Question about Garmin nuvi 255W GPS Receiver
My Garmin turns on and shuts its self off.
My Garmin--mid-trip--last night shut itself off then turned itself on. Then as soon as the map came up the edges of the screen turn white and the screen shuts off. It's not a very old Garmin.
    Brigadier General:
  • 4,090 Answers
But it might have a very low charge or a bad battery (despite being connected to Dc) recharge the battery from AC or replace the battery
Posted on Jul 26, 2009
Shuts off during navigation
This is often caused by no memory left on the unit, corrupted map or system files and a large trip log. Please see this link for more info on boot-up issues:
SHARCNET USA Out of Warranty GPS Digital Camera Repair Center
Mar 21, 2014 | Garmin nuvi 1300 Car GPS Receiver
I shut my Garmin Nuvi off mid trip home, now when i want to start another trip the map shows me at the location I shut it off at. How do I get it to start back at my own address??
It would appear that it's not accessing satellites. If it was it should know that you're at home. First, if you haven't already, press Menu and then STOP so it stops trying to continue the journey.
  • If it then won't access satellites outdoors you should try updating the operating system software. Download and install Webupdater to your computer from http://www8.garmin.com/support/collection.jsp?product=999-99999-27
  • Connect your satnav to your computer and run the webupdater program
  • It will search for updates to your satnav operating system. Install any updates it finds.
  • When it finishes installing updates it will give you the option of installing optional updates. It's not necessary to install these unless you want to.
This should solve your problem.
Jun 05, 2011 | Garmin GPS
Nuvi 225W shuts off as soon as it comes on
Well, I had a similar experience with a nuvi 1300, and perhaps my solution will work for your unit.
I tried holding my power button for 10-15 seconds, which forces it to start, but mine (like yours), would begin starting, get stuck on "Loading Maps." and then shut itself off.
I had to plug it into a USB port of a PC, and it started up for the purposes of data transfer, (not the normal startup). I then unplugged it from the PC and it restarted properly.
Give that a shot and see if it works.
Apr 12, 2010 | Garmin nuvi 255W GPS Receiver
My Garmin shuts off in the loading maps screen every time we try to turn it on. It will flash the Garmin logo when it gets turned on, go to the loading maps stage and then just shut off. Any ideas?
first I would try to load the current firmware from garmins website. if that doesnt work then try a master reset by holding the bottom right corner of the screen, holding that and turning it on. it will however erase all user data.
Aug 12, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin 178C Stays on for 20 secs then turns off
I had the same problem. In your settings you can set this thing to monitor your battery's power so it auto shut down if your battery goes below 11.2 volts or so. I disabled this and it has worked ever since.
Jun 16, 2009 | Garmin GPSMAP 178C Sounder GPS Receiver
KDF-46E2000 turns off then back on by its self
* Most common would be a couple of capacitors in the power supply that are not letting the proper voltage to the lamp.
* The lamp itself is not working properly.
Jan 25, 2009 | Sony KDF46E2000 46" Projection HDTV
Garmin 760 - No Voice Directions
Go back into your tools and settings and re select the voice of american jack and see if it comes back on.
I lost the voice 2 days ago while on a trip from tenn. to florida and this fixed it. we never shut off the voice but somehow while using bluetooth or FM trans it shut off voice transmiting.
Dec 14, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
Heater shuts itself totaly off as soon as the room is warm
Difficult to guess what the problem might be due to the amount of electronics the unit has that could cause inconsistent or illogical functioning.
I noted one product review that said "if the room is too large the auto shutdown will engage".
I suggest you revisit the instruction manual and specifications before deciding whether to call a service engineer....
Sep 24, 2017 | Bionaire BCH-4138 Ceramic Compact Heater
Garmin 300
Is it working with the charger plugged in? when you take the charger off, is it immeditaly shut off? if it shuts down, does it wake up to the same point/map/stage it was before? more info is needed.
Oct 23, 2007 | Garmin n vi 300 GPS Receiver
Garmin nuvi 255W GPS Receiver Logo
825 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
