Question about NetGear Powerline XE102 Ethernet Bridge Network Adapter
Netgear wall plug XE102 stops working when downloading
I have two Netgear Wall Plug XE102's. Internet works perfectly until I download a file. It will start at say 500k, then go down to 400, 300, 200, 100, 0, then just stop. I have to reboot the wall plug for the Internet to work again.
  • 1,272 Answers
It seems to be an issue either with the powerline adapters or the electric line. Swap the devices and check if it helps. Also, disable encryption utility if being used
Try connectig both teh devices in the same room and check the download speed
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Posted on Jul 25, 2009
My wall-plug says it can't get in ip adress. It also says that it can't even connect to the network. Is this fixable? If yes, how? (P.S. This isused for my xbox by me, if that helps anything.)
The device is for "bridge the networks" each other PC,Laptop,etc...,is not a router.The device communicates with the router so you can have better "signal" between any device that want access to your network.
Here is a great tutorial to Connect and troubleshhot your Xbox to a wireless network.
If you need more help post back! Thumbs and testimonial are welcome!
There is a great article at Working with Windows Wireless Networks
Dec 08, 2010 | NetGear Powerline XE102 Ethernet Bridge...
I have MacBook and it is not recognizing the ethernet connection
1. First check the light status of the XE102.
2. Then hard reset the Xe102
3. As this is a plug n play device all the lights should come on.
4. In case if the lights wont come on.
5. Check the powerline ..
6. And if that will not work , get a new adapter or replace the existing one from netgear ( 1-888-638-4327 )
Jan 26, 2010 | NetGear Powerline XE102 Ethernet Bridge...
Only power light NetGear XE102
I was never a big fan on thos plug in ethernet devices. I would either go wireless or run hard line to the computer.
Dec 25, 2009 | NetGear XE102 Powerline Ethernet Adapter...
No lights come on when I switch on my XE102.
Though, it is not repairable, yuu may contact NETGEAR to get the unit replaced if it is still under warranty. Contact them http://my.netgear.com
Regards
Anand
Aug 08, 2009 | NetGear XE102 Powerline Ethernet Adapter...
The middle light on my netgear ethernet bridge xe102 wont stay on
-- Xe102 device is simply a plug n play device
-- so if the connection light shut off after some time
-- first hard resett the powerline adapter
-- and after that get the powerline checked
-- If that doesnt work there is no specific configuration
get the adapter replaced ..
Jul 01, 2009 | Powerline Netgear XE102 Ethernet Bridge...
I purchased two netgear wall plugged bridge XE102. They worked fine for one month. Now I get messages on my computer do not detect homeplug adapter. On my TV it say's is not hooked to the internet. What is...
I had the exact same problem those branded ones at our shop where one just stopped working all together.
THeres a couple of things to rule out so you can try some steps to figure it out.
Try changing the port on the router where the first plug is hooked into, if you can, try a direct connection without the plugs aswell. Also, try inserting the plugs in different outlets and see if anything has changed. If they're only a month old, they are still under warranty and you could get them replaced either through ytour place of purchase or from netgear aswell.
Apr 26, 2009 | NetGear XE102 Powerline Ethernet Adapter...
Can't Connect to Netgear Range Extender Kit
-- you can connect the Xe102 to he wall plug where ur router is placed
-- And then reset it from the reset hole on the back of the Xe102
-- and after that connect the WGX102 to the other wall plug where u wanna get wireless access ..
-- And then reset it from the reset hole on the back of the WGX102 as well
-- And once u do that it will not ask for a security key .
-- It will show netgear unsecured
-- try to connect with it and u will be connected
Feb 14, 2009 | NetGear WGX102 54 Mbps Wall-Plugged...
I have a logitech cctc system but when i plug in the usb device it states there is a problem with the powerline bridge driver and states its not compatable with vista but logitech states it is compatable...
You might have a 64-bit Windows installed. The drivers on the CD are only for 32-bit windows. Download and install the latest drivers from Logitech website (http://www.wilife.com/Support/Downloads.aspx), which includes the 32-bit and 64-bit versions. Hope this helps !
Jan 06, 2009 | Powerline Netgear XE102 Ethernet Bridge...
Trouble installing XE102 Powerline
there wasn't actually any problem with the device. For these bridges to work, you need to be on the same phase of the wiring. If the devices are on different phases then they can't communicate. But I still couldn't get the encryption to work. Netgear support doesn't seemed to be bothered with that...they told me to ignore it.
Dec 16, 2008 | NetGear XE102 Powerline Ethernet Adapter...
Netgear xe102 isnot picking up an ip address
-- Xe102 is a plug n play powerline device
-- there is no specific configuration required for that .
-- try hard resetting from the reset hole on the back of the device
-- then get the powerline checked
-- check the light status of the powerline device.
And if the problem still persists , upgrade the powerline device ..
Follow the link below ::
http://kb.netgear.com/app/answers/detail/a_id/901
Nov 15, 2008 | NetGear XE102 Powerline Ethernet Adapter...
NetGear Powerline XE102 Ethernet Bridge Network Adapter Logo
333 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
