SOURCE: i need codes for philips universal remote control
lost manual tring to hook up dvd/vcr emerson up need code
SOURCE: codes for daewoo tv, ge remote model 24912
Codes for Daewoo are: 0451, or 0092
If this doesn't work with your new remote there is always the way that I have done it in the past and that is to use the find the code function on your new remote. It is a pain but can be done and is quite effective. Each remote is slightly different, but for the most part you would hit the set up botton and hold it in until it starts flashing then hit the T.V. Button and then hit the first code it tells you to hit and then hit the power switch if it doesn't turn off your T.V. then you hit the increment button up, (this is different for each remote so it is important to follow the instruction manual on this part) You bassically keep hitting the incriment button until your code comes up and then it will turn off your t.v.! Then your done. Note: It may take up to 400 pushes of the increment button, but it will work.
SOURCE: program my zenith converter box to my tv
while holding down the tvs power button push the channel up or down slowly. this will turn your tv off when your code is found. when it is found and your tv goes off release the power button. now your remote will work with your tv...........
SOURCE: codes for Daewoo TV & DVD on Ge UN Remote #
go on their website there is always a list of codes
SOURCE: I have a ge universal remote model #24110R need tv code
http://www.jascoproducts.com/support/universal-remote-codes.asp
0130 0004 0009 0100 0005
....0138 0043 0140 0039 0444 0080 0042
....0058 0017 0010 0126 0018 0127 0019
