Question about HP Pavilion dv6426us Notebook
I have an HP DV6426us. Last night I accidentally unplugged the AC adapter. I immediately plugged it back in, but the blue light on the DC jack wouldn't come on. I have also had a problem where the power runs down within seconds, so after 30 seconds the laptop had no charge and shut off. Now I can't get the blue light at all. The adapter was purchased in May 2009. I have always had to replace the adapters every 3-6 months because they would melt, but this one shows no signs of problems at all. I don't know what the source of these issues is, I just need to get the power back on.
  • 724 Answers
Sounds like the battery pack is shorted and loading down the Adapters. The adaptor should have the specified voltage coming out of its output plug! Need to test it with a volt meter or some other crud way. If the battery is really bad, not even the adapter or a car battery will be enough to overcome a short. But the car battery may show you the exact and cook everything.
Posted on Jul 24, 2009
  • 120 Answers
You need to replace the battery asap. The battery is equipped with power mosfet connected to battery. pull the battery on the bottom of your laptop. There is a button on battery that you can check if the battery is charging. if no..,change it.
Compaq CQ1-1225 AIO Wont Start at all. Removed all components
Suggestions;
Anti-Static wrist strap connected to ground source, and your wrist;
1) The jack your AC adapter plugs into on the motherboard, is the DC Power Jack.
Motherboard out of case, power to motherboard, take your multimeter and see if you are getting 19 VDC at the DC Power Jack's positive solder joint, on motherboard.
The center pin of the jack is Positive. (The inner cylindrical shell is Negative)
Follow the DC Power Jack's positive pin from the Center of the jack, to the motherboard.
You probably won't be able to touch your meter's Positive (Red) probe, to the DC Power Jack's positive pin under the jack; so touch it's solder joint on the opposite side of the motherboard.
(DC Power Jack should be soldered close to the motherboard, is why)
Of course also touch the Negative lead, (Black probe), of your meter, to the Negative, (Ground) solder joint for the DC Power Jack.
Getting 19 volts DC?
See if there is a cracked solder joint, for any of the DC Power Jack's pin connections to the motherboard.
ANY perceptible movement of the DC Power Jack on the motherboard, indicates a bad power jack, and may indicate a broken/cracked solder joint.
Center pin of DC Power Jack is loose? Bad DC Power Jack. Replace.
2) DC Power Jack is determined to be in good repair? No cracked/broken solder joints?
The next components in the power circuit on the motherboard, leading From the power jack, are P. MOSFET's.
Power MOSFET.
Power MOSFET Wikipedia the free encyclopedia
More information using a prior solution,
Dv6000 power light does not come on any more
Check the links given.
3) The last thing that concerns me, although I probably should have listed it first; is the AC adapter you are using.
Concern is that it doesn't have the 'intelligent chipset' that matches the Compaq CQ1-1225 All-In-One desktop PC's circuitry.
AC Adapter For Compaq Presario All in One CQ1 1225 Desktop PC Charger...
Just my thoughts..........
Regards,
joecoolvette
Jan 15, 2015 | HP Computers & Internet
Power problems
Unplug the AC adapter (Charger) from power. Unplug the AC adapter from the laptop.
Remove the Battery.
Press the Power On button in, and hold it in for a count of 10 seconds.
(And I mean 10. Count, 1001,..1002,..1003,..etc)
Reinstall the Battery. Plug the AC adapter back in. Plug the AC adapter into power.
(ALWAYS plug the AC adapter into the laptop FIRST, then plug the AC adapter into power.
Why?
To avoid a voltage spike at the laptop)
WAIT 1 minute, turn the laptop on.
Still no?
Then the AC adapter needs to be checked, to see if it is putting out the correct voltage.
Don't know, Model Number wasn't stated.
AC adapter checks out, then it is on to the DC Power Jack.
The jack on the laptop (DC_IN) that the AC adapter plugs into.
What style?
Don't know the Model Number wasn't stated.
DC Power Jack checks out, then I suggest you have a problem with a Power MOSFET,
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
(Model Number is on the Bottom of the laptop. Plus, this IS a Dell, right?)
Post back in a Comment.
Regards,
joecoolvette
Feb 19, 2013 | Dell Inspiron Computers & Internet
AC adapter power connection LED blinks but not charging
This suggests to me that you need to check out the AC adapter, and see if there is an intermittent short. In otherwords a break in the wires.
AC adapter unplugged from laptop, and power, remove the AC power cord from the body of the AC adapter.
Use a multimeter set to OHM's, (1K), and connect the Positive (Red) probe lead to one of the flat bladed prongs, in the power plug that plugs into the surge protector.
Touch the Negative (Black) probe lead to one of the holes in the plug, that goes into the AC adapter 'body'.
Keep going from hole to hole, until you get a reading.
Now have an assistant gently wiggle the power cable, and see if you get an intermittent reading.
Do the same for the other plug's flat bladed prong.
Intermittent reading means replace the power cable, or if more feasible, the entire AC adapter.
Power cable proves to be fine, move on.
Plug the power cable back into the AC adapter. Plug the AC adapter into power.
Using a multimeter set to DC Voltage, touch the Positive (Red) probe lead of the multimeter, to the center hole of the plug that goes into the laptop.
(If just a symbol, the DC Voltage symbol is a dotted line over a solid line)
The Negative (Black) probe lead, touches the outside cylindrical metal shell, of the plug.
Have an assistant gently wiggle the cable, and see if there is an intermittent reading on the multimeter.
(Reading should be 18.5 Volts DC)
[There are Analog multimeters which have a scale, and a needle, and Digital multimeters that just have a digital readout.
If using an Analog multimeter the needle will drop towards 0.
If using a Digital multimeter the readout will drop to smaller numbers, or 0 ]
AC adapter checks out? Go on.
The port on your laptop where the AC adapter plugs in, is the DC Power Jack.
AC adapter unplugged from laptop, Battery removed.
Take a pencil, and gently use the eraser end to see if you can wiggle, the center pin of the DC Power Jack.
ANY perceptible movement means a problem with the DC Power Jack.
The GOOD news is that the DC Power Jack, is NOT soldered directly to the motherboard.
It slides down in a Channel on the outside edge of the Base Enclosure, and has a wiring harness coming from it.
The end of the wiring harness has a plug, that plugs into the motherboard.
The HP part number for this DC Power Harness is HP 600630-001
A) http://www.dectrader.com/600630-001-New-HP-DC-input-power-socket-connector-With-cable.html#.UD0_w6B0k9Q
B) http://www.ebay.com/itm/HP-Compaq-600630-001-DC-Power-Input-Jack-Cable-CQ42-G42-Notebook-Series-/180932154005?_trksid=p4340.m1850&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D11%26meid%3D1653940420718665976%26pid%3D100011%26prg%3D1005%26rk%3D1%26
This is a link to a free Service Manual from HP Support,
http://h10032.www1.hp.com/ctg/Manual/c02627955.pdf
Page 73 is for the Power Connector Cable.
No damage to the DC Power Jack, and the harness is not slightly unplugged?
Now you have real problems.
You have a bad Power MOSFET,
A) MOSFET:
http://en.wikipedia.org/wiki/MOSFET
B) Power MOSFET:
http://en.wikipedia.org/wiki/Power_MOSFET
C) http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
However it doesn't take a rocket scientist to replace. (Sorry Gort)
These SMD's use a J-lead contact. Simple unsoldering, and soldering.
(Better be fast though as you don't want to overheat a power transistor. Better be good, because you don't want any cold solder joints)
For additional questions please post in a Comment.
Regards,
joecoolvette
Aug 28, 2012 | HP Computers & Internet
Which ac do when a laptop compaq nc6400 is verr slow and doesnt charge the battery
What does the AC do? (Alternating Current)
Apparently not get rectified into DC electricity by the AC adapter, (Charger), or the rectified AC (Which is now DC), is not getting to the laptop.
Be sure the Battery is still good. They have a lifespan, and only last so long.
Verify, by performing a DC Voltage test with a multimeter, if the AC adapter is putting out the correct Voltage.
If it is an AC adapter for an HP Compaq NC6400 Notebook PC, the DC Voltage coming out of the AC adapter is supposed to be
18.5 Volts. (DC),
http://www.amazon.com/Notebook-Adapter-Presario-cq50-142us-cq50-110/dp/B001MQ4MNW
On the AC adapter plug going to the laptop, the center pin is the Positive connection.
The outer cylindrical metal shell is the Negative connection.
AC adapter puts out 18.5 Volts?
Have an assistant;
1) Gently wiggle the power cord coming TO the AC adapter.
2) Gently wiggle the cable coming FROM the AC adapter TO the laptop.
See if you get an intermittent reading on the multimeter. Indicates a broken wire.
[ An economical, but fine for this test, multimeter, can be purchased for as little as $8 to $12, here in the US.
Analog or digital is fine.
Available in a multitude of stores. An auto parts store is but one example ]
AC adapter checks out it's on to the DC Power Jack.
This jack is the round port on the laptop, that the plug from the AC adapter plugs into.
Battery removed use a wooden small object, and gently see if you can move the center pin around, for the DC Power Jack.
See if the rest of the DC Power Jack will move around.
The DC Power Jack looks like this not mounted to the motherboard,
http://www.batterystyle.com/compaq-nc6400-jack-p-436629.html
Click on the two views shown of the DC Power Jack.
The view on the left shows the jack from the back.
The view on the right shows the jack from the front. The view you see now.
Note that in both views the jack is shown upside down, in relation to how it actually sits on the motherboard.
The view on the left, (Back view), shows Prongs coming from the jack, that go down through the motherboard, and are then soldered.
The gold colored prong is the Positive prong. It goes to the Center Pin of the jack.
All of the silvery colored Prongs are for Ground, or Negative.
Where the Prongs are soldered to the motherboard, are called solder joints. Each prong has a solder joint.
It may just be that one, or more solder joints are cracked.
This would require disassembling the laptop down to the bare motherboard in your hand, then re -soldering any cracked solder joints.
[ Be SURE to use an ESD wrist strap, and have it's alligator clip connected to a good ground source, BEFORE working inside a laptop ]
It may be however that the DC Power Jack is damaged, and replacement is necessary.
HP Support > HP Compaq NC6400 Notebook PC > Manuals page,
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=101&prodTypeId=321957&prodSeriesId=1847703
On this page click on - Service and maintenance information
(Under the - Quick jump to manuals by category - heading)
Under the bold - Service and maintenance information - heading, click on -
HP Compaq NC6400 Notebook PC Maintenance and Service Guide
(24 Apr 2007 / 4.61MB )
[ This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the above file name, it may take up to 30 seconds, before the first page comes up ]
Need guidance in de-soldering, and removing the old DC Power Jack, and soldering in a new one?
Post in a Comment.
If the DC Power Jack checks out, you have a bad power correcting chipset. This is a type of Power MOSFET.
Motherboard replacement is the solution.
Regards,
joecoolvette
Apr 25, 2012 | HP Compaq nc6400 Notebook
I got a compaq c36 it was working fine but now it wont switch on or anything do you now what it could be
1. Plug the laptop into AC power.
2. Take out the battery.
3. Try a different outlet.
4. Look for the light that indicates that the AC adapter is plugged in. If that light isn't on, try plugging and unplugging the AC power jack and moving it around until the light shows its connected. If no light comes on, its possible you have a bad DC jack or the AC adapter needs to be replaced.
5. If the indicator light is on and the laptop won't power on, then it's possible you have a bad switch board or stuck button. Make sure no buttons are stuck. Conversely, push hard on the power button and move it around in order to make sure you're making good contact.
6. If you know the battery has a charge, unplug the AC adapter and connect the battery. If it turns on, then you can be sure you have a bad DC jack or a bad AC adapter.
Mar 01, 2011 | Computers & Internet
Advent N270 netbook will not charge. Orange light comes on initially then goes off. Also when I wiggle the plug into the laptop the light flashes on and intermittently.
It sounds like either a bad connection on the motherboard or a broken wire in the adapter making intermittent connection.
1. With the power adapter disconnected, do you have a power light? This would indicate the adapter is good and the plug is questionable.
2. Check your power adapter output with a multi-meter.(be sure to wiggle the wires around) If the power fluctuates, replace the plug.
3. If the power is solid, replace the motherboard connector.
Nov 22, 2010 | Intel Computers & Internet
Pluged aspire 4520 in at night. next morning, no lights no power. nothing
if the unit will power one with ac adapter plugged in then you have a bad battery. check to see if you dc jack on the lap top lights up when you plug in the AC. if it does not light up then your dc jack or ac adapter is bad.
Jan 27, 2010 | Acer Aspire 4520-5582 Notebook
Hp pavilion dv5-1002nr will not power up
Let's run through a basic flow chart.
1.Plug the AC adapter, (Charger), into the laptop.
Is the Power LED light on, and the Battery charging light?
[The Power LED light is on the front edge of your laptop, all the way to the left.
There are three small rectangular LED lights in this area.
1) All the way to the Left - Power LED light.
2) In the middle - Battery Charging LED light.
3) On the right - Harddrive Activity Lamp {Light}
The HDD Activity lamp blinks when harddrive is in use]
Gently wiggle the AC adapter plug, that is plugged into your laptop.
Does the Power LED light and/or Battery Charging light, 'Wink' when you move the plug? (Blink)
Does it stay on when you keep it over to a certain position?
If so, you have either a bad plug on the end of that AC adapter cable, wires that are bad in the cable itself, or a bad DC Power Jack.
(The DC Power Jack, is the port where you plug the AC adapter in. May be labeled as DC IN)
Do you wish to test the AC adapter plug?
See if it has an intermittent connection, due to a break in the wires that meet the plug?
And/or, see if the AC adapter is putting out any voltage, and if so, the correct amount of voltage?
Do you have a multimeter?
A cheap, yet effective multimeter, can be purchased for around $10 to $12 at most auto parts stores. (Radio Shack has them, and a multitude of other stores also. Not an advertisement for Radio Shack)
Set the multimeter to DC Volts, (Turn the knob in the front), and if it has a separate setting, set it to DC Volts - 50 Volt scale.
Read the label on the AC adapter's case. You are looking for the OUTPUT voltage/amperage.
Example:
I'm looking at an Acer Aspire laptop's, AC adapter right now.
INPUT: 100 - 240V ~ 1.8A - 50/60Hz
OUTPUT: 19V === 3.42A
The Output voltage is 19 Volts.
AC adapter plugged into the surge protector.
The Red lead, (Positive), of the multimeter, (Right now it's being used as a Voltmeter), is inserted into the middle of the AC adapter plug.
The center of the plug is the Positive connection.
The Black lead, (Negative), is held against the outside of the AC adapter plug. The round cylinder of the plug on the outside.
This illustrates the AC adapter,
http://www.buy.com/retail/product.asp?sku=213337465&listingid=63465880
The photo shows the AC adapter charger body, attached to the cable with the plug.
To the top left you see the plug, and the shiny metal cylinder. The Black lead touches the outside of the cylinder.
Read whether you are getting voltage, and the proper amount of voltage.
Gently wiggle the plug back, and forth, and see if there is a break.
Voltage, no voltage.
If the AC adapter proves to be good, you have a problem with the DC Power Jack. (DC IN)
The DC Power Jack is on the right side, all the way to the rear.
The setup, and mounting for this DC Power Jack differs from most laptops.
Most laptops have the DC Power Jack soldered directly to the motherboard, or are soldered to a separate small circuit board, that plugs into the motherboard.
This jack has a cable leading from it, and the jack attaches to the bottom case of the laptop, via a small bracket.
To illustrate what I'm referring to here, you may want to download, (Free), the Maintenance and Service Guide from HP Support.
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=3753576&lang=en&
(Just click on the X, of the small survey window that comes up)
On this page Left-click on -
HP Pavilion dv5 Entertainment PC - Maintenance and Service Guide
(10th file down. This is a PDF file. The computer you are on now has Adobe Reader on it, which uses PDF files)
Give it a few seconds to download. It may take up to 20 seconds before you see the first page.
I advise wait, until it has fully downloaded before looking through it, or you may break the download connection.
Under the Bookmarks column to the left, click on the + sign next to - Removal and replacement procedures
Click on the + sign next to - Component replacement procedures
Scroll down, and click right on - Power connector cable
(Or use the blue down arrow above to go to Page 96)
Point of this?
If you are technically inclined, you could disassemble the laptop, and replace the Power connector cable.
The DC Power Jack is part of the Power connector cable.
[BUY and USE an ESD wrist s-trap. Connect the alligator clip to a good ground source. I use an empty desktop computer case, and connect to the metal frame.
Average cost is around $6 for this device. Can be found in a multitude of stores. Again, Radio Shack is one source, but there are many.
Use a multi-compartment container for the various screws you will remove. Label each compartment for the area the screws came out of.
You can use a clean egg carton in a pinch.
Make notes, and drawings as you disassemble. Use a digital camera if you have one available.
Check with HP to see if this part is available. I also would check online, and you may want to give thought to Ebay]
2. If the Power light stays on with no intermittent problems with the DC Power Jack, or the AC adapter:
A.There may be a problem with the Power On switch itself. (Under the Power On button)
B.The Ram Memory modules, (Slang is Stick), may have become jarred loose.
AC adapter unplugged, battery removed. Open the Memory Compartment, and remove all ram memory modules. Now reinstall them.
Reinstall the Battery, and then the AC adapter. (Then plug the AC adapter into the surge protector)
Power On the laptop.
C. The Harddrive might not have a good connection.
All power sources removed again, open the Harddrive, (HDD), Compartment.
Make sure the harddrive's plug is tightly connected.
(Page 62)
D.If none of the above cures the problem, then it's time to seek a professional, competent computer repair shop.
The charging circuit of the motherboard may be bad. There is a sensor that determines if power should come from the AC adapter, or the battery.
It also determines if the battery needs charging.
You may have harddrive failure.
[Again, if the shop does determine it to be a bad motherboard, AND you feel technically inclined, you may want to replace the motherboard yourself.
Check online, and also Ebay]
Dec 16, 2009 | HP Pavilion dv1000 Notebook
When you plug in the ac the power is intermittent and then will go into hibernation. With a full charge the battery will last about 30 min. If you unplug the battery the ac will work for a short time then...
Sounds like you have a loose DC jack or a faulty AC adapter. Try testing the adapter with a multimeter (or have a someone do it for you) to see if it's output is consistent. If you wiggle the ac adapter plug slightly when it is plugged into the jack on the notebook and this causes the power to go on-and-off (you should be able to tell by a power/charge led on the notebook) it is likely the DC jack if the AC adapter tests ok.
Prices to replace the jack vary. My shop does it for $65 labor + $15 for the jack on most non-apple notebooks.
Sep 21, 2009 | HP 510 Notebook
Toshiba plug-in ac adapter LCDlight flashing and wont boot up
It may be that you need a new, (Or good condition used), motherboard. You may not.
The problem could be the DC Power Jack. The DC Power Jack is small, and the body is made of plastic. Sometimes there is a metal shell around the plastic body. (The jack is a rectangular shape, and is just a little larger, than the outside portion of that AC adapter plug!)
This is an example of a DC Power jack for a Toshiba Satellite a215-s5807,
http://www.notebookworks.net/ProductDetails.asp?ProductCode=NBW52-0133
As you know there is a metal pin in the center, and at the back of the round hole, there are flat metal contacts.
Let me explain the construction of a DC Power Jack, and how it's mounted to a motherboard. This all has relevance to the solution.
Your laptop uses DC electricity. (The AC adapter converts AC to DC. Your laptop battery, and a flashlight battery, are examples of stored DC electricity)
DC uses a Positive connection, and a Negative connection. The metal pin in the center is Positive. The flat metal strips at the back are Negative.
That laptop DC Power Jack has metal prongs, that come out of the plastic body. One prong, (Or pin), connects to the Positive metal round pin, in the center of the jack.
There may be one, or two prongs, (Or pins), that come out of the plastic body, and connect to the Negative side of the jack. (Flat metal strips)
These prongs go down through holes in the motherboard, and are soldered on.
With the AC adapter plugged in, an accidental bump on the plug itself, could break the body of the jack, or break solder joints that hold the jack to the motherboard.
AC adapter removed, and battery removed. Use a NON-metallic object, and see if you can make the center pin of the jack move. See if the entire jack itself seems to move.
A.If the center pin moves, you have a broken DC Power Jack.
B.If the entire jack moves, you have cracked solder joints. (Broken)
Replacement of the DC Power Jack for A.
Re-solder the solder joint/s for B.
Cost of replacing a jack at a reputable computer repair shop? $90 to $150
Cost of re-soldering solder joints? $50 to $90
Cost of replacing the motherboard?
$250 on up.
If you are a skilled person with the correct tools, it is feasible for you to replace the jack, or re-solder the solder joints.
It is also feasible that you yourself, could replace the motherboard.
Some laptops have a poor motherboard design, for where the DC Power Jack is mounted to the motherboard.
Crude explanation would be, that the main body of the motherboard is a 1 foot square. Then a 2 inch square comes out of the side of the main body.
The DC Power Jack is mounted to that 2 inch square. From accidental bumping, OR just normal usage of inserting, and removing the AC adapter plug, this 2 inch square can crack away from the main body.
This, of course would require a motherboard replacement.
Disassembly instructions for a Satellite A200 and A205 Series laptops. Very close to the A215 Series,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-1.htm
(Don't forget to buy, and use a cheap ESD wrist strap, to prevent static shock to the delicate hardware components, inside your laptop. Average cost is $7)
Aug 04, 2009 | Computers & Internet
HP Pavilion dv6426us Notebook Logo
116 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
