On July 9th, I asked: on my 50'' plasma, a vertical line popped up from top to bottom and 2 days later another was duplicated both located at 1/3 screen in from the right side. I was told the DM board has a bad capacitor and will need to be replaced. I then asked if $1200.00 was a valid cost as quoted by a sony repair ctr. I received the Plasma back today not repaired and these now are the reasons: ''Need to replace bad sustain boards and main logic core seems like it took a big power spike and affected components hopefully. The PDP display is bad. no longer available''. Can anyone confirm this based on the info given and any other thoughts. This is a Sony KE50XBR900. Thanks in advance.
  • 188 Answers
There is little hope.
In some plasma set there are some panels with the so called COF ic's,in some sets these IC's are powered via an SMD resistor located near these IC.Resoldering the resistors could be the sollution.
Posted on Jul 24, 2009
1 vertical black line on samsung plasma tv on left side (model # pn50a450p1dxza)
Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the left top left corner of the display window. It will make search easy. Some times, the ads attached with each posts both at the right and bottom, might help you to find the availability of spare parts. There are more than 640 posts to different brand TVs now. Will be updated daily. Faults to Samaung Plasma TVs are given in detail.
Aug 19, 2012 | Samsung Pn50a450 Pn50a450p1dxza 50" 720p...
LG plasma 50 inch tv with a fine vertical black line in the center of the screen that runs from the top of the screen to the bottom
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | LG 50PG20 50 in. Plasma HDTV
I have evenly spaced, rows of two vertical green and red lines from top to bottom of my vizio plasma P50HDTV10A
Somehow when switching between the tv and the dvd my wife encountered the pink and green, thin, parallel, vertical lines on the screen. The picture was visible with the lines. I turned the tv off and on but the problem persisted. Unplugged tv for about two minutes and after plugging it back in and turning it on the vertical lines very gone and the picture was back to normal.
Jan 12, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
Samsung 50 in. HPS5033X/XAA colored lines running vertically and won't go away.
How wide are the lines. Do they change width? Where on the screen are they located?Connections on the c boards at the bottom to the panel flex cables or bad c board itself can cause 2 inch wide verticle bar. Before touching these connectors be sure power supply is disconnected from the 2 sustain boards on the sides. If you don't there will be an arc that will destroy the flex cable thus you will have to replace the panel. If C boards or connections don't fix it the replace the plasma panel. If the lines are thin lines then panel is likely bad. Contact Panasonic even if out of warr they may help.
Dec 06, 2009 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Black vertical line 2 in wide on zenith p42w34p
Hello, I can help you fix your plasma TV. If you have Black vertical 1.5 inch line/s that come and go. Please feel to call or message me at 1-503-432-9904 or pleasefixitdave@yahoo.com Ask for Dave! Later guys!
Jan 02, 2009 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Dell W5001C 50 in plasma - vertical black line
the y-boards are not the problem. its the e or f board located on the bottom of the panel open the back cover and look at both for potential burn spots around the silicon sealant. if one or r brown, theres your problem. ebay the board number and get it fixed.
Aug 18, 2008 | Dell W5001C 50 in. Plasma HDTV
Parallel vertical lines through left side of Panasonic Plasma tv
This sounds like one of the driver boards at the bottom or top of the screen has an intermittent fault. The set will have to be taken in to a service centre.
May 31, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Vertical black lines
I want to know the possible cause of tv with 2 black line at the top and bottom of the screen. Is it have the same causes even if the tv model is not the same..thanks
Dec 19, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
Electro Med Services...
