the brakes.
If the neutral safety switch is bad or misaligned, it'll do exactly what you're describing. If pulling it down in neutral starts the truck, then that's a sure indicator.
italinhitman
  • 43 Answers
  • Posted on May 26, 2009
SOURCE: the gear shift on my 2004 gmc envoy does not move from park.
cheak the brake pedel swich it work a swich in the gear seleter
john h
  • 29494 Answers
  • Posted on Nov 26, 2009
SOURCE: gmc yukon has the abs & parking brake light
you have to fix the problem with ur brakes- first check the wiring ,connectors and connection clips to the abs sensors and modulator if looks ok than have truck scanned some auto stores such as auto zone / advanced auto do it for free the code will give u a start point towards fixing ur problem--visual inspection of brakes doesnt always show problem
Anonymous
  • Posted on Mar 30, 2011
SOURCE: 04 Trailblazer Will not shift out of park.
Sounds like the cable from the shifter to the transmission probable snaped. It happened to me at the emission inspection station. What a nightmare. To check this you will need some help. Have someone set in the car and apply the brakes as well as the emergency brake just incase. Get under the truck and find the cable from the shifter to the transmission. Have the person in the truck move the shifter lever from park to another gear. If the arm where the cable attaches to the transmission does not move when the lever is moved it is the cable. They are relitively cheap and you should be able to replace it yourself.
2answers
03 envoy will no go in any gear. Shiftsr just glides through the gears on the panel. Nothing in 2wheel or 4wheel drive either. Rpms just race up when you put it in gear.
This would be the shift linkage bushing, very common. When switching through the gears, the gear selector lights in the dash probably don't move from P.
1helpful
2answers
2005 envoy xl will not shift out of park
check brake switch --trans cable and shifter
2005 Honda Odyssey brake horn fuse keeps blowing, stuck in park
Why do fuse's keep blowing ? A short circuit to (ground) somewhere . Do you know how to use a wiring diagram an a DVOM - digital volt ohm meter to test electrical circuit's ? Brake ? brake light's ? You can't get it out of park because of the shift lock solenoid ( shifter interlock system ) This is a safety system that won't let gear selector to move from park unless driver is pushing the brake pedal . The fuse blowing - no power to brake light switch , computer see's no signal so it won't energize the shift lock solenoid .
http://www.bbbind.com/free-tsb Enter vehicle info. Year , make , model an engine size . Under system click on lighting ,then under subsystem click on stop lamps . click the search button ,then the blue link.
Electric Testing Techniques You Need to Know
How to find short to ground blown fuse
2012 Chrysler Town and Country wont shift out of park
Probably a problem with the shifter interlock system . Won't allow the gear selector to move from park with the engine running unless the driver is pushing on the brake pedal . Locking solenoid in the shifter , brake pedal switch , wiring etc... may even have a body control module in the loop controlling these system . Do the brake light's work ? Some of these system's have a release point in the shifter assembly . Don't know if this is your problem without checking it out .
Shifter won move
Shifter Stuck in Park Wont Move Easy Fix Most Make Model Vehicles
WHY WONT MY 97 S10 2 WHEEL DRIVE WONT GO INTO GEAR WHEN I PUT FOOT ON BRAKE PUSH BUTTON ON SHIFTER SHIFTER WONT MOVE
The car has an interlock system that prevents you from shifting without putting your foot on the brake ..The brake pedal switch not only controls the stop lights, but also sends voltage to an actuator that unlocks the gear shift. Check the brake pedal switch for failure or loose connections or blown fuse that feeds that circuit . If you look in your Manuel there is a way to override and unlock the gearshift incase of voltage failure.
My mechanic tells me I need a new interlock shift in my 2002 GMC Envoy. On ocassion, I need to pump my brakes a few times before I am able to move my gear from park to drive. The shifter is cheap but the...
Before any parts are replaced, it needs to be determined if the brake pedal switch is being actuated properly and functioning properly. After that, the interlock solenoid needs to be checked, as well as the linkage.
I changed the brakes on my 2004 GMC Envoy. Everything is good accept the service brakes light is on and won't turn off. How can I turn it off?
Do you have a good brake pedal, does it hold when pushed? Is the ABS light on too?
There may be air in the brake lines, there may be dirt in the lines. Have you tried bleeding the system?
1helpful
Gear shift will not move from park
First thing to check is your brake lights. The brake interlock for the shifter relies on the switch that turns your brake lights on. If it's not working, you won't have brake lights OR the ability to move the shifter out of park. In an emergency, most of these vehicles have a small plug near the shifter that you can remove, push a button, and move the shifter without pushing the brake pedal.
Good luck.
3answers
Igniton key is stuck in switch and won't turn off
Check the shift cable to the shifter to the transmission,and the shifter could be malfunctioning.
4helpful
3answers
The gear shift on my 2004 gmc envoy does not move from park.
Top GMC Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a GMC Expert? Answer questions, earn points and help others
