Question about Tools & Hardware - Others
Got a worx router,model wx15rt cannot find a 30mm guide bush
The guide bush has a 30mm hole and a over all size of 87mm with two screw holes
If you can't fabricate your own. Get a dedicated or universal sub base for the WX 15RT Router, this allows attachment of trend and other bush guides
Posted on Jan 29, 2010
Attach Worx Trimmer Safety Guard
check for a hole in the head or shaft that the screw will be positioned in when fully screwed in
Jul 31, 2016 | Worx Garden
Looking for user manual for worx router model wx15rt please
http://www.manualslib.com/brand/worx/network-router.html
Mar 01, 2015 | Crafts & Hobbies
Imhave stripped threads on my sand filter housing where the pressure gage fits
That hole that you thread in your pressure gauge is 1/4" size. The pressure gauge is a 1/4" x 20 threads NC.
So, the fix I would attempt is to drill out the hole to the next size up and re-tap new threads - I would go to the next commonly used size: 3/8".
to do this: Obtain the proper drill bit size for a new 3/8" hole. That drill bit size will be a 37/64". Once you drill out the stripped hole to the next size opening, get your 3/8" Tap, and slowly & carefully start turning in a clockwise direction. Make one complete rotation, check to see if bites into the new hole, if not, then push into the hole a little bit harder, and try again. Once it bites, turn 1 more full turn and then backup a 1/2 turn. Continue a full turn, back up a 1/2 half turn. What this does, will break away the plastic fragments and will clean out the hole so it will not ruin the new cut threads.
Once the tap is in about half way, thread the tap all the way out, and then turn the tap back in by hand. It should screw in easily, yet firm.
Now you will need a reducing bushing. Threads on the outside of 3/8" and inside threads of 1/4". This is a reducer bushing commonly labeled 3/8" x 1/4" NPT also sometimes known as a Hex bushing 3/8"x1/4" NPT
Use only 4 wraps of teflon tape wrapping in a "Counter" clockwise rotation, on both the busing and the new pressure gauge.
Good Luck
Jun 07, 2014 | Hayward SAND FILTER, PRO SERIES
What do I do if my router has 33mm guide bush but jig a want to use says I need a 30mm guide bush?
Look up 30mm router guide bushings on the web. Do a search. You'll find several sites that carry a 30 mm bushing.
May 13, 2014 | Tools & Hardware - Others
Makita template guide does not fit
My Makita router arrived with a couple of template guide bushes of different sizes. The size of guide bush chosen for use with a particular template will be dictated by the template - stock templates usually state the size of guide to be used with that template and mostly these are generally so common sizes a good router is supplied with them, from memory I think the smaller of my guides is something like 17 mm.
Template guide bushes are flimsy and easily damaged and so it is expected router users will be buying spares and other sizes. They are almost universal but not quite and router users are quite adept at minor modifications to make things fit, and not just guide bushes but also router tables, adaptors for various tasks and so forth.
I suggest you take a glance through a few catalogues featuring router accessories, including Makita of course.
May 06, 2017 | Makita Tools & Hardware - Others
HI, i am looking for a guide bush to use in conjuction with a hinge jig, is there a special one that i need. Kind Regards Darren
I assume you are asking about a router guide bushing, although this question was filed under chain saws. The guide bushing size has to correspond to the bit size to get the right size cutout for the hinge template. Here's a set: http://www.grizzly.com/products/Brass-Bushing-10-pc-Set/H3134
Good luck, Al K
Aug 26, 2010 | Garden
Can i use 30mm guide bush to cut worktop with a 1/4 router
Yes you can. You probably would want to do some test cuts in the wood that you are using.
If your worktop is hardwood then each pass will have to be maximum 1/8". It will take many passes depending on the thickness of the worktop. This is assuming that a carbide bit is being used. The smaller the diameter of the bit the less resistance. Also using a 1/4" shank on the bit and the HP of the router determines how fast the router will cut.
Sep 04, 2009 | Tools & Hardware - Others
We have a LC427SSX and want to mount it on the wall
The thread size is standard, just a metric standard. To attach the Sylvania LCD427SSX to the wall mount bracket you'll need (4) metric 8mm machine screws with a 1.25mm pitch. You'll find them at your favorite neighborhood hardware store with the designation M8 1.25x40mm. (40mm long...the 30mm would be to short)
Jul 09, 2009 | Sylvania LC420SS8 LCD TV
My drain hole is stripped on my hayward pool pump. the threads are completely gone as i was trying to put a metal fitting in the hole for the use of an ozone generator. can i re thread the hole? it is a...
There are a couple of ways to do this repair, First way is to buy a reducer bushing (threads on the inside and smooth surface on the outside), drill out the hole to tightly fit the bushing, and prime and glue it in place. The second way is to buy a tap (the next size up), buy a brass reduser bushing with threads on both the inside and outside. If you dont have enough material to inxdease thr hole size, then you will need to buy some J.B. weld and fill the hole, wait 16 to 25 hours to drill and tap
Jun 14, 2009 | Hayward SAND FILTER, PRO SERIES
Tools & Hardware - Others Logo
683 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
