Question about Sharp R-820B Convection/Microwave Oven
My ge microwave is rusting under the turntable.
My expensive GE microwave is rusting under the turntable. GE seems to think it has never happened before although the same thing happened to my sister's new microwave. In the past I have not had this problem with other microwaves I have owned. The microwave is built in a brick wall.
  • Sharp Master
  • 9,098 Answers
This is due to either liquid spills or steam buildup or both.
In rare cases, you may have bad air flow (blocked vent or clogged filter) or a weak internal cooling fan or hood vent exhaust fan.
It's recommended to wipe off any moisture that accumulates inside, and leaving the door open a while after cooking may help, too.
And I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out of the controls and door panels, etc.
You need to clean the area, sand it shiny, then clean it squeaky again.
Then you can get high temperature appliance paint in spray or brush-on form from local appliance part stores or places like Wal-Mart and Lowe's.
I would suggest you let it dry overnight with the door open before using the oven.
You can find helpful exploded view diagrams and order parts (such as charcoal filters, etc.) by entering your full model number from the tag on the oven here.
You shouldn't need to remove the oven from the wall to take care of this problem.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Posted on Jul 25, 2009
Have ge model je1860 turns on but when you hit cook nothing happens is it the turn table motor. i don't want to do trial and error on parts.naturally the fuse is good
I'll presume you can program it ( set the length of time you want to cook)
Does the timer count down?
Does the turntable ( if you have one) turn?
If everything else seems to work properly and it just doesn't cook more then likely the magnetron is bad
$87 from Sears:
http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Microwave-Parts/Model-JE1860WH04/0432/0123245/G0590488/00005?blt=06&prst=&shdMod=
Jan 18, 2011 | GE JE1860 Microwave Oven
We have a GE Microwave Model# JVM1660 and the turntable dosent work
the spindal motor under the microwave in some cases burn out these units are not expensive to have replaced you will need to find a local microwave tech in your are
best wishes
Dec 29, 2010 | GE Microwave Ovens
Are there any recalls on GE microwave JVM1540DN1ww Thanks, ssi96@aol.com
There are no recalls on GE over the range microwave JVM1540DN1WW but there SHOULD BE! Mine lasted only a year and a half and then started running and heating with the door open. Shortly after that it stopped heating at all. The light and fan works, and the keyboard lights up but the turntable doesn't turn anymore (yes I made sure the turntable was turned on), and it doesn't heat. It will count down like it's heating but it doesn't heat. Changing the door switches didn't work. Husband thinks it is the magnetron which is expensive to fix. I won't ever buy another GE microwave period! Check the web and you will see all the similar complaints. I just searched online and for a lesser price than I paid for the GE, Samsung sells one that has the one year warranty but also has a 10 year warranty on the magnetron.
Jan 25, 2010 | GE Microwave Ovens
Glass turntable replacement
GE has parts available at their website , but they seem very expensive. We have a chain of appliance parts stores in Mich called APCO. If you have a simular store perhaps they can help for less. This link is for GE website.
https://www.geapplianceparts.com/GEApplianceParts/Dispatcher
Jan 06, 2010 | GE Profile Spacemaker Over-the-Range...
I have a GE Spacemaker II microwave: JEM25GY that died. It seems less expensive to replace rather than fix. Power works; it doesn't heat. New models all apparently have turntables; mine didn't and I...
YOU CAN TRY REMOVING THE GLASS TRAY AND TURNTABLE AND REPLACING IT WITH YOUR OLD GLASS TRAY (IF YOU HAD ONE) OR JUST ANY GLASS MICROWAVE TRAY. WITHOUT THE TURNTABLE, I CAN'T SEE HOW IT CAN ROTATE.
Nov 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE XL1800 will not heat
sounds like the twt is bad (the traveling wave tube) that is quite expensive. Unfortunately your solution is probably to buy a new one.
Jan 22, 2009 | GE XL1800 1100 Watts Microwave Oven
Turntable not rotating
I fixed my own GE turntable by replacing the motor. You can purchase the part (#WB26X10135) directly from GE for $34.75 plus tax and shipping ($8.95) or from RepairClinic.com for $24.90 plus shipping ($6.46) and no sales tax except for delivery in Michigan.
The part is easy to install. Just print out this drawing to see where it goes (look for part 43) underneath the unit. Of course, be sure you unplug the oven first!
Hope this helps!
Aug 02, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1631BB005 making noise
Many thanks to e3enigma above! I removed the synch motor under the turntable; all other microwave functions work fine and the grinding noise is gone, hooray! A trip to the appliance parts store tomorrow for a replacement synchronous motor and all should be well. Thanks again!
Jan 06, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL 1800 - turntable issues
check capacitor and motor drive of turn table.
Jan 03, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Sharp R-820B Convection/Microwave Oven Logo
479 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
