Question about GE GSS20IEPWW / GSS20IEPCC Side by Side Refrigerator
The freezer side works good but the refre side does not cool.
Only one side cools
    Sergeant:
  • 202 Answers
FAn not working of duct clogged
Posted on Jul 24, 2009
Sub Zero 642 side by side, refrigerator side not working.
If the refrigerator compressor runs and cools when you use the manual activation mode but does not run normally then the control board would be what I would suspect. If it has the manual activation then it is new enough to give error codes. If it is not running and not recognizing it's not running, something is wrong with the control. Unless you are seeing two dashes in the refr display. That would mean the refr section was disabled.
Jan 11, 2016 | Sub-Zero 642
GE Profile, bottom, freezer Freezer does not stay at 0 degrees. With uses during the day it gets up to 20 degrees. Ice cream does not stay frozen. This happens mostly in the summer. Once it get cold...
most refregerator..usually open the door at day time..so it will not keep on required temperature o degreefrequent opening refrigerator,must be adjust the thermostat to higher setting..
Jul 11, 2011 | GE Refrigerators
Water leaking into bottom of refr
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 03, 2010 | Whirlpool 21.8 cu. ft. Side-By-Side...
Fridgefreezer top fridge section has stopped
see if the back panel inside the refr comes off if it does and u have a fan back there make sure it is working if not make sure its gettin power to it and if it is and not running then replace it and see if this corrects the problem if this fails see if u have a duct going from the freezer to the refr if u do take it apart and see if somethings blocking the airflow or if it has a door thats stuck shut and not letting air go thru
Mar 01, 2010 | Refrigerators
FAN IS RUNNING BUT FREEZER AND FRIG NOT COOLING whirlpool ED22TQXFW00
2 possible issues... 1 are you sure the freezer is not working, if the food is basically frozen, but no cool in the refr. then you may have a defrost problem, if no cool at all in both then a relay on the compressor has shorted out. relay is very common!
Dec 31, 2009 | Refrigerators
Freezer frosts up and stops cooling after approximately 2 weeks GSS201EPHWW
AUTO DEFROST IS BAD REMOVE FREEZER BACK PANEL CHECK HEATER CONTINUITY WITH REFR. UNPLUGGGED IF HEATER BAD ORDER HEATER KIT FOR YOUR MODEL
Jun 24, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer works but refregerator is warm
If this is the model I am thinking about, you have the same compressor for each side. There should be a vent or opening that you can adjust to let cool air inside the refrigerator. Find it and adjust. You may have this opening blocked by something. Let me know if this fixes the problem.
Jan 24, 2009 | GE GBS18HBM Bottom Freezer Refrigerator
GE GSS20IEPWW / GSS20IEPCC Side by Side Refrigerator Logo
257 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
