Question about ASUS P4PE-X Motherboard
Motherboard and CPU Frequency
Monitor would not come on. when finally on, message of "motherboard not meeting up with CPU frequency" appeared
    President:
  • 392 Answers
Goto BIOS by pressing DEL or F1 or F2 , then in that press F9 for default settings. then SAVE & EXIT...
Posted on Jul 24, 2009
  • 120 Answers
It seems to be you hace a p4-pex.. check your cpu,, cpu must be 533MHZ specs and lower, try to boot the pc in lower specs.. like 2.0GHZ at 400 MHZ.
  • 724 Answers
Lack of info..
Need spec of both parts CPU and MO BO
DID they ever work together?
    President:
  • 1,383 Answers
When you power up the computere press F2 or "del" or F5 key towenter in bios then load optimal defaults settings.then save then check.
If still problem arise then pull out cmos cell for 15 minutes from motherbord then it auto reset to factory defaults.
Intel core tm duo cpu e4500 motherboard
Intel = Processor (CPU ) manufacturer
Intel Core tm = Trademark. The Intel Core is a Trademark from Intel
CPU stands for Central Processing Unit. Another term used is Microprocessor, or simply - Processor for short.
e4500 is an Intel Core2 Duo processor.
Maximum frequency rate ('Speed') is 2.2GigaHertz.
2MegaByte of L2 Cache. (2MB of L2 Cache)
800MegaHertz Front Side Bus. (800MHz FSB)
Tells me Nothing about the actual motherboard. Look on the motherboard for a Model Number. May be in center of motherboard. May be on edge of motherboard. May be in-between one of the expansion slots, on motherboard.
Post back in a Comment.
Also post what the problem is, in your best description.
Computer does not turn on. (Power Supply does not turn on)
Computer seems to turn on, but get No Signal on monitor, or Sleep Mode on monitor, or Power Saver Mode on monitor.
LED lights light up, and fans spin.
Regards,
joecoolvette
Apr 23, 2013 | Computers & Internet
Please help.. my monitor has no display and my don't even beep. the LED in the monitor turns back to orange after few seconds. cpu, disk drives and ram are working..
This is one of the serious problem that arises because if you set your monitor with a high resolution with high frequency, then the monitor doesn't display anything as it's frequency is out of the rang or limit of the monitor's actual resolution capacity. Each monitor will have a limit of max frequency that is said to be the Refresh rate (for each and every resolution setting the display is refreshed.) When high resolution is set with high frequency that is not supported by the monitor, it then display a message like "frequency out of range". If you press ESC key within the few seconds of this setting, it will revert back to its initial resolution. But if you continued with the setting of same High resolution with High frequency, the monitor is not going to display anything because its frequency is out of the range. Most of old monitors like CRT's etc doesn't support 1024×768 at a refresh rate greater than 60Hz.
Jun 20, 2011 | Asrock P4I45GV R5 Motherboard
Try to put operating system in computer comes up with overclocking failed error how do i reset or fix overclocking problem
hit F1 or DEL right at boot repeatedly until it enters bios. look for cpu/frequency, perhaps underneath "chipset" or "advanced" settings. lower the cpu/frequency a little, until it boots, or look for "auto" settings for the cpu/frequency and ram speeds.
Nov 23, 2010 | EliteGroup 945P-A (945PA11) Motherboard
Acer h233h monitor flickers with any cpu usage above about 20%
sounds as though you sre using to hich a resolution frequency...try to set your frequency to 60mhz or possibly 75mhz. Anythinh higher can cause problems.This can be done through "control panel" at the monitor settings.
Jan 04, 2010 | Acer AL1511 15" LCD Monitor
In the middle of my screen a blue box is showing and in it this reads OUT OF RANGE H. FREQUENCY 68.7 KHz V. FREQUENCY 85.0Hz What does this mean and how can I fix it this was a gift...
That message appears when the Windoze display settings exceed the monitor capabilities. If you will boot into windoze safe mode (F8 at boot) and correct the display settings, the message should clear at the next boot. Afterwards you can right click on the desktop and access the display settings to make final adjustments.
In your case, the refresh rate (V Frequency) should not exceed 70 Hz
Nov 23, 2009 | Envision H22W 22" Monitor
ECS P4IBMS Motherboard CPU Voltage Jumper Settings
I don't believe that there is a P4 motherboard that needs jumper setting to specify the CPU voltage. This used to be common for Pentium & Pentium II motherboards, & some Pentium III motherboards. But I have never seen a Pentium 4 motherboard that require this kind of setting.
Besides, I checked the motherboard's manual & I saw that there is a sub-menu in BIOS labelled "Frequency/Voltage Control". This should be the place where the CPU voltage should be set, & on most motherboards, CPU voltage & frequency are automatically detected.
Jun 20, 2009 | EliteGroup ECS P4IBMS Socket 478pins...
Can't change the resolution
The frequency failure is probably a message from the monitor to say it cannot cope. When setting resolution click "advanved" and try reducing the frequency.
Apr 30, 2009 | GE Asus P4GE-MX...
Which frequency of processor for QDI motherboard BrillianX-1S with BIOS 4.51 PG
hey there.
If you are planning to upgrade the processor with the latest one then it is not possible without upgrading your motherboard.
Because as per all the bus and system configuration requirement with ur CPU you must give the recommended bus speed, bus lines, Address lines, Ram supportive slot, and RAM Frequency.
Your motherboard must suuport all those requirement if you are upgrading ur Processor.
You are right that ur motherboard can only work with PIII CPU.
Upgrade ur motherboard with atleast of 845,945G Chipset to support up to core2 Duo Processor in Intel. OR with A8V-VM and above in Asus Motherboard.
(Gimme your acknowledge by rating me)
Romy
Aug 03, 2008 | Computers & Internet
Motherboard problem
If your cpu fan is faster,it may be due to a higher frequency setting.
The frequency that it runs best at is 60 hz, but it can be running at 70 hz or higher.
Jun 14, 2008 | ASUS P4P800-X Pentium Motherboard
ASUS P4PE-X Motherboard Logo
209 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
