Question about Konica Minolta magicolor 2400 Laser Printer
My 2300W lightning symbol is flashing and I can't get rid of it...I can't find a paper jam, have opened and closed and started and restarted it...is there a way to be sure that there is no little piece of paper stuck somewhere in the paper path?
  • 120 Answers
Remove your lazer toner, you can check if there is a paper jam on the roller. Maybe your roller has a dirt on it.
Posted on Jul 24, 2009
A symbol flashes indicating paper jam, however there is no paper jam
open and close the cartridge access door. does it change to the next indicator ?
Apr 04, 2014 | HEWLETT-PACKARD LaserJet P2015 Printer
Paper Jam at Tray 1
The solenoid may be getting stuck, the only way to check is to remove the solenoid and check that it opens and closes smoothely.
May 26, 2013 | Minolta magicolor 2300W Laser Printer
The paper light is flashing. The tray has paper, there is no paper jam. I check everything, put tray back in, press go and after a few seconds, there is a click noise and it starts flashing. What do I do?
The light flashing may mean more things, not just a paper jam. Could mean any of the following:
- Front cover is open: Close the front cover of the printer.
- Back cover is open: Close the back cover of the printer.
- Paper jam: Clear the paper jam. To see paper jams and how to clear them, click here. If the printer does not start printing, press the Go button.
- No paper fed manual feed slot: Put the paper back in the manual feed slot.
- Memory full: The printer memory is full and the printer cannot print full pages of a document. To solve this problem, click here.
- Print overrun: A print overrun occurred and the printer cannot print full pages of a document. To solve this problem, go here.
- Drum Error: The corona wire needs to be cleaned. To see how to clean the corona wire, click here.
Thank you for using Fixya!
Dec 02, 2010 | Brother HL-2040 Laser Printer
What does the "heart beat" symbol/light mean?
I assume you mean the symbol that has a pair blackened circles and then a pulse up and then down below the starting line before returning to the starting line.
That is the paper jam symbol. If the continue light is on (steady) and the paper jam light is on, then you have a paper jam. Press Continue twice to see any secondary error message (this will show where the problem is).
See the manual for the list of the lights that show where the jam is occurring. Different groups of lights will be lit. The manual is available as a PDF at the bottom of this page: http://support.lexmark.com/index?locale=EN&page=product&userlocale=EN . An example: if the Continue, Toner Low and Paper Jam are all on, then the jam is in the fuser area under the print cartridge assembly. For a paper jam, even a small corner of torn paper could be in the mechanism.
In all cases, you should check the entire paper path. When you pull out any paper, grip it so that you can gently pull the sheet straight out. Remove all paper from the output tray. Then remove the paper tray if you are using it. Pull any paper from this area. Press down on the green duplex flap and remove any paper from there Reinsert the paper tray. Open the front door of the printer and remove the print cartridge assembly. Lift the green flap and remove any paper from the area. NOTE: the fuser and the fuser area may be hot. Open the rear exit door and remove any paper from that area. Use a flashlight to check for small pieces of paper that may be stuck. Once all the paper is removed, reinstall the print cartridge assembly and close all the doors. Press Continue to reset the printer.
The page that jammed may be reprinted.
I hope this helps.
(please note that frequent paper jams may be a sign of excess humidity in the paper. Put less paper in the tray at each refill and keep the remaining paper in a dry location. If the paper jam light is coming on when no paper jam is present, one or more of the paper jam sensors may be bad. Contact Lexmark for more information.)
Nov 30, 2010 | Lexmark E250dn Laser Printer
I had a paper jam. Got the paper out, but now
Some printers won't reset the jam condition until you open a specific door or cover -- even if you've gotten the jam out, they think it's still there until you open that cover. Try opening and closing all of the machines doors and access points, and even pull out the paper tray and push it back in.
If the jam condition still isn't cleared, turn the machine off and back on with the main power switch.
Jul 05, 2010 | Canon PC-940 Black and White Copier
The printer jams often and often makes beautiful fans out of the paper you can contact me at yak1racs@yahoo.com
You probably have a piece of paper from a previous jam stuck in the printer. If it is making beautiful fans, then it is probably in the fuser module. (At least in my experience.)
I'm not sure about the minolta, but most printers have color coded levers inside that you need to open to check for paper jams. In HP's they are green.
Jul 16, 2009 | Minolta magicolor 2300W Laser Printer
Triangle symbol on our printer with a AMBER LIGHT FLASHING?
There is an issue with the media/paper. First thing is to make sure there is paper, and if so, that it's touching the intake rollers. Next is to check for jams, which are usually under the imaging drum. Open the front lid and remove the drum (it's in the front; follow the directions shown on the label on the front right.) Also, check for jams where the paper exits the printer.
Final two things. The lid could be ajar - simply push down firmly to ensure all the contact switches are closed. The last thing is an issue with the fuser, which may require replacing it. I highly recommend getting the service manual from HP, as it is easy to follow and has extensive troubleshooting.
Jul 01, 2009 | HP LaserJet 2550n Printer
Paper jam, cleaner kit
If the paper is not situated perfectly in the tray, and it cannot grab the top sheet easily, mine will give the paper jam message. I just adjust the paper in the tray, then open one of the doors, front or back, and close it again, and it usually fixes the "Jam".
Jun 23, 2008 | Minolta magicolor 2300W Laser Printer
Flashing light
Here is what HP has on the subject of the triangle light flashing:
c00028322.gif 1 - Attention Light 2 - Ready Light 3 - Go Light Figure 2: Printer light key c00028323.gif 1 - Symbol for light off 2 - Symbol for light on 3 - Symbol for light blinking
c00028328.gif Door open, media out, no print cartridge, or media jam
The printer is in an error state that requires operator intervention or help. Check the following:
  • The print cartridge door is completely closed.
  • Media is loaded.
  • The print cartridge is correctly installed in the printer.
  • There is no media jam.
Figure 8: Paper jam c00028328.gif 13.JJ.NT JAM IN TRAY 1
13.JJ.NT JAM IN TRAY X
The Attention LED is blinking. Check paper loading then open and close top cover.
When there is a jam in tray 1, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored.
When there is a jam in tray X, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored. These are the error explanations for just the flashing triangle light, there are many more, but none for just the flashing triangle.
If the light pattern is different let me know (other lights on as well)
-Hope this helps.
May 28, 2008 | HP LaserJet 1012 Printer
Konica Minolta magicolor 2400 Laser Printer Logo
199 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
