Question about PreSonus INSPIRE 1394 External Sound System
Inspire is plugged and hooked up to laptop but says no device when I open. Also have a red light. not sure what that means.
    Problem Solver:
  • 9 Answers
The red light on the front of the PreSonus Inspire 1394 means there is no synch between the interface and the computer. The device is useless until that light goes blue.
Make sure the device drivers are installed. Check device manager... look for two entries: one under "61883 Device Class" and the other under "Sound, video and game controllers". Missing devices or devices with a yellow exclaimation may need to be reinstalled. A red "X" means it's disabled (enable it).
Sometimes, the connection just stumbles. It may come back on it's own, but usually not. Try pulling the firewire out of the computer, counting to five and plugging it back in.
Other possible, but less likely causes: bad firewire (try another), interference (stay away from CFLs), or a bad firewire port. Or the device could just be bad.
Posted on Jan 15, 2010
  • 120 Answers
It might be your lamp is dead.Remove your lamp and check it. If you don't know how to remove this ask technician... Or maybe your button switch is not working properly.
Posted on Jul 24, 2009
  • Tomsx May 06, 2011
    How about on a Mac . Same issue with sync. Tried messing with midi settings as instructed .. No go
I've got a used creative inspire t6060. Connected all, no sound. There's green light on the remote wired control, power supply measured fine: 18.5V AC from transformer, and also 18.5V DC at the big...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Mar 17, 2011 | Creative Technology Inspire T6060 5...
Is it not possible to use the usb cable to hook up the HTC Inspire to your tv true or false possible or not.
I believe some USB connections on TVs, game consoles are USB 2.0 which means they can provide power. If anything, you can only charge your HTC through the tv's usb connection
Mar 01, 2011 | Sony Televison & Video
Inverter beeping, red light power to pc going in and out
Usually the beeping means the outlet is being short circuited or you are drawing too much power. Make sure your hooked up device(s) don't draw more than 90W and are intact.
Feb 22, 2011 | Targus Mobile Power Inverter 90 Watts...
Nothing happens when I plug this in. I've tried eSATA and USB, both with the power adapter. The blue light comes on but nothing else. The hard drive works in other enclosures so I know that isn't the...
Your assumptions are leading in the right direction.
  • The blue light would just be denoting power to the device the red light would denote drive activity. The limitation on this enclosure is that its white papers states a "Hard Drive Compatibility: 320GB HDD capacity", but I have seen people use a 500GB drive that seemed to work. If your using a drive larger then 320GB this may be an issue.
  • The enclosure HDD combo is Plug-N-Play via USB so this would mean drivers most likely are not the issue. I don't believe drivers are even packaged with the device which would mean they use protocol standard drivers from the OS.
  • Make sure that you are not hooking the USB up to a external USB hub (especially a bus-powered one) while trouble shooting as it may not provide enough power. Connect the drive up to system USB controller directly while trouble shooting.
  • I believe this device has the ability to hook up 2 USB cables at the same time for extra power (mainly while using the eSATA connection). Try hooking up the USB mini-B connector and the USB +5VDC connector and then hooking both up to the system on two different USB ports. This should then correct the possibility that your drive may not be getting enough power.
  • Lastly, the enclosure could have a faulty IC on the PCB. Exchanging it would provide the answer for that.
Hope this was helpful. Thanks for visiting FixYa.com
Feb 02, 2011 | Eagle Tech ET-CS2XMESU2-BK 2.5" SATA to...
Dell inspire laptop 1564 webcam not working properly. Whenever open the dell webcam center the error showing as below: "please plug in a supported device"
It sounds like the driver does not match the WebCam.
Uninstall the WebCam driver and WebCam
Reboot the laptop and reinstall as required.
Hope that helps.
Dec 09, 2010 | Dell Computers & Internet
Toshiba satellite P305D-s8828 won't come on or recharge
Check your AC adapter to make sure it is plugged in, and that the light (if you have one) is on on the adapter. If not try a different outlet. If it is gently wiggle the jack going into the computer to see if the system starts, if it does start you need to have the DC jack replaced. A flashing light means the battery has died and it needs to be charged, the laptop charges the battery using the adapter so start by checking from the wall to the laptop.
Jun 17, 2010 | Computers & Internet
Creative Inspire 5200 system won't work
Hi. Check your speaker system with a different audio device like iPod or any MP3 Player using the same jacks. If the speaker system gives out sounds then nothing is wrong with it... if no sounds come out, then you know what I mean...
Try to replace the speaker of your sub-woofer... maybe that can fix it!
^_^
Jun 06, 2010 | Creative Labs Inspire 5200 Computer...
The ac adaptor light is permanently red
Hook up the ac adaptor and make sure the other end is not plugged into the xbox 360. if its still red then your ac adaptor is bad. If its still green then plug the other end into the 360 and if it turns red then that means the mainboard inside the 360 is bad.
Jun 06, 2009 | Microsoft Xbox 360 Console
PreSonus INSPIRE 1394 External Sound System Logo
961 people viewed this question
Top PreSonus Computers & Internet Experts
Greg Ulan
richie46
Tom Chichester
Are you a PreSonus Computer and Internet Expert? Answer questions, earn points and help others
