Operating Systems
Problem for Operating Systems
Generic problem for all Operating Systems
Re-installation of windows after format C:
By rli2 on Jul 24, 2009
hI, i after formated C: drive, I would like to reinstall from beginning, can not find C and CD drive, any way to solve? thanks
Comments:
Jul 24, 2009
- but my computer not reconized CD drive...what now? thanks
Jul 24, 2009
- When my computer is powered on, I tried to check the boot-screen for setup key (i.e. DELETE key, F8 key, F2 key) to enter BIOS panel: BUT all these failed to allow me to access BIOS, any other KEY? all shows "missing operating system..." put boot disk in A, get A:\, what can i do now?
Jul 24, 2009
- It is Intel, the problem was I press DeL together with "Power on" while i should wait a second. thanks
Jul 24, 2009
Jul 25, 2009
- Sry, It was ESC key I used to Access BIOS. NOT "DELETE" KEY, this is Acer notebook and with Intel in it.
DOS i used command was: FORMAT C:, ONCE power on, and press ESC, then get into BIOS, SET order as CD-HDD-FDD, then exit and save, put cd in, re-start, then window installation window pop-up, just follow screen after, my problem is some dll files failed, may be cd scratached not readable, also a ERROR MSG showed temporaary folder not accessable (?????!) - but whole process I belive on right track. not need a boot disk.
may be i should reformat HD, what should to use? format c:?/?/?//..pls help thanks
Best Solution
posted on Jul 24, 2009
Helpful)
jeevan.m
Rank: Guru
Rating: 90%, 448 votes
1. Insert the Bootable Windows CD in the CD Drive 2. Then Power On your Computer and Boot from the CD. 3. Then proceed with the installation . For installing this you dont require to find C and CD Drive. hope this solves....
Comments:
Jul 24, 2009
- Then go to BIOS and then check whether your CD Drive is detected or not , if it is not detected , open your CPU Panel , and then check CD Drive back and change the jumper settings. After you change the jumper settings from primary or secondary then the CD Drive will be detected.
Jul 24, 2009
- hey actually tell me which motherboard are you using... But initially when you turn on your computer , just ina fraction of second a screen will appear , which shows you motherboard manufacturer or Company , there itself the key for BIOS will be displayed... generally for Intel Motherboards it will be F2 or DEL , Mercury it will be DEL ... First of all let me know the model of your computer and the motherboard you are using ..
Jul 25, 2009
- when u power on your computer then onwards press delete... then u will enter into BIOS Screen....
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Not Rated)
santhoshjsr
Rank: Wiz
Rating: 81%, 145 votes
restard your pc enter f8 or delete buton slect 1 st boot device cd rom after install os windows soft
Was this helpful?
Yes
No
Solution #3
Not Rated)
jennerina
Rank: Guru
Rating: 88%, 32 votes
put Disk in CD drive and set PC settings to boot from CD drive first instead of C:, it should self run from there.
Comments:
Jul 24, 2009
- different manufacturers use different keys for entry into BIOS, try F2, F8, and even F11. If those don't won't work, go one by one *function key* and see which will let you in. Make sure you are hit the keys at the very beginning of turning it on. Sometimes holding it down until it goes through or repeatedly hit the button helps. If you are getting a beeping sound, that most likely is not the appropriate button. F2 or F8 are the most likely keys.
When you formatted, did you format through windows on do format from DOS command C Prompt?
If formatted through DOS, you will most likely need to learn some basic DOS commands to set it read CD drive to reinstall.
It still doesn't explain being unable to access BIOS from start function key. Good luck to you.
Jul 24, 2009
- Pressing DELETE while powering on? Only hit one of the function keys. Not delete. *sorry if I am misunderstanding you*
Was this helpful?
Yes
No
Popular Solutions for Operating Systems
Questions and Unsolved Problems for Operating Systems
Answer
How can I upgrade my royal 660 cashregisterlink to cashregisterlink pro
Answer
my computer does not perform any better than when i installed your program. if any ting it is worse.... (More)
Answer
i have wipro laptop model no 7B1110, which was formatted , now i want to install drivers couldnt... (More)
Answer
I've used this software successfully for several years. When I try to burn to CD I get the message... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Operating System Experts
Top Computer & Laptop Repairmen
in , CA
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
