Question about Altec Lansing MX5021 Computer Speakers
In mx5021 when i try full volume then sound is very very bad
  • 724 Answers
Old school audio output push and pull circuit is toast. the electronic audio output stage is made of a preamp, drivers, and output stage.
Use to be able to change out the tubes or top hat transitors now it is a package that is sealed inside and soldered to a ckt board that is sealed inside of the case with no easy access to it, without destroying the container and re-engineering a put back together. A new wolfer amp combo is needed. Less head ache
Posted on Jul 25, 2009
Altec lansing mx5021 wired controller not working
Sounds like you might have a wire loose at the other side of the controller. This is a easy thing to find out. Just unscrew the side screws that hold the back board to the cabinet. Don't unscrew the screws connected to the speaker wire clips unless the back doesn't come off. Just look for a disconnected wire at the controller jack then put it back. If there is no loose wire then you might have a bent female contact at the outside of the controller jack. You would have to look for this looking into the holes where you plug the cable into the controller jack. If you see a bent contact then use a thin nail of ice pick and insert it into the hole where the bent connector is to try to re open the contact so the cable can slip into it easy. Don't forget to unplug the power first.
Nov 07, 2013 | Altec Lansing MX5021 Computer Speakers
My sound card, windows everything ok, but sometimes sound doesn't come through the speaker. it gets power and everything.......even the blue light of the controller is ok......wat shud I do???? sometimes...
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Jan 26, 2011 | Altec Lansing MX5021 Computer Speakers
My altec lansing mx5021 speakers problem
The problem I have found is the contact glue between the back panel and circuit board inside the sub woofer. The glue becomes conductive after some time (2 years..!!) and needs to be scraped away from across tracks, you can tell the problem areas as the glue is pale yellow but goes brown and conductive over time. Good luck.
Regards
aj
Feb 18, 2010 | Altec Lansing MX5021 Computer Speakers
Speakers are not working completly.
Please click on start /programs/accessories/entertainment/select volume control/click on the option windows default/thats all your problem will be solved.. thankyou...
Jan 02, 2008 | Altec Lansing MX5021 Computer Speakers
Altec Lansing MX5021 Computer Speakers Logo
203 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Jerry Umali
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
