Question about Midland 1001Z 40-Channels Base CB Radio
Microphone i have 2 uniden 4 pin radios and can't switch the microphones
    Problem Solver:
  • 13 Answers
Uniden 2-way radios have 5 pin mic connectors, mind you pin 1 is not used (12V), are you sure both are uniden radios? what are the model numbers?
Posted on Jul 24, 2009
CB Uniden 4-wire mic to a Uniden 510 radio how to wire color codes please
look up microphone wiring diagram for your cb and mic. more than one way to wire, depending on mic and cb having 4 or 5 on plug end. write down mic numbers and cb plug numbers. if audio on mic is 3 and cb is 4 put 3 on 4 pin check each wire. using power mic make sure red and black wire are on the right pin, can damage radio or mic or both.
Feb 11, 2018 | Uniden Radio Communications
Uniden PRO510XL low output and "motorboating"
Hi
It sounds like your circuit board may have a bad solder joint. Sometimes during manufacture of the ciruit board, the joint could not be perfectly made. This will limit conduction and create heat which will worsen the effect over time. If you are familiar with opening and working with electronics then I suggest you remove the circuit board and inspect it for cold solder joints. When you find one, you can use a Cigar Torch type lighter to help reflow the solder easily. Out side of that, you mayu want to send it to a Electronics repair shop to do this for you. Let me know more and I will help. Good luck
Jan 19, 2008 | Uniden PRO510XL 40-Channels Base CB Radio
Trying to wire ranger sra198 mic to galaxy 4 pin radio.
That microphone comes wired stock for Uniden/Cobra.
That is:
1- Shield
2- Audio
3- Transmit
4- Receive
You need to change it to
1- Shield & Black
2- White
3- Red
4- Blue
Mar 16, 2017 | Galaxy Radio Communications
How to wire a 4 pin ProComm microphone to work on a 5 pin microphone for a Uniden Grant XL
The simplest way is to order a microphone adapter from ebay or a reputable CB shop. I have all my mics wired for standard 4 pin cobra. The standard 4 pin cobra is the most common and if you keep adapters handy then you can use all different kinds of mics on different radios.
Apr 09, 2016 | Uniden Radio Communications
How to wire a superstar DM-452 to a five pin uniden and washington
Trying to wire a dm-452 4 pin mic to a 5 pin uniden ... - Fixya
www.fixya.com/.../t22723929-trying_wire_dm_452_4_pin_mic_5_pin
Jan 6, 2014 - trying to wire a dm-452 4 pin mic to a 5 pin uniden washington -Uniden Bearcat Pro PC68XL ... SOURCE: trying wire a superstar dm-452.
How to wire a superstar DM-452 to a five pin uniden and ...
www.fixya.com/.../t26060852-wire_superstar_dm_452_five_pin_uniden
36 mins ago - how to wire a superstar DM-452 to a five pin uniden and washington - Uniden CB Radios question.
Wire superstar dm 452 mic - Answer
www.dqrkc.com/search/...uniden...pro.../wire_superstar_dm_452_mic
... to a 5 pin how to wire a dm-452 superstar 4 pin mic to a 5 pin uniden washingtonit's not possible to wire 4 wire mics to the uniden 5 wire radios without ...
Uniden Bearcat Pro PC68XL 40-Channels Base CB Radio ...
Jan 19, 2016 | Uniden Radio Communications
Wire 4 pin microphone
  • Here is how it should be wired. --- Pin 1 -> Shield --- Pin 2 -> Modulation --- Pin 3 --> Transmit Switch --- Pin 4 --> Receive
  • PiP
  • Feb 01, 2014 | Magnum DeltaForce CB Radio
    I have a uniden Grant like to wire up a 4 wire D104 the mic has white black red shield
    Wiring 1 4 pin D104 mic to a Uniden Grant CB is as follows -
    • Pin 1 - Shield - Shield
    • Pin 2 - Audio - White
    • Pin 3 - Transmit - Red
    • Pin 4 - Receive - Black
    Regards, Tony
    May 05, 2011 | Uniden GRANTLT 40-Channels Base CB Radio
    Dm 452 microphone
    this radio is made by PEIRCE SIMPSON and is wired like a cobra.
    pin 1 shiels or ground
    pin 2 is audio
    pin 3 is transmit
    pin 4 is recieve
    shield is a bare wire wraped around the audio wire.i dont know the colors of the wires in the echo mic.the transmit wire will have contiuity with the shield wire when the mic is keyed that wiregoes to pin 3 . there should be 2 wires left. check these wires one at a time with the shield wire one will have contiunity . this wire will go to pin 4 recieve.the other wire will go with the shield wire on pin 1
    this is the way you find how it wires. it will take an ohm meter to find whice wire goes where.
    james morgan
    morgans electronics
    Mar 09, 2009 | Uniden Bearcat Pro PC68XL 40-Channels Base...
    Mic wiring diagram
    Want to wire cobra mic to a uniden washington radio
    Nov 20, 2007 | Radio Shack TRC-447 CB Radio
    Midland 1001Z 40-Channels Base CB Radio Logo
    124 people viewed this question
    Top Midland Radio Communications Experts
    Steve
    eradiostore
    eradiostore
    Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
